Page 458 of 775 FirstFirst ... 358408448454455456457458459460461462468508558 ... LastLast
Results 9,141 to 9,160 of 15487
    Aug 2014
    #9141
    Quote Originally Posted by n5110 View Post
    parang may nagalaw sa wiring ng innova nyo. G-gas itong sa akin normally pag switch ON ng ignition, iilaw ang mga indicator including ABS then mawawala din after 2-3 secs. pag patay at hugot naman ang susi dapat walang naka ilaw. bago ba pa install ng turbo timer ganun na?
    innova E diesel itong sa akin sir, Normal naman sya pag switch ON ng ignition, iilaw lahat including ABS then mawawala after ilang secs. Lalabas uli ang ABS after na hugot ko na ang susi at activated ang turbo timer, patay lahat ng accessories including aircon, ang engine lng ang running. If naka set sa "0" zero ang turbo timer, after hugot ko ng susi, di na lumalabas ang ABS indicator at automatic rin off ang engine which is normal. Lumalabas lng talaga sya if running lng ang turbo timer. Yung wala pang turbo timer dati, walang lumalabas na ABS kasi paghugot ko ng susi, automatic patay rin ang engine. Anybody na nakaranas nito mga sir/s.
    #9142
    Quote Originally Posted by crosswind View Post
    dr.d what brand did you get??
    i just got a hybrid nwb wiper for the crosswind
    ngayon sa innova naman
    daily driver yung innova ko malabo na wipe kawawa naman yung driver
    i don't recall the brand. but it did come with a light green blade protector that you slip off...
    nono.. that's not right. that was the replacement.
    the one that lasted long, came with the car when i bought it second hand 4 years ago... that, i do not know the brand of!
    sorry.
    Mar 2012
    #9143
    meron na bang nakapag pakabit ng power window sa innova J? plano ko kasing magpakabit. may na search ako sa web na may nag kakabit sa evangelista. ano kaya ang puedeng maging problema? tnx
    Jan 2014
    #9144
    sorry.
    Thank you Dr.d btw you have a innova?
    #9145
    yes. i have two. 2005 and 2012.
    Jan 2014
    #9146
    Maybe the wiper is NWB thats what most car brands uses
    #9147
    Mga ka-innova!
    What is throttle body? saan siya located? ano purpose niya?
    how do we maintain it? or pinapalitan ba ito after a certain period or KMs?
    Salamats!
    Up this one. anyone can shed a light?
    Jan 2014
    #9148
    Mga sir ask ko lng po if san po maganda magpa 10k pms sa innova natin yng sa labas napo ng casa ksi may kamahalan sa casa eg it cost 8k po lahat npo change oil nd tune up. Sa q.c lng po ako tnx po...
    #9149
    Throttle body. this is where the clean air is coming in preparation for combustion. i guess lahat ng gas fed engine have the same term naman. sa experience ko sa kotse ko dati once na sobrang dumi ng throttle body hinde na maganda ang idling ng sasakyan, kailangan baklasin at gamitan ng caburetor cleaner. dito sa innova at 32K wala pa naman akong na raramdaman na signs na kailangan ng i service. maybe you can check the manual kung may cleaning ng throttle body at XXXKM reading.
    #9150
    Quote Originally Posted by Jason Perez View Post
    kaka PMS ko lang ng 32K. change fluids ( mineral), spark plugs,oil filter, gasket, adjust ng hand brake, top up coolant at iba pang checkup. 3588.70 pesos gastos.
    Jan 2014
    #9151
    Ganun po ba sir pati tune up ksama napo ba dun? San po kyo nagpa pms sir?
    Mar 2012
    #9152
    question lang mga sir, may moisture ba yung bubong ng innova nyo pag gumamit kayo ng AC? tia
    #9153
    Quote Originally Posted by gygie View Post
    Sakin meron.
    Jan 2014
    #9154
    sa Shell po 6k aabutin medyo mas maganda pa rin sa casa
    saakin parang humina kapit ng brake sa handbrake
    Jan 2014
    #9155
    saakin sa side parang fog
    #9156
    wala naman nakalagay na tune up dun sa work scope pero maraming chineck aside sa change oil. sa toyota alabang ako. kasama na dyan yung 20% labor and 15% parts discount
    #9157
    sakin, hindi sa bubong. sa right rear fender. malamang, may kaunting leak ang insulation doon...
    May 2012
    #9158
    Meron din sa rear right gitna ng gulong saka salamin,kaso bakit pag tanghali Hindi efficient yung lamig Para sa cabin lalo na pag umpisa Parang tas nabilad,saka uneven ung hangin at lamig., sa gitna sa left mahina ung lamig kesa right sa last row naman mas malakas yung blower sa right kesa left?
    #9159
    Quote Originally Posted by jyg1995 View Post
    Nasa kanan kasi rear blower ng innova nakalagay.
    Pag nabilad sa araw normal naman talaga na mahirap palamigin ang oto.
    Aug 2014
    #9160
    sir, tanong ko lng, anong brand ba ang turbo timer ng innova mo? familiar ka ba sa connection ng wiring nyan? baka kasi merong mali sa connection ng timer ko. Amata brand tong sa akin, bali 3 wires lng nakakabit, +12v, ignition and ground. Verify ko lng sana yung connection sa ignition, kasi itong sa akin, naka tap sya sa black/red na wire ng innova. ganun din ba sayo? thanx in advance sir.
Toyota Innova Owners & Discussions [continued 3]
