mga boss ano ba pinaka magandang ipalit sa ilaw pag nakukulangan na tayo sa liwanag?
ung pinaka maliwanag na bulb lang papalitan at wala nang palit ng wiring..
hanap muna ko mas murang alternatibo sa HID...
salamat sa mga reresponde.
You can try Philips Xtreme Vision or Osram Nightbreaker... I understand that each of them gives at least 100% more brightness than regular halogen lamps....
25.7K:shark:
salamat sa mabilis na reply sir..
pwede po malaman anong specs ng ilaw ang dapat bilin?? at may idea po kayo sa price?
paano naman po sa brake lights? may recommended bulb kayo na pwede ipalit na mas maliwanag?
Headlights of Innova - H4 55/60W (no change is needed in the socket - just "plug and play")
Cost (one pair) is about P1200,- IIRC....
25.7K:shark:
salamat idol..
saan po kaya meron niyan? metro manila... pref qc or marikina?
salamat idol..
best to stick to stock.
baka matunaw ang housing...
besides, who told you your brake lights were dim?
una, bakit ka nakukulangan na ng liwanag? may problema ba ang mata nyo? sa duktor po kayo pumunta.
baka naman, lumalabo na ang plastic lens ng headlight housing.. try re-surfacing the outside with plastic cleaner. kung sa loob naman, someone might know who can do it..
but if you are able, replace the assembly..
my concern with higher wattage lamps, is that the housing and/or socket might melt.
di naman po for preference for safety din pag grabe buhos ulan halos di na makita brake light...
mejo malabo na po ang mata at nasa 60++ na po ako kaya hirap na po sa maneho sa gabi. pero ikokonsider ko po yan mga suhestiyon niyo po
visibility is poor in strong rains.. that is why we should all slow down in them. increasing bulb wattage may not be a bright idea, because...
they may become blinding under ordinary conditions..
we all know who these are.. nakaka-silaw kapag nag-brake..
and sir, if you think your vision is worse now because of age, perhaps you should consider retiring your driver's license... for the sake of the rest of us!
ok lang ba pagbigyan mo muna ako palitan ung bumbilya? hehehehehe
susubukan ko muna ung nightbreaker kasi madami din un ang suggestion. di sila nagsuggest na wag na magmaneho hehehehe
Mas makakatulong ata boss to remove tint and wear corrective glasses to resolve your problem regarding light
Was an osram nightbreaker, nightbreaker plus, philips night vision user before on medium tint. may improvement kaso minimal. And wala akong swerte sa bulbs na to, pundi agad ang low beam in 12-14 months.
this time around, i had hid projector retrofits. the difference was very Huge.
If you really want better light output, this is the way to go. Save up and invest. Imho
