Page 408 of 775 FirstFirst ... 308358398404405406407408409410411412418458508 ... LastLast
Results 8,141 to 8,160 of 15487
    #8141
    Anyone experienced blinking optitron gauge? Our blinked for around 10secs earlier. The whole gauge was blinking. What could be wrong?
    Sent from my Nexus 5 using Tsikot Forums mobile app
    Sep 2013
    #8142
    Quote Originally Posted by Innovaer View Post
    at 40K, should i change to semi synthetic or full synthetic? from regular...
    any tips?
    Sakin baliktad tayo. I used mineral oil when i got my brand new car then started using FS * 30K up to the present.
    Oct 2011
    #8143
    any tips?
    mag FS ka na lang sir kung konti lang price difference sa semi.
    Apr 2009
    #8144
    Hello mga fellow tsikoteers! Plan ko sana palagyan ng roof rail yung unit ko. Nag canvass ako dito samin (dasma) mga 4.5k yung bigay. Original oem parts daw sya tapos dinidkit lang. Okay po ba yung price? Para kasi mahal. Oks lang din ba yung dinidikit lang na roof rail ? May recommended store po ba kayo ma advise along south (cavite, las pinas, paranaque)?
    Posted via Tsikot Mobile App
    #8145
    Quote Originally Posted by kristine123 View Post
    Di nya nakuha new model 2014 sir?
    nope he got olde rmodel. Sabi ko nga kung kelan may facelifted na hindi pa niya naintay.
    Experiencing it too! actually napapanay nga eh? hindi ko na lang pinapansin.
    what seems to be the problem kaya?
    Palit optitron gauge? i hope nothing serious.
    Last edited by cast_no_shadow; February 21st, 2014 at 02:44 PM. Reason: added last sentence
    #8146
    Is it normal for the Automatic Transmission Innova G na umiinit front wheel after driving?
    pansin ko kasi hindi free wheel ang front wheel ng Innova AT? is it normal guys?
    #8147
    Could be the wheel bearing.
    #8148
    almost all cars now have disk brakes up front. the pads are always rubbing against the disk, generating some heat. thus, the hotter front wheels compared to the rears. but the heat should be uncomfortable, at the worst. if it is more than uncomfortably hot, then something is wrong..
    Oct 2011
    #8149
    Hindi kaya sa alternatir yan sir kaya nag blink optitron gauge? Pag nasira yan, wala ka na makitang gauge.
    #8150
    isn't that the visual warning that the door is open when the engine is running?
    when alternators die or get disconnected, the symptom is gradually diminishing bulb, fan, and other electric appliance intensity/sound/etc. within one hour, you will notice these..
    Oct 2011
    #8151
    Actually that is what i suspect since blinking optitron gauge might have something to do with the alternator supplying the voltage not unless there is something wrong with the optitron gauge itself.
    #8152
    Just replaced the following on our vvti innova.
    OEM air filter
    OEM oil cover gasket
    6quarts Top1 SDO
    Baldwin oil filter
    Denso iridium spark plugs.
    #8153
    OEM air filter
    6quarts Top1 SDO
    Baldwin oil filter
    Bro CB hows your gauge?
    #8154
    ^hindi na nag Xmas light. Kaso still observing. 2x na nangyari e. Still observing. Will have the connection checked also. Sayo?
    Oct 2013
    #8155
    Gaano kainit? Kung hindi mag fre wheel, baka may slight sticking na ang caliper brakes mo, repair kits lang katapat nyan.
    Oct 2013
    #8156
    OEM air filter
    6quarts Top1 SDO
    Baldwin oil filter
    Ano yung coil cover gasket?
    #8157
    ^i meant oil cap gasket.
    Sent from my Nexus 7 using Tapatalk 2
    May 2009
    #8158
    Fello innova owners na magpa-aircon cleaning na.
    Tanong lang po. Yung hangin po ba sa rear aircon is galing rin sa harap (under dashbaord) at dumadaan rin sa aircon/cabin filter?
    Or may sarili ba siya source at sariling filter din?
    TIA.
    Jun 2012
    #8159
    Quote Originally Posted by matt chua View Post
    TIA.
    Hindi siya galing s harap. May sarili siya condenser located sa tabi ng 3rd rear seat. Wala din siya filter.
    #8160
    Pansin ko din ang pag flicker ng optitron gauge pag nag ON ang AC. Mas pansin din ito pag naka polarized glasses ka. Baka normal lang.
Toyota Innova Owners & Discussions [continued 3]
