Page 592 of 662 FirstFirst ... 492542582588589590591592593594595596602642 ... LastLast
Results 11,821 to 11,840 of 13229
    Jan 2010
    #11821
    Quote Originally Posted by Ventoy View Post
    Anybody can give some Feedback on the new INNOVA SPORT RUNNER
    Binigyan ako ng option sa agent ko na to choose between SR and variant G eventhough i already ordered the G but still I decided to buy variant G kasi maganda na ang interior and u can accessorize it to become SR sa exterior
    Jan 2010
    #11822
    gud pm po... first ive been watching a lot this forum even before ko pa makuha ang innova e ko, and i can say that this forum has been a HUGE help for me at i bet LOTS and LOTS of people, kayat more power!!! now like someone posted here i while ago i came from a lancer, we have to lancers in fact, a 97 and 2000 model, now ask ko lang po, kung ilan and idle nung nakuha nyo ung innova nyo guys... ?kc ung sa akin nasa 1.5, sa gitna ng 1000 and 2000 rpm, is this normal? i mean do i need to lower it a little base on a innova profile kc ung lancer ko naman nasa ALMOST 1000 rpms lang kc para matipid, by the way kakukuha ko lang ng innova ko last monday so theres a lot to be learned... and another thing pala, why is it na feel ko yung vibration sa shift stick ko? kc sa lahat ng nadrive ko ito lang ung feel na feel ko ang vibration ng makina sa shift stick, lalu na pag first gear, nakikita ko nagshe shake talaga sya literally, i have an innova E gas M/T. thanks in advance.
    Aug 2006
    #11823
    Quote Originally Posted by madcat820 View Post
    Sir, naninibago ka lang coming from sedan, ganyan din ako noong una.
    Sedan has cable connected transmission shifter kaya di mo feel ang vibration ng makina, while the Innova has the shifter literally on top of the transmission and the tramission is literally bolted on the engine kaya you will feel the engine vibration from the transmission shifter.
    Anything you noted that is not normal to your expectation, just tell it to your SA in the next PMS so that they could explain them to you in details.
    Enjoy your ride and safe driving
    Mar 2007
    #11824
    i asked almost the same question yesterday or last wed i think, but mine is around 800-900 rpm. also feel the vibration of the stick..
    saan toyota ka kumaha? i got mine last tue at toyota makati
    Jan 2010
    #11825
    Quote Originally Posted by Mile2 View Post
    ahhh... many thanks sa explanation now i know.... maraming salamat po
    Jan 2010
    #11826
    Quote Originally Posted by antz-z View Post
    hehehe, kala ko ako lang... btw, nagkamali pala ako ng read 900 to 1000 rpms po pala ako,
    sa alabang ako nakakuha. buti umabot pako monday ko nakuha unit ko, tamang tama sabi ng SA kasi by tuesday kasi yung LTO, CHATTEL, INSURANCE etc is ndi na raw free. ewan ko sa kanila pero ive heard sa ibang branch 1 month daw ung promo nila..
    Mar 2007
    #11827
    wow, meaning yung lto, chattel, etc mo is free?? you're one lucky dude!!
    btw, question po ulit sa mga gurus. what's the best way to compute your fuel consumption? i don't think meron ang innova ng km/l gauge..
    Aug 2006
    #11828
    Innova G and V has the KM/li (average) on the MID console (Multi Information Display).
    You can actually do manual computation by having a full tank and noting the Odometer reading, then on your second full tank compute the difference on the odometer reading and divide that on the number of refilled liters.
    #11829
    there might be a factory defect on the transmission shifter. My Innova is already 5 years old at 70TKM. at 40Tkm total run, i can hear a grinding sounds sa stick at 5th gear at a speed of 50km/hr. Pag tinulak ko konti pataas yung stick, nawawala yung grinding sound. Hanggang sa lumala na, ngayon kahit naka primera, nagkakaroon na din ng grinding sounds, dati sa 5th gear lang.
    sent my Inno to my trusted mechanic, ang result, sira na daw shifter bushing. Sabi ko ba't parang ang bilis naman. Some cars, at 10 years old or older, ni walang problema sa shifter bushings, etc.
