Page 414 of 775 FirstFirst ... 314364404410411412413414415416417418424464514 ... LastLast
Results 8,261 to 8,280 of 15487
    #8261
    I wonder if meron ba Bosch na fuel filter for innova. Iniisip ko kasi 9 years na rin. Baka madumi na rin yun kahit low milage pa
    Sent from my Nexus 5 using Tsikot Forums mobile app
    #8262
    Baba ng mileage mo bro baka ubra pa yan.
    Yung OEM ba ano tatak?
    #8263
    denso siguro.
    Aug 2006
    #8264
    Quote Originally Posted by desertfox615 View Post
    sir, where do you source your OEM shocks? is it KYB or Tokiko?
    Toyorama or LVC di naman sila nagkakalayo sa price ng OEM Toyota parts
    Oct 2013
    #8265
    CB
    2600 din kay toyorama
    SA casa mas mura, around 1.8k lang ata yan. Nagtaka nga rin ako bakit mas mura sa casa compared sa Toyorama.
    #8266
    Quote Originally Posted by vvti2.0 View Post
    Talaga? Di pa ako naka canvass sa casa eh? I assumed mas mahal kasi.
    If thats the case ang labo nun ah? Hehe
    Aug 2006
    #8267
    Kung P1.8K sa casa hehehe magpapalit na ko ako after 7 years
    Dec 2012
    #8268
    anybody here has a wiring diagram for Innova E 2012. Specially for the fog light portion. Thanks
    Jan 2013
    #8269
    hello tsikoters.. question lang..
    1. Meron bang race chip or similar gadget na pang Innova VVTi?
    2. Ilang HP ba ang increase pag kinabitan nito?
    3. Plug n Play ba ito like SB? meaning walang puputulin na wiring or whatsoever..
    4. Meron na ba tsikoter na nagkabit nito sa kanilang Innova whether d4d or vvti?
    maraming salamat..
    Mar 2004
    #8270
    tanung ko lang po kung may naka pag try na po maglagay ng Intercooler sa innova d4d 2.5? thanks.
    Aug 2010
    #8271
    malamang meron kay warren.
    #8272
    i have problems with my INNOVA 2005 vvti... Engine won't start... no clicking sound.. battery is still in full charge.
    Ano kaya problema? meron bang relay ang mga starter? saan ko makikita ito? or baka full assemble na papalitan?
    #8273
    Quote Originally Posted by kristine123 View Post
    personal experience several times already...
    car wouldn't start. no clicks except the steering column key. i thought the battery was ok, because the lights would work and the horn still made a racket..
    but in truth, the battery was in its last throes..
    good luck.
    (luckily, it was a MT. i had it push-started and drove straight to the battery shop, where i had my battery tested.)
    #8274
    good luck.
    as in no clicking sound Sir? i have volt meter inside my Innova, 12.something Volts. it won't go down to 12volts even headlights and fog lamps are open. i will try another battery tomorrow. Thanks
    Oct 2011
    #8275
    Is there any chance that you have an aftermarket alarm system installed in your innova ma'am kristine ?
    Posted via Tsikot Mobile App
    #8276
    No, i don't have aftermarket alarm system sir retz...
    #8277
    Mga ka-innova sa mga nagpa change fluids outside casa.
    Ano gamit niyong
    Brake fluid
    ATF
    OEM pa din ba? Or you tried other brands?
    Oct 2011
    #8278
    For brake fluid you could use other brands like Bendix or Mag1 (DOT 3). ATF fluids, better stick with OEM Type T-IV.
    #8279
    Thanks retz.
    Matic din ba sayo? Dame ba type ATF like engine oil? I mean rating?
    Oct 2011
    #8280
    Afaik sa Toyota lang ung Type T-IV yan ung latest na ATF fluid may nakikita akong ATF-Z1, SP-III, Mercon etc.... pero sa ibang brand ng sasakyan na un sir. Meron ung Dexron III pwede sa power steering fluid but not sure if compatible din as ATF fluid so better stick with OEM imo.
Toyota Innova Owners & Discussions [continued 3]
