Page 399 of 775 FirstFirst ... 299349389395396397398399400401402403409449499 ... LastLast
Results 7,961 to 7,980 of 15487
    #7961
    Quote Originally Posted by n5110 View Post
    *kristine. Palyado po ba ang pakiramdam nyo pag running at high speed? Yung tipong parang hinde smooth? Dati sa honda sedan ko 2400 ang injectors cleaning sa goodyear servitek. Meron silang stand alone na cleaner na may ultrasonic to de clog the injectors. Before linisin ipapakita sa iyo ang buga ng injectors. Makikita mo kung consistent ang labas ng sa mga butas. Baka hinde din dyan ang problema.
    Thanks sa info sir.... di naman palyado sir. Parang moody ang innova kasi.... may time magaan, may time nabibigatan kahit 2 lang tao. next ko na lang papalinis.
    Feb 2010
    #7962
    Quote Originally Posted by crave View Post
    Hi bro, you can go to pages 46-50 of your owner's manual for the activation procedure or you can go to your favorite casa to activate them for you since medyo tricky yung procedure. HTH
    Sent from my SM-N9005 using Tsikot Forums mobile app
    Thanks for the feedback sir... Already brought my unit back to Toyota Pasig and was informed na disabled na talaga yung feature na Beep Sound Whenever Engaging or Disengaging the alarm. Sound will only activate if there would be an Open Door or Forced Entry....
    Dec 2013
    #7963
    Mga Sir, Tuwing kilan po dapat magpalit ng Air Filter?
    Oct 2011
    #7964
    Ung sa akin every 20k palit sir same with fuel filter element.
    Feb 2011
    #7965
    Hi, tanong lang. Im planning to get a rear spoiler. Im targetting the one without LED light. Clifford Bodykits do have one for 5.5k with paint and install na(plastic sya and not fiber glass). It doesnt need to drill holes and will just be using adhesive type material to install the spoiler. Ok lang ba na adhesive type which is malamang doulble sided na 3M?
    Oct 2013
    #7966
    Quote Originally Posted by altis View Post
    delikado yan. drill type kunin mo.
    Feb 2011
    #7967
    Quote Originally Posted by vvti2.0 View Post
    Problem dun sa may drill... possible lang sya sa mga may kasamang LED light. Dont want to have the option ng LED light if in case in the future that it fails or mapundi hindi ka makakahanap ng replacement.
    Oct 2013
    #7968
    Ordinary na super bright led lang naman ang nakakabit dun sa may brakelight, kapag may napundi, marmai mabibili na piyesa sa alexan, deeco or e-gizmo.
    #7969
    San ka bumibili ng filter retz?
    Oct 2011
    #7970
    Sa toyota mismo sir. Meron VIC pero same price lang sa oem.
    Posted via Tsikot Mobile App
    Jul 2013
    #7971
    Quote Originally Posted by Lew_Alcindor View Post
    Meron ba dito may problema sa aux power at cigarette lighter?
    Yung aux power ever since wala power. Ni report ko na before 5000km pms kaso pinadelay ko muna yung pag ayos kc baklas dashboard daw. Lapit na 10000km pms ko. Iniisip kung papabaklas ko na dasboard. Ayaw gumana kahit palit ng fuse located under the driver kick panel. May ibang fuse pa ba na pde tingnan?
    Sent from my GT-N5100 using Tapatalk 2
    update lang.
    sabi ng service advisor, ECU daw problema. nagulat naman ako. hindi daw ECU ng makina. yung sa electronic devices daw ng ECU. anyway, under warranty naman so papalitan na lang ng bago.
    yung cigarette lighter ok na. yung aux power outlet lang hinde.
    iniisip ko naman, baka masira uli yung ECU na yun kasi wala naman akong kakaibang ginawa para masira yun eh.
    Oct 2013
    #7972
    Parang niloloko ka gn service advisor mo hehehhe...
    Oct 2013
    #7973
    Heto yung schematic diagram ng power source sa katabi ng cigarette lighter:
    Mar 2013
    #7974
    mga sir, tanong ko lang. ok lang po ba talaga na pwede na di na daw lagyan ng relay pag maglalagay ako ng bosch europa silver? toyota innova 2013 po pala akin. Ano po ba mangyayari pag walang relay? TIA
    #7975
    Quote Originally Posted by prince_jeoure View Post
    i had the opinion that a number of japanese cars already have relay to the horn.. but i really haven't dug into my innova yet to find out..
    Mar 2013
    #7976
    Thanks sa input sir.
    Oct 2013
    #7977
    May relay na yan, check this thread.
    http://tsikot.com/forums/toyota-cars...ml#post2255867
    For Innova, Vietnamese ata, pero same lang sa Hilux
    Mar 2013
    #7978
    thank you sa mga nagbigay ng input mga sir, :D balak ko kasi mag DIY sa pagpalit ng horn. para pag ibabalik sa casa balik to stock para di mavoid warranty.
    Aug 2010
    #7979
    yung headlight, may tig isang relay na rin ba yung stock?
    #7980
    oo nga... hirap basahin.. vietnamese, e. but the schematic does show relay..
Toyota Innova Owners & Discussions [continued 3]
