Sir tingnan mo yung parang ash tray na nasa harap ng dashboard.Minsan kasi may mga maliliit na bagay don na nalilimutan na.Kapag umaandar ang makina saka mo lang maririnig.
As my experience.
As my experience.
magbawas ka lang ng washer sa compressor mo or dalhin mo sa mga AC technician alam na nila yun. 10minutes job lang yan 100% solve na probema mo. Hope this will help.
di mo talaga maasahan ang innova pagdating sa paahon kasi high speed ang design ng gearbox. It means that it is fast only in plain surface.
Bronze metallic. Havent checked the inside hood yet pero im sure wala pa dumi yun kasi bihira magamit. Wala pa nga 1k yun odometer.
Someone mentioned na baka masira yun paint (inside and outside) if walang insulation which makes sense due to extreme heat over a period of time.
Most likely kuha na rin ako from toyota to protect the paint and kasi yun altis ko meron din insulation provided na.
Mga sir's is it normal for the rear AC to take some time before mag kick in yung lamig? One significant consideration was that the unit was sitting in the heat of the afternoon sun. We haven't really used the rear AC so I don't really know what to expect although I was thinking it should be similar to how front AC vents behave.
Thanks in advanced!
^^^ Matagal talagang lumamig ang buga ng rear AC lalo na kung nakaparada ka sa direct sunlight... Isipin mo na lang na ang flow ng hangin ay dumaraan sa ilalim ng bubong ng sasakyan na manipis lang ang insulation,- it will take a while na lumamig iyon...
15.5K:boxing1:
What is the best procedure to cool your car faster when park in a direct sunlight? Do you open your car window and let the fan blow at the highest setting? Well, assuming you aren't using any of the Vkool or Huper Optik heat rejection tint.
sakin nakaopen door at window tapos naka high yun aircon..pag lumamig na saka na sarado lahat..malaking tulong din yun windshield sun shade pag nag park ka sa open area na direct sunlight para ma lessen yun init sa loob... meron na din yun auto start engine na alarm system..
Since we are in the subject of alarms, do our Innova's have the alarm enabled by default? If it's not then how do we enable it? I read through the manual and it had nothing about enabling the alarm. I did try pressing the red alarm button on the key but got nothing...
*Ginnova - what you did with your windows are way cool, is that something that I can just setup using the OEM remote control keys?
ok din yung suggestion ni darkmatter..ako naman ndi fully open, pero naka-open din yung window then sinasara ko once malamig na....input lang guys....hot air goes up so kapag nasa loob ka ng sasakyan at binukasan mo bintanaor aircon, cool air pushes hot air upwards kaya kung bukas ang window mo,lalabas yung hot air....natutunan ko lang sa skul at sa mechanical engr namin..hehehe
in my case, laging bilad ang sasakyan ko sa araw. habang naka park mode sa ofc nilalagyan ko ng konting siwang bintana sa driver side pati na rin sa likod... pag gagamitin ko na bukas bintana sa driver side then parehas no. 2 settings ng aircon both front & rear para maitaboy init palabas. in a few minutes lamig na.
Drive SAFELY
GOD Bless!
mga sirs sa akin naman ginagawa ko is binubuksan ko yung likod na pinto tapos bukas ng aircon pinasisingaw ko yung init na hangin sa likod para mas mabilis ang labas ng mainit na hangin.
