Page 402 of 775 FirstFirst ... 302352392398399400401402403404405406412452502 ... LastLast
Results 8,021 to 8,040 of 15487
    #8021
    is it ok to use 100/90w H4 bulb sa headlight sa stock wires mga sirs?
    any suggestion?
    Narva
    Osram
    Philips
    Philips ko sira na ang isa (low beam) after 2 years
    Jun 2013
    #8022
    Guys saan makakabili ng beige metallic na spoiler? Hinde sa casa ah TIA
    Sent from my GT-P7310 using Tsikot Forums mobile app
    Apr 2009
    #8023
    mga sir
    nagbabalak ako mag palit to iridium spark plugs sa next pms ko (50k)\
    sa ngayon naka OEM lang ako
    significant ba improvement in terms of driving experience?
    Jan 2014
    #8024
    Quote Originally Posted by shibby75 View Post
    Lahat ng diesel nasisira ang injectors, especially sa d4d are prone to injector failures. Kahit sa wikipedia sinani na common ang injector failures sa high mileage engines.
    Toyota KD engine - Wikipedia, the free encyclopedia
    Sbi ng bayaw ko na ahente sa toyota, nasa 120k mileage daw kadalasan pinapaltan ang injectors which costs 15-20k each!
    Dagdag maintenance yon.
    New here, yung sa akin po j variant 06 mt, ok pa injector at 150k
    #8025
    Quote Originally Posted by kristine123 View Post
    any suggestion?
    Narva
    Osram
    Philips
    I wouldn't recommend it sis... You may need to upgrade your wiring.... Plus it could cause the accelerated fading of your headlight
    #8026
    thanks Sir CVT.... di na lang ako bumili... ginamit ko na lang stock bulb headlight ko
    Oct 2011
    #8027
    Anyone encountered stuck-up in their fuel gauge reading needle?
    #8028
    ^sa diesel ba yan retz? try mo haluan ng 2T yung fuel tank mo.
    Oct 2011
    #8029
    Yes sir cb, ganon din ba nangyari sayo? lubrication lang kailangan?
    Posted via Tsikot Mobile App
    #8030
    most likely nagstuck up na fuel float mo. which is common sa diesel lalo na kapag nakapagload ka ng water contaminated diesel kasi nag rust yung fuel float.
    try to put 200ml of 2T in your full tank. see if it will be of any help. madami kasi sa 4x4 forum ganyan. years na stuck yung fuel gauge. after gumamit ng 2T, gumana ulit yung fuel gauge.
    #8031
    Agree with you bro. In my limited experience with our rides in the past and now, changing the HU made a lot of difference in the sound experience vs changing the speakers.... Most notably when the 45W/52W x 4 standard HUs became standard models in the market....
    Thanks sirs sa mga inputs niyo. wala pa akong budget sa HU upgrade sa speakers pa lang. sabi ng mga nakakausap ko maganda daw ang Ryan Audio for tipid meals set up. Salamat
    Jan 2009
    #8032
    Sobrang haba na masyado ng thread and I don't know where to start.
    I'm planning to get an Innova as a second car... lumalaki na mga bata. Anyway, here are my inquiries:
    1. Side by side differences among V, G, E, J and Limited G variants. Can't find this anywhere. Gusto ko sana ma-narrow down na yung trim na pipiliin ko before I go to the dealer
    2. I know choosing between gas or diesel-fed engine is subjective, but, if it's just going to be a secondary car (ie. weekend driver) and I plan to keep it for more than 8 years, what would be best for me and why? My take is, since I predict it's going to be a relatively low-mileage car, I'd get the gasoline variant para mas mura ang maintenance.
    3. Any known quirks with either engine type or AT/MT transmission I should know about?
    Thanks!
    Oct 2011
    #8033
    Cge will try that sir cb sana gumana na after. Thanks.
    #8034
    Thanks!
    1. Welcome to Toyota Makati, Inc. - VIOS INNOVA COROLLA ALTIS YARIS HILUX FORTUNER AVANZA PREVIA RAV 4 PRADO HIACE
    2. For me i choose vvti kung minsan mo lang naman gagamitin.
    Sa kapit bahay namin 2005 till now walang naging problema sa Innova vvti (gas) manual at bago pa till now, 30+k odo pa lang.
    3. mas tipid sa gas Manual transmission compared sa Automatic Transmission.... pero I'm comfortable driving an AT.
    Oct 2011
    #8035
    Sir cb, natandaan ko lang ung sabi ni sir dvldoc doon sa kabilang thread na hindi niya ramdam ang difference using 2T sa petron diesel max.... might be some conflict with the detergents used in petron diesel max. Wala kayang side effects ito sa engine? kasi petron diesel max karga ko. I'm not a 2T user yet but seems like madami na rin ang gumagamit nito.
    Jan 2013
    #8036
    sir, since for family use lang, i would recommend Innova G VVTi AT. Mas smooth ang ride ng gas compared sa diesel at mas classy ang dating ng interior compared sa J at E variant at para sakin sulit din yung price difference with the features and accessories of G variant. No worries sa warranty.
    Btw, i am a very satisfied owner of 2013 Innova G VVTi AT. Ang pinabit ko lang na additional accessories are the ff.
    1. Sprint Booster - c34x4
    2. Spare tire cover at spare tire lock - casa
    3. Engine under cover - casa
    4. Hood insulator - tsikoter
    engine is all stock.
    sana makatulong sa iyong pag desisyon sir..
    good luck
    #8037
    Retz dapat walang problem yan. Iba ibang engine iba iba ang effect kaya mahirap compare Kay devildoc. Modded din kasi engine niya.
    Sent from my Nexus 5 using Tsikot Forums mobile app
    #8038
    Quote Originally Posted by homhomnova View Post
    good luck
    Sir maganda yang nga add ons niyo. Pwede ba pashare ng nagastos niyo?
    Oct 2011
    #8039
    ah okay. mukhang madami din 2T users na Innova here kaya hindi na stuck-up fuel gauge reading nila. anyway, saan maayos muna baka malaking trabaho din pagpalit ng float swtch kung sakali.
    #8040
    That's better... I just hope that my pair of Phillips XP would last longer....
Toyota Innova Owners & Discussions [continued 3]
