Page 308 of 775 FirstFirst ... 208258298304305306307308309310311312318358408 ... LastLast
Results 6,141 to 6,160 of 15487
    #6141
    Hello guys!
    ask ko lang regarding fog lamps, sealed ba siya? Parang disposable?
    i mean pag napundi palit ka ng buo or bulb lang papalitan?
    Deads na kasi fog lamps ko, nauna yung left side last year pa ata yun. Then yun right ayaw na din umilaw kagabi.
    OEM pala fogs ko.
    Thanks!
    Oct 2011
    #6142
    pwede bulb lang palitan pag napundi. use the same oem or same wattage if other brand. pwede diy since may instruction naman on how to replace fog lamp sa manual.
    #6143
    Thanks bro retz!
    Naku drive lang alam ko bro hindi ako mabutingting sa sasakyan hehe.
    How will i know if bulb ang sira or may ibang problem?
    Pag kasi kinatok ko yun isang fogs umiilaw pa parang may maluwag lang sa connections.
    Oct 2011
    #6144
    check mo ung bulb, normally mangingitim pag napundi na at putol na filament, kung hindi naman baka may loose connection lang somewhere.
    #6145
    Noted!
    Salamats!
    #6146
    Quote Originally Posted by mr_x View Post
    Tanong lang mga guru:
    Nag pa PMS ako kahapon for 5k and may dalawang item akong brought out sa casa:
    1. Yung tunog every morning na parang belt na di maka ikot, lasting for about 30secs then gone, only happens in the am
    2. Yung speedometer ng innova has +10 more km/hr reading compare sa GPS ko.
    Yung #1 sabi baka daw sa fan belt but when they chk mahigpit naman, then this morning notice ko yung tunog is when you open the aircon so maybe sa aircon nga, ask ko yung iba if may am tunog din kayo when you open aircon in morning time only.
    Yung #2, na prove nila na mali nga yung speedometer ng innova, they use a gadget and road test it, yung gadget nila at yung gps ko pareho read, while yung car +10 km/hr. Ex. 90km sa gps, 100 na sa car.
    Ask ko yung iba if may issue rin kayo na ganito or pa try kahit using your phone with gps for the speed kasi first time na may nakita silang ganito.
    Salamat po.
    Generally, the speedometer of all vehicles are calibrated on the high side, which is about 5KPH to 10KPH higher than the ground speed as measured more accurately by our GPS units....
    So, you can "run 105KPH in a 100KPH zone"..... (This is the reason *as in the case in the US* that there is a generally acceptable practice that you can run higher by 5MPH over the speed limit,- because you are actually running right on speed limit as measured in their GPS and doppler radar/speed radar or gun)
    19.0K:higop:
    #6147
    19.0K:higop:
    Sir, i ask this also sa casa (boss nila) and say dapat daw accurate. Yung gps ko kasi galing sya sa altis ko and very accurate sa altis, less than 5km lang difference. Sabi ko din sa casa baka sinadyang ganun talaga, 5km is ok with me but 10km too much. Im using all stock tires.
    #6148
    Bro.,- and what do you expect from the casa (and their boss)?,- siyempre immaculate ang produkto nila at walang problema,- that is their training. But of course, we know better. Baka nga mas magaling ka pa sa boss nila, base sa iyong experience.
    I'd say it is by design as guardband to the speed limit.... If you are to refer to your speedometer,- you are actually running a few KPH/MPH compared to the speed limit... That is 'safer' in a sense....
    19.0K:higop:
    #6149
    19.0K:higop:
    Got your point sir, my other worries is the accuracy of the ODO and the km/L consumption kung accurate din. This is more important to me. Tnx sa reply.
    Dec 2007
    #6150
    Salamat po.
    I have Waze and indeed the speedometer reads higher than what the gps navigation displays.
    #6151
    I would think that the odometer would be accurate to a certain tight tolerance, bro... So, should be no worries there.
    BTW, I think that I am quite confident when I say "by design"... , because that is how it is with our 4 run-of-the-mill rides of different makes (no brand loyalty here,., ).... Nissan, Honda, Toyota and Hyundai....
    19.0K:higop:
    #6152
    19.0K:higop:
    I think this will be my next to check, odo vs gps distance travelled.
    Gonna chk those trip meter in gps.
    Anyway, according sa casa they will test another innova and report back the findings if found significant they will escalate.
    Note: The good part is seen for overspeed, the downpart is under speed. If limits is 60-100, and you think you are just 60(safe) but reality youre just 50.
    Dec 2007
    #6153
    Talking of car owners, bibilib ako sa patience ng taong imemaintain ang min speed sa highway.
    Jul 2011
    #6154
    ang alam ko binawasan ang accuracy ng GPS ng US Dept of Defense. dati yata <1meter accuracy ngayon yata +/- 10m ang accuracy nya pag commercial GPS.
    baka daw magamit ang GPS technology sa guided missile targeting US homeland.
    #6155
    19.0K:higop:
    Quote Originally Posted by MrQ5 View Post
    Tama naman sir, +/-10 meter nakalagay naman for fix location sa gps, pero we are talking thousand meter (km) here and its moving, gps accuracy is +/- 1km for moving. Sa cell na may gps ganyan din accuracy.
    Jan 2010
    #6156
    mga ka innova ask ko lang sana kung ano gamit nun rubber strips on both sides of the roof sa innova natin? sa akin kasi flimsy pag ka kabit yung edges parang matatanggal na, pwede kaya tanggalin ko na lang? kasi parang babahayan pa ng water at sanhi pa ng kalawang.... mahalay kaya kung tatanggalin?
    Jul 2003
    #6157
    Quote Originally Posted by Capsaul View Post
    +1
    Nireport ko yan nung nag 5K PMS ako ilang linggo lang nakaraan.
    Mukang common problem sa Innova kasi ganun din yung ibang units na nagpapa service sa casa.
    Sa opinyon ko wala naman itong kritikal ng epekto pero naiipon yung mga gabok at dahon sa mga sulok sulok.
    Mejo hindi ko lang nagustuhan at mawari kung bakit hindi ginawan ng paraan ng casa. Kahit naman sang ayon ako sa service advisor na common problem siya, hindi ibig sabihin hindi na nila ito aayusin tsk tsk. Hindi na lang ako nakipagtalo at ako na magdidikit. Baka rugby na lang/contact cement.
    Jan 2010
    #6158
    Quote Originally Posted by fourtheboys96 View Post
    +1
    ganun pala baka DIY na lang... hehe
    #6159
    Sa akin medyo matigas na ang rubber. minsan parang gustong matanggal driver side. binabalik ko na lang.
    Gusto ko sana palitan kaso ang mahal....
    Oct 2011
    #6160
    rubber strips sa roof?
Toyota Innova Owners &amp; Discussions [continued 3]
