Page 154 of 775 FirstFirst ... 54104144150151152153154155156157158164204254 ... LastLast
Results 3,061 to 3,080 of 15487
    Feb 2011
    #3061
    ako ganun din eh, naka bukas slight yung window ko dun sa part na sakop pa ng rain gutter, para yung hot air na nasa taas, may lalabasan na part. tapos sun shade at habang di pa umaalis, naka idle ride ko, bukas naman lahat ng bintana, after 1 or 2 mins, pagbukas AC sa harap, malamig na.
    Oct 2011
    #3062
    Thank you mga sirs sa tips on quick cooling when your ride is park outside in an open field with direct sunlight.
    Query regarding the car alarm system. The car alarm is automatically deactivated the moment the unlock button is press. I lock the car door using the key and not via lock button on the remote key and when I open it using the key (not the unlock remote button), the alarm sounded. Is this the correct setting or the way the alarm should function? since when I lock the door using the car key, the alarm is not activated in the first place and I was surprised that the alarm sounded the moment I opened the door.
    Apr 2012
    #3063
    Hello Po,
    Mayroon po kami na D4D na Innova at nagtataka lang po ako sa isang part ng makina na parang nagmomoist po ng langis... yun po yung nakabilog ng pula sa picture
    Normal po ba ito at ano po ba itong part na ito ng makina?... ano po silbi ng tube na ito galing sa makina papuntang intake?...
    Salamat po
    Jan 2012
    #3064
    normal lang naman po yan kasi nati trigger ang alarm pag hindi ka sa remote niya nag operate..
    Quote Originally Posted by jamart2005 View Post
    Hello Po,
    Salamat po
    last time na nagpa tune up ako nilinisan nila yan sa akin at nilagyan ng sealant para hindi na mag moist...
    Apr 2012
    #3065
    Mga sir good day po. Newbie po dito xa forums, ask ko lang sana kasi we wanted to buy 2nd hand Innova E 2008 model. Any points po on how to check the vehicle? And how do I know na hindi binaha ang sasakyan?
    Aug 2006
    #3066
    Quote Originally Posted by ejhorton View Post
    Bring with you a trusted mechanic, to inspect everything for you.
    Dec 2007
    #3067
    Quote Originally Posted by ericson21 View Post
    Similar practice for me. FYI, yung neighbor namin nabasagan ng windshield, CRV yung vehicle. According sa casa, this happened because the vehicle is parked in open area with all windows totally closed and the heat build-up probably caused the pressure to exceed the limitation of the windshield. If this explanation is true, it goes to show yung excellent seal ng honda crv. Anyway, as it applies to us, it makes sense to have the windows partially open when parked in open areas especially nowadays na sobrang init ang panahon.
    Oct 2011
    #3068
    parang hirap paniwalaan yan ah.
    BTT:
    For D4-D A/T, what is the gear when the speed reaches 80kph? is it aleady in the 3rd gear or just 2nd gear?
    Feb 2011
    #3069
    sa alarm ko sa G ko, nag a-activate lang ang alarm system ko pag ni lock ko using the remote (lock button) tapos pagka sinusian (not the unlock button) mag a-alarm yun. pero pagka susi ang pag lock (manual lock) at susi din pinang unlock, di mag aalarm kasi di nag trigger yung alarm sa pag lock pa lang.
    pagka kasi sa remote ni lock doors tapos sinusian, tutunog, considered as a force entry yun.
    Sep 2011
    #3070
    hello po. tanung ko lang po. d4d
    ok lang ba start walang hitter? may affect pu ba kay innova ? ( paki correct po kung hitter ba tawag dun, sa may dashboard yung logo na hinihintay mawala sign na pwede na istart)
    yung pinsan ko kasi kapag hiniram diretso start agad wala ng hinihintay.. e di ko naman mabawal nakakahiya. baka akala pinag dadamot ko pa.
    Tia
    Mar 2011
    #3071
    Tia
    sir sa pagkakaalam ko dapat po talaga antayin mawala yung umiilaw na heater(not sure if tama) and the airbag light bago mo istart.hindi ko po alam kung bakit pero yun po ang advise sa akin pag diesel daw po ang makina.para daw po maalagaan ang makina natin.
    Oct 2011
    #3072
    Sir, un na nga ang punto ko. hindi dapat mag alarm pag susi lang ang gamit. Pero nabanggit nung isang poster na it should alarm pa rin kahit susi lang ang ginamit. Baka sa settings issue ng alarm ito.
    Oct 2011
    #3073
    Tia
    ung ignition coil heater nawawala na agad un the moment you turn it on. hindi mo nga makikita o mapapansin un eh. ang matagal mawala ay ung ABS sa instrument panel.
    #3074
    Bro.,- hindi ignition coil heater iyan,- glowplug iyan for diesel engines.... Ito iyong nagpapainit ng combustion chambers/cylinders and the the engine block... The dashboard lamp usually turns-off once the cylinders reached the correct temperature or a pre-set heating time, usually 3-5 sec....
    Wala yatang glowplug sa mga CRDi engines....
    15.5K:boxing1:
    Oct 2011
    #3075
    ay, glowplug pala tawag doon sir. ito ang symbol:
    walang glowplug sa crdi? hindi pa ba crdi ung d4-d?
    Sep 2011
    #3076
    thank you sir sa mga advise ..
    nakakahiya naman bawalin kasi kapag umaalis naman ako. iniingatan niya si innova. hindi naman abuso gumamit napansin ko lang sa pag start
    ang ginagawa ko nalang kapag hinihiram sinususi ko na. para iistart nalang niya tapos na yung mga umilaw
    hehe
    Sep 2011
    #3077
    ..........yan ito nga po.. merun sir,, glow plug pala tawag diyan..
    Oct 2011
    #3078
    cguro sir nasanay na siya sa gasoline engine kaya start na agad. ung mga gumagamit ng sasakyan na diesel lalo na mga old school diesel engine, mapapansin mo na it takes around 2-3 sec. para mawala ung glowplug na symbol when you turn the engine on.
    Sep 2011
    #3079
    nagamit din naman sana yung advie ko. may glow plug din naman yun . hinihintay naman niya yun
    ewan ko dito ngayun si innova bakit start agad baka kasi masira agad kapag ganun palagi.aminado ko hindi naman kasing tibay ang d4d kumpara sa 4d56 design talaga sa durugan ,
    mabait naman siya actually siya katiwala ko sa lahat ng oto kasi. siya nag dadala palagi sa mekaniko,. o siya nag memekaniko minsan, napanin ko lang talaga kapag inistart si innova
    Aug 2005
    #3080
    4 nights, 4 days travel using the innova to Pagudpod, traveled almost 1,400 km round trip. Plenty of stops along the way.
    left laguna with gas tank at 3/4 full now it is a bit more than half, but spent 5,600 petot gas along the way.
    carwash badly needed and almost ready for the 5,000 km change oil.
Toyota Innova Owners & Discussions [continued 3]
