Pinupunasan kasi ng carwash boy ang mga hydro lifters, natutuyo ang lubricant at nasisira. Occasionally i apply atf oil para dumulas ulit, 4 years ok pa nman.
Shibby. Yun nga. After carwash last week bago ko napansin na nagka problem. Ano ba dapat maintenance nung hydraulic door shock?
Parang hindi na active si sir amir lately. Nag post siya ng picture ng rear door hydraulic shock binebenta niya dati pwede isang pares o one piece. Pero hindi ko na pinapalitan hinyaan ko na lang bihira ko na rin kasi gamitin ung innova.
Sent from my iPad using Tsikot Car Forums
Isnt it using the same container of the front windshield washer? It just uses a different motor?
Paano po tanggalin yung 3rd row seats? They are pretty much dead weight now kasi they are always folded up because I need the trunk space and dalawa lang kami palagi. Worried din ako baka mapuwersa yung handles kung saan nakakabit yung hooks for the seat.
Thanks in advance!
it's pretty straightforward, because the retaining bolts are large and very visible.
but i think you have to return these bolts after the seats are removed, because you can see the outside thru their holes.. not to mention, you can easily lose these bolts in your garage.
also, you're in an awkward position while doing the bolts, and the seat is heavy. you may need an asistant to restrain the seats, or else they fall (on you!).