    Have you ever experinced this on your Innova's? (manual po).
    Aug 2006
    #11830
    Quote Originally Posted by bongliza View Post
    I got more than the Kms covered than yours but never experience any grinding sounds so far. What others are saying was the shifter vibration due to engine vibration.
    Jun 2008
    #11831
    I experienced this, I hear a very slight hissing sound when I rest my hand on top of the shifter when the transmission is in gear. But when I lift my hand off the shifter, it's gone.
    #11832
    quick question mga sirs, pag nagpalit ba ako ng HU mawawala un remote function nun SW remote? innova G un ride mga sirs...
    Mar 2007
    #11833
    kailangan pa ba i-break-in ang innova pagkabili? i think i didn't see anything about this in the manual... also, pag start, do you wait for the temp to normalize or go na agad.. sa vios, manual says after 10 seconds, pwede na paandarin..
    Jan 2010
    #11834
    well, as for me meron as manual ko, at page 218,
    as for temp normalize question, meron lang ako napansin sa innova ko, pag ka start ko specially ung first start ignition of the day, parang ang lakas ng hinga ng makina, i mean para naka tungtong ung paa mo sa gas even not, parang its doing it by itself, it happens the first few seconds, I think (sa akin lang ewan ko if it is true idea lang) i think its warming itself, kc after ilang second dahan dahan na syang hihina ung hinga, so i assume yes pwede na agad as long as na perform na nya lahat ng test (na sa heads up display) like ABS and airbag check etc.., i think pwede na agad pa aandarin.
    hope it helps.
    #11835
    I do believe, that, the answer is YES or even could be that it is a must, in order for the owner to check on the performance of the engine on the vehicle purchased..... thats why PMS is there; for Toyota to check on things that needs topmost concern on the vehicle(s) breakin period
    if I am not mistaken, I do believe that all motorized vehicle needs to undergo a breakin period when a vehicle is newly purchased and when vehicle has been overhauled.....
    Jan 2010
    #11836
    newbie here... got mine yesterday black g vvti...
    ask ko lang kung ok sa inyo yung faux wood trimming? di ba parang
    cheap ang dating na parang nag papa ka camry? mas ok sana kung gray trim na lang kesa faux wood... can i peel it off?
    thanks....
    Apr 2008
    #11837
    Tama, yung sa akin din, parang diesel kung magvibrate ang kambyo. Good thing is hanggang doon lang kasi overall, tahimik at walang vibration sa dashboard. Siguro ina-absorbed na ng kambyo ang lahat ng nginig, "take one for the team" hehe.
    800 rpm idle, 900rpm kung may aircon, even as low as 700rpm pag-nagpapalit ng gear (diko alam kung bakit) naparang mamamatay hehe. Wag muna pababain yung idling, 'di kakayanin, baka masira pa yan.
    hope this helps.
    Problemang legal?----------------> http://panyero.com/
    Apr 2008
    #11838
    Quote Originally Posted by Capsaul View Post
    thanks....
    Haha, oo nga, may fettish ang toyota sa fake wood triming. Lahat ng top of the line may ganyan. Kala siguro nila class tignan, di nila alam mas nagiging cheap. Pede mo tanggalin, pero baka mawala warranties mo.
    Hayaan mo masasanay ka rin haha. Mas malala ang fake wood triming ngayon, mas matingkad, 'di tulad noong lumang G medyo dark hehe
    Problemang Legal---------------> http://panyero.com/
    #11839
    Quote Originally Posted by Robenson View Post
    same here, my shift knob does vibrate and may sound at some point of time; i think this is usually normal for a diesel engine vehicle....
    #11840
    thanks....
    if I am not mistaken, since G variant is one of the top line of Innova; it really has a wood trimming and even could be a wooden dashboard to have it's class look; to be something different amongst other variant of Innova....
    if you peel it off; it might leave some mark and might not look good on your Innova..... you can try to live with it and no worry I do believe at some point of time, you'll get used to it...
Toyota Innova Owners & Discussions [ARCHIVED]
