Page 602 of 662 FirstFirst ... 502552592598599600601602603604605606612652 ... LastLast
Results 12,021 to 12,040 of 13229
    #12021
    Quote Originally Posted by ajOT View Post
    Sir what is your Innova engine? Gas (VVTi)-1SMF or Diesel (D4D)-2SMF/3SMF
    Regarding on the battery, id choose Motolite, mas pangmatagalan and once click START....
    sir mine is Gas vvti so 1smf...by the way what is smf? what differs 1 smf with 2/3smf?
    seen on the motolite website na motolite gold (21months warranty) maganda ba to?
    btw, my battery is stock pa na purchased my innova in Dec. 2008, hindi ba my battery should last longer than this? hindi kaya na-drain sya due to grounded sya? should I go to Toyota casa for this or diretso sa Battery Shops na lang???
    Jul 2006
    #12022
    Quote Originally Posted by likot View Post
    Kuskusin mo muna ng ice, kahit tube ice para lumamig yung sticker tapos tsaka mo tanggalin habang pinapalamig mo siya nung ice. Effective to...
    Quote Originally Posted by annika View Post
    in getting my conduction i use hot water. i deep a cotton balls on the hot water, slowly i peel the sticker. and part by part i wipe the sticker with the hot cotton balls and peel again until everything is taken. it works for me.
    hair blower gamitin nyo
    Jul 2006
    #12023
    Quote Originally Posted by wolfhound View Post
    I beg to differ.. In my case, i noticed that it consumes fuel more if the rear ac is turned on. Anyway, i set my front ac to the highest temperature and lowest fan speed and the coolness is enough for me even on noon time.
    wala pong difference sa fuel consumption. kasi isa lang naman compressor. If you don't turn on the rear AC mas matagal mag automatic mas mahihirapan pa nga engine baka mas tumaas pa gas consumption. the rear AC if turn on ang madadagdag lang is Fan.
    Jan 2010
    #12024
    Quote Originally Posted by bencel View Post
    what do you mean matagal mag automatic? You're the one controlling the fan speed and temp of the ac right?
    So is it advisable to turn ON rear ac eventhough you're driving alone?
    Aug 2006
    #12025
    It would feel enough for you getting the cool breeze using front AC only when driving alone but certainly half of your cabin is hot. When Cool air meets Hot air means it would produce cabin condensation.
    Aside from the rear blower, there's also the rear AC condenser.
    Benefits when using dual aircon:
    1. Eliminates cabin condensation thus eliminates molds and bacteria build up on the upholstery and thus eliminates foul odor.
    2. Reduces stress on the front AC condenser.
    3. Reduces stress on the AC compressor and to the engine.
    4. AC thermostat is almost at nominal most of the time.
    For me regarding FC whether it would consume more or consume less fuel, I would stick to running dual AC all the time. My AC is already more then 3 year old and had never been gone to to any casa AC PMS and still running fine. I usually run on the lowest thermostat setting and 2nd fan speed for front and 1st fan speed for the rear.
    May 2005
    #12026
    Quote Originally Posted by attyallanlatras View Post
    The 1, 2, or 3 SMF is an indication of power ratings/capacity of the battery. Gas engines don't need much power when starting as compared to the diesel. Diesel will always need a min. of 2SMF to operate properly.
    I don't know about the quality of Motolite before but I already have two Motolite EXCEL (green) fail on me. The Truck Master 2SM I'm using seem to need constant topping up of water compared to the MF battery it replaced. But Motolite is allegedly made here in the Philippines, so buy Filipino.
    Jan 2010
    #12027
    Quote Originally Posted by Mile2 View Post
    I dont understand some of the technicalities like cabin condesation, number 2 and 3 but I got your point. I will definitely follow your advise. Just want to be clear by lowest thermostat setting, did you mean 28 Celsius?
    I noticed my ave. fuel consumption display in the info display shows only 6.3 km/L. Is this normal? I haven't manually computed it. I own an A/T G variant by the way.
    Thank you for your reply!
