mga bossing, in our innova the "door open" indicator in the panel has this faint light whenever the switch is set to "door". The indicator is not as bright when a door is open but there's a very faint light, say 25-30% of a normally swithched on light. It totally shuts off when you move the switch to "off". Common po ba ito?
Hindi ba more on sa crdi lang yan? Kasi malinis naman ang gasoline.
Posted via Tsikot Mobile App
Di naman yan nililinisan, and hindi naman yan nasasakal.
Automatic transmission sayo di ba? Marmai factors kasi na nakaka apekto sa fuel consumption.
Baka madumi lang air filter mo and also your spark plugs, nag iridium ka na ba?
Sa central diesel ata madam, pwede sa kanila ang injector cleaning ng petrol engine.
Try mo check sa obd scanner kung tama nga yung fuel consumption mo. Baka naman di naman injector ang issue.
Di lang naman kasi fuel consumption ang pwede maapektuhan ng maduming injector, kahit yung usok and hatak affected yan.
Normal na yan sir ung sa akin nga 6-7km/Li d4-d.
Never had that problem, mine is a 2009 vvti.
though i had that problem on my bike. Garnish was forming on the fuel gauge sensors due to seldom use and mostly low fuel level. The sensors was exposed to air for long periods of time.
try doing a full tank and dont let it fall half the mark. Try doing it for a few weeks and see if it wojld loosen up the fuel sensors.
*kristine. Palyado po ba ang pakiramdam nyo pag running at high speed? Yung tipong parang hinde smooth? Dati sa honda sedan ko 2400 ang injectors cleaning sa goodyear servitek. Meron silang stand alone na cleaner na may ultrasonic to de clog the injectors. Before linisin ipapakita sa iyo ang buga ng injectors. Makikita mo kung consistent ang labas ng sa mga butas. Baka hinde din dyan ang problema.
