Guys,
Ilan pala ang spark plugs ng Innova VVTi natin?
I'm planning kasi to try using Denso Iridium Spark PLugs, and try using also the Hurricane Air Filters...
Many thanks![]()
I am using denso iridium for 3 months now. Pansin ko tumipid ng konti, nag register na ng 8kml sa odo ko. Dati 6-7kml lang, pero never 8 on stock plugs. Pero pansin ko din na pagdating ng 120kph, bumagal na mag 180. Dati no sweat ang 180.
Bought it from a seller in sulit, located sya sa new manila. 4pcs for 2k.
Hi Guys,
Nag pa PM kc ako last Saturday pina check ko na rin lahat ng shocks. Then may findings na minor leak sa shock sa driver side.
Ask ko lang po kung pwede ko na siya pa replace kc warranty pa naman yung units ko.
Thanks in advanced.
Kung front shock, mejo me kamahalan yan. Covered ng warranty as long as stock rims ka.
rear left shock ko nagka leak, pictyuran daw and claim as warranty, then call nila ako pag me stock na.
iiwan daw car ng 2 days, at isa lang daw inaprove for replacement.
Di na ako nag claim, bumili na lang ako sa casa, 900 lang naman rear shock.
Baka makahuyan pa ng pyesa ang oto ko sa luob. Replaced it myself, wala pa 30min tapos na 2 shocks.
Does anybody know how to remove the body panel where the rear evaporator is? Will appreciate the instruction. Thanks.
Isa lang din leak sa akin, kaso mejo pinatagal ko ng ilan buwan before replacing. When i removed both old shock, the non leaking shock was unusually softer than the bnew one.
I assume since leaking yung kabila, the other side was working twice as hard just to control the bounciness. I just replaced both sides.
Regarding the rear evaporator , meron gumawa diy instuction thread dito, search mo na lang.
i had mine done before because i sprung a leak in my rear evaporator. pinanood ko. i am confident i can do it. it's easy but repetitively boring, not to mention you have to do it uncomfortably haunched..
remove the covering mats. then remove the plastic panels at the right. it's intuitively easy, really. the screws are easy to find but are many, and they are big and easy to manipulate. the hard part is you have to remove the third row seat as well.
good luck.
Yes the seat has to be removed. I just don't want to break any clip. Will try and remove the panel slowly. Do you think I can DIY the evaporator cleaning. I'm planning to install yung filtrete using velcro sa panel pero gusto ko mainspect muna evaporator. Thanks.
hi sirs,
tanong ko lang ilan nasasakay niyo sa 3rd row ng Innova, kaya ba apat na payat if ever?
Thanks!![]()
noob question innova users
bought our innova last May 2012 Innova E
13k odo
ask ko lang maingay kasi tuwing umaapak ako sa brake, matinis na tunog everytime na nag brake ako, minsan meron minsan wala
hindi ko alam kung need naba to pa check or linisin etc.... sorry noob lang talaga sa sasakyan
