Page 409 of 775 FirstFirst ... 309359399405406407408409410411412413419459509 ... LastLast
Results 8,161 to 8,180 of 15487
    May 2009
    #8161
    Quote Originally Posted by mika_23 View Post
    Hindi siya galing s harap. May sarili siya condenser located sa tabi ng 3rd rear seat. Wala din siya filter.
    Does this mean mas mabilis dumumi yun components sa rear aircon dahil walang filter? Thanks.
    Aug 2009
    #8162
    The latest facelift for the innova doesn't look too bad, except for the wooden armrest, and ala corduroy seats. Can you guys recommend options for the seats? Any feedback on leather upholstery, leatherette and cloth seat covers? I'm not convinced with the materials used. Family is thinking of getting one to replace the old workhorse. Thanks!
    #8163
    Quote Originally Posted by vvti2.0 View Post
    Gaano kainit? Kung hindi mag fre wheel, baka may slight sticking na ang caliper brakes mo, repair kits lang katapat nyan.
    Anong repair kit sir? magastos po ba?
    #8164
    #8165
    Maybe you meant evaporator bro?
    Jun 2012
    #8166
    Yup, evaporator pala hehe
    Quote Originally Posted by matt chua View Post
    I think so hindi ko pa napapaservice ung saakin ung sa iba medyo, kung gusto mo bili ka ng aircon filter sa ACE na pwede ihulma mo sa rear intake para kahit papano mafilter ung alikabok.
    #8167
    ^hindi na nag Xmas light. Kaso still observing. 2x na nangyari e. Still observing. Will have the connection checked also. Sayo?
    Sent from my Nexus 5 using Tsikot Forums mobile app
    Pasumpong sumpong yung blink niya.
    check connections? how? baklas dashboard diba to access the optitron gauge?
    Aug 2006
    #8168
    Anong nagbi-blink? A lot of new VIOS has this momentary blink on the optitron. Inquired with TMBC at wala pa daw silang solution dito kahit marami na ang reported cases, yung sa new VIOS ang blink niya ay korteng padlock at sabi ng SA this is related to security circuitry. Lumalabas ang blink when sudden hard acceleration or deceleration.
    Reson for editing: okay, I did some back reading and I think this case is not related to new VIOS blinking on the optitron. Whole panel optitron pala ang nagbiblink sa car ninyo
    #8169
    Quote Originally Posted by Mile2 View Post
    Yup whole panel ng optitron bro.
    Akala mo christmas light.
    Mukhang dalawa pa lang kami ni CB naka experience.
    Mar 2012
    #8170
    every morning pag mag start ako, may malakas na vibration sa bandang ilalim ng innova ko. hindi ko naman masilip kung saan yun dahil medyo mababa ang innova. usually madidinig ito pag mataas ang ideling. may naka experience na sa inyo nito?naka ilang silip na ako pero d ko pa din makita. pa sumpong-sumpong kasi kaya mahirap hanapin. tnx
    #8171
    Quote Originally Posted by gygie View Post
    Experience this also, parang tunog ng loose belt (sa may bandang likod ko nadidinig), i told the SA last PM (10k) wala naman daw loose. Akala ko last time sa aircon sa likod but off pa naman and kahit not moving yung vehicle may tunog pa rin basta the engine started, pero mamaya wala na.
    Oct 2011
    #8172
    Hindi kaya ung loose seatbelt bucke lang yan sir or ung tools sa likod ?
    Posted via Tsikot Mobile App
    Aug 2006
    #8173
    Just securely fit your jack on the tools compartment. Pag maluwag yung jack kumakalog yon at source ng body to jack vibration/rattling.
    Mar 2012
    #8174
    napansin ko pala kaninng umaga, may vibration pa din. pero ng tapakan ko yung brake, nawala? bandang right side sa bandang likod nangagaling yung tunog. pero dati naman wala eh. ang mahirap lang kasi on and off ang ingay, kaya mahirap hanapin.
    Jul 2006
    #8175
    guys meron ba naka experience sa inyo sa diesel m/t na kapag nirerelease yung clutch right before umandar eh me sound na "tug" sa ilalim? thanks thanks
    #8176
    Quote Originally Posted by sirmykel View Post
    a long time ago, sa jeep namin... maluwag na yung cross joint ng propeller shaft. palit lang, ok na..
    Apr 2009
    #8177
    Good day Innova Owners!
    Mga Sirs, question lang po regarding the Positive Crankcase Ventilation (PCV) valve ng innova. Does this valve need the vacuum created by the intake to operate? meaning vacuum-triggered ba siya? Or is it a simple one-way relief valve na gagana at magbubuga ng blow-by gases kahit walang vacuum from the intake side? I'm planning to make changes sa oil catch tank ko, and it will affect the vacuum created by the intake.
    TIA.
    May 2012
    #8178
    sir ask ko lang about change oil
    last change oil ng innova 2012 E AT namin is lastyear JULY * 10kPMS using fully synthetic oil
    ngayon nasa 15k PMS papa change oil ko naba or pede to til 20k odo?
    sensya naguguluhan kasi ako kung kelan ba talaga
    Feb 2010
    #8179
    Good Day Innova Gurus...
    Inquiry on mags...
    Ask ko lang if kasya sa Innova natin ang 17 x 7jj Offset 45 with 225/50 R17 tires?
    Kindly advise mga gurus...
    Thanks in advance
    Oct 2011
    #8180
    Quote Originally Posted by evincar View Post
    Sa 20k na yan sir since FS oil ang gamit mo.
Toyota Innova Owners & Discussions [continued 3]
