where is the air intake located for Innova?
gud day ka innova bago lng po ako sa community.. needs help for my new innova E AT diesel po . first auto ko po kc ito at wala pa expirience need break in procedure..
TIA
I noticed earlier this morning that the carpet of the front seat passenger side is damp. Is it coming from the aircon? because I know that there's water drip in the rear wheel that is coming from the aircon. Any DIY for this? or should I take it to aircon repair shop? TIA.
Meron pong water drip sa front same sa rear. Simple lang po ang gawin mo sir, just remove the carpet, start ka sa baba ng glove compartment( start from the center passenger side). may water tube po doon makikita mo, natanggal na papunta sana sa labas.
May malikot atang paa na pasahero mo![]()
pa advice naman po. ano po tama routine check para sa innova. 1st tym lng po magkaunit eh heheheh..
TIA
Na experience ko to before sa middle east sa HILUX. Dinala ko sa casa then tried to repair by programing, nawala naman kaya lang after 4 hrs of driving bumalik uli. Ibinalik ko uli sa casa then re-programed uli. Tinanong ko sa SA dun kung di ba delikadong bigla na lang mag activate yung airbag while Im driving hindi naman daw ang risk lang daw eh may possibility na hindi mag activate incase of collision. After re-programming less than 2KM umilaw na uli kaya sabi nila palitan na lang ng spiral cable na nakakabit sa manibela. After replacement 2 yrs na ngaun di na ulit umilaw.
Thanks sa ibang nagreply. Iba yung ABS sa airbag system. It lit up two more times when I was driving towards home in the afternoon last friday. One thing I noticed though is that I did not hear the whirring sound just when i drove off. Used the vehicle yesterday and it was fine, heard the whirring sound when the vehicle picked up speed. It even functioned as described in the manual when i had to break hard around the afternoon when one of those st$&*& motorcycle drivers cut me off. I felt the brake pedal pulsated and heard the motor whirred. I hope it's okay now but will bring it to casa when it lits up once more.
ask ko lzmg po saan makaka bili nang tail light for my Innova V Yr. 2009 around south area ...
mga sir.. courious lng po. sa AT po kailn po dapat gamitin ung gear n 3-2-L..
thanks
During flood fordging put it in L. Limit your speed to as long as possible while maintain the rpm at around 2k.
During downhill like going down from baguio, its more safe to use the engine brake from D, shift down to 3-2-L to aid your brakes so that your brakes wont overheat.
During tranversing a stiff incline its best to limit yourself with low gears so you can opt to put your setting to 2 only so that your tranny will only play along the first two gears only
