Page 143 of 775 FirstFirst ... 4393133139140141142143144145146147153193243 ... LastLast
Results 2,841 to 2,860 of 15487
    Oct 2011
    #2841
    Quote Originally Posted by BoyBawang View Post
    Yup once you disconnect the battery it will reset the ECU....
    Is the innova drive by wire or still cable?
    are there any other aftermarket air filters available and how much?
    TIA! ;)
    I see.... will there be an issue if the ECU is reset when the new battery is in placed? doon sa isang thread kasi namamatayan ng engine during idle and that happened when the battery was replaced.
    #2842
    AFAIK everything will be reset...Like the clock, MID,Radio settings etc..isolated case lang yun namatayan after mag replace ng batt...no worries changing batts ;)
    Feb 2011
    #2843
    Quote Originally Posted by ruelito View Post
    TYT OEM air filter * P1,089.00
    thanks sir!
    Mar 2011
    #2844
    I have already replaced my battery during my 30T km last Sept. 2011 at Toyota Dasmarinas. So far no re-setting was happened. 1SM maintenance-free battery cost P 3,821.00 with 24 months warranty. Almost the same kung outside casa magpapalit.
    Oct 2011
    #2845
    okay, thanks sir!
    Oct 2011
    #2846
    Additional queries regarding car batteries:
    1.) The 1SMF, 2SMF are the sizes of the car battery itself. How about models such as N50, N70, NS50 etc... in Motolite car batteries, are those code relates to battery sizes as well?
    2.) What is the recommended RC(recharging capacity) for an Innova?
    #2847
    Automotive batteries are classified according to group size 1smF etc,while N70, N50, Ns50 etc..The variants differ in ratings, warranty, number of plates and other features such as RC or Reserve Capacity...CA or Cranking Amperes.......AH or Ampere Hour.
    the bigger the better if you got lots of electrical load..hth ;)
    Apr 2005
    #2848
    Ang mga matting pala ng Innova hindi original Toyota. Just discovered this a while ago while cleaning the matting. Yung driver side matting ko may plastic sa gitna kung saan naka rest ang heel ng foot. While cleaning the matting may nag peel off na parang tape/sticker na itim. So I peeled it off and guess what was written under it...."FOR MERCEDES BENZ..Made in Germany". At least imported..
    Oct 2011
    #2849
    Thanks sir!
    Oct 2011
    #2850
    With regards to changing your car tire, do you see to it that it is replaced by same brand and model of that particular car tire? may effect ba if you use other car brand (mainly because it is cheaper)? granting that you will replaced it with same OEM specs and tire size.
    #2851
    No problem dapat assuming ok quality ng tire na binibili mo. If you cannot replace all 4 tires at the same time, do it in pairs (front OR rear pair).
    Take note of the load / speed rating and not only the specs.
    For example on Civics and Corollas - 205/55/R16 91V
    Yung 91V pertains to the load / speed rating. Take note of this sa original tire and buy something with a similar value.
    A little picture to help understand (credits to the owner):
    Tsaka ingat nalang sa shady brand - you get what you pay for - and nakakatakot masabugan sa highway.
    Also, may manufacture date yung mga tires. Be sure to get newly manufactured ones. Lumang goma = tumitigas; unsafe.
    Nakastamp ito sa tire:
    (picture c/o tirerack)
    In the example above:
    DOT U2LL LMLR 5107
    51 Manufactured in the 51st week of the year
    07 Manufactured in 2007
    Oct 2011
    #2852
    Thank you sir for reminding the load index and speed rating. I will take note of the manufacturing date. how about the type of tire thread? should i also consider this?
    #2853
    If you are replacing all 4, should be no problem.
    If you are replacing only a pair, *dapat* wala but you never know since iba na yung wear sa harap/likod. *May* cause premature wear on either set since magkaiba.
    Oct 2011
    #2854
    Quote Originally Posted by mda View Post
    Maybe same brand and model na lang i-replaced ko para walang problema. Btw, I check my tyre LI and SS, it is 94V. Nakasulat sa driver side door na 94S ang car tyre LI and SS. FYI.
    #2855
    94 is 670Kg on the tyre
    V is 240KPH max
    S is 180KPH max
    You should be well guardbanded...
    15.3K:jazzybass:
    Oct 2011
    #2856
    haha, city driving lang naman tayo. bihira na ung lumagpas ng 100kph. tska hangan 200kph lang ang speedometer.
    sinipag ako mag canvass ng mga presyo ng car tyre, mahal kasi ung existing tyre ko compared sa yokohama or good year.
    Oct 2011
    #2857
    Why is it that according to the manual that gasoline fuel filter should be change every 80,000km or 96 months whereas diesel powered engine fuel fitler does not need to be change periodically? what is the logic or wisdom behind this since both have the same purpose of filtering fuel.
    Apr 2005
    #2858
    Sa diesel 20k kms ang palit ng fuel filter.
    magkakano ba ang annual registration costs ng innova mga bosing? i just want to know how it compares w/ our fd 2.0 s/l. tnx
    Aug 2006
    #2860
    On D4d you can actually change fuel filter element as frequent as you would prefer since the element is just under 500 Pesos. I know few owners do every 5Kms PMS with D4d fuel filter element replacement. For VVTi the cost of Fuel filter assembly will cost more than 3000 pesos.
Toyota Innova Owners & Discussions [continued 3]