    Aug 2006
    #12028
    Cabin condensation means your cabin produces moist or tiny mist of water from the cool air and hot air, plus additional from your breathe and body heat.
    Minsan nakakasakay tayo ng taxi na amoy basahan at mabantot kasi mahina ang aircon, yung singaw ng katawan ng tao plus mahinang aircon dyan nakakaroon ng cabin condesation na halos di mo napapansin na may malilit na basa sa mga uphosltery at pag nagatagal nakakaroon na ng amag. Yung amag ang nagbibigay ng mabantot na amoy.
    My AC control panel was still analog and dial type, so I'm not sure about 2009-2010 model having digital control panel.
    Jan 2010
    #12029
    But are you saying that you set your thermostat to the coolest level?
    Aug 2006
    #12030
    No, the older model have rotary dial control which has low cool to high cool.
    High cool is the coolest.
    Jun 2006
    #12031
    i set mine at 23c during daytime and 25c at night. sipunin ako eh. I always set the fan at number 2 position, ayoko ng auto fan at palagi 1/2 lang takbo pag malamig na.
    May 2005
    #12032
    Update on our meeting :
    Met with a senior executive of TMP and her group manager at 10am today. Meeting was very cordial as they are very much willing to listen. Showed them the posts here in FCP and in Tsikot and have agreed that they will seriously look into it. They will take this up with senior management so positive action will be planned and executed.
    Couple of suggestions that I made which they will seriously consider :
    1. Setting up of a quick action center or hotline to address the D4D problem
    a. I will be forwarding to them the numbers of those who are affected and they should get in touch with these owners for possible remedies
    b. Instead of the dealership calling, it will be TMP customer service who will be dedicated to solve the issues
    2. Extension of warranty for those beyond three years (just for the supply pump) until they can say that the D4d problem is close to zero
    3. They will generate the database from their dealerships of owners who have complained and possibly still awaiting actions
    4. Possible Focus Group Discussion with concerned owners and TMP to address common issues
    5. They will monitor both FCP and tsikot for other concerns that I have not raised. (btw , I also included the issue on the Innova gas tank)
    Meeting adjourned at 1120am
    I will keep you posted as they have given me numbers if nothing has been done.
    Thank you for your support.
    Aug 2006
    #12033
    Thank you very much Bong (Fireblade)
    Dec 2009
    #12034
    Quote Originally Posted by fireblade View Post
    No difference in the consumption at all. The ac is strained more if you only use the front blower as it takes more effort to cool the cabin. Best to turn on both fans to manage your cabin.
    Thanks for the info fireblade. :massbounce:
    Dec 2009
    #12035
    Thanks Mile2 :barmy: Very useful informaion po. Kaya pala may times na amoy kulob whenever i turn on the rear AC. I usually turn on lang po kasi yung front AC on its 2nd fan speed pag mainit at kasi bihira lang talaga sakyan yung 2nd and 3rd row seats ng innova namin. Thanks for the info.
    Belated Happy Valentines pala sa lahat! :doclove:
    #12036
    I think, sir, you may would like to go to a CASA (if under waranty) or to any reputable shop, at first, to check on your electrical system of your Innova; since as you mentioned that it is grounded....
    if im not mistaken, stock-dealer battery should at least around 2 years; on your case at least up to 12/2010....
    #12037
    KUDOS to you
    by the way, what is FCP?
    May 2005
    #12038
    KUDOS to you
    It is Fortuner Club Philippines sir.
    #12039
    oh I see.
    The meeting earlier, was to talk about D4D Problems of all models of Toyota (ex. Innova, Foutner, etc.), am I right?
    Good Luck on your future plans.
    May 2005
    #12040
    oh I see.
    The meeting earlier, was to talk about D4D Problems of all models of Toyota (ex. Innova, Fortuner, etc.), am I right?
    Yes and I included the Innova gas tank woes. I even showed to them the thread with pics of Mile2 for better appreciation.
Toyota Innova Owners & Discussions [ARCHIVED]
