Page 652 of 662 FirstFirst ... 552602642648649650651652653654655656 ... LastLast
Results 13,021 to 13,040 of 13229
    Jun 2010
    #13021
    Quote Originally Posted by Ginnova View Post
    That will be my next project.....
    Here's the detailed procedure in removing the dashboard so can clean the aircon ducts/vents.
    http://tsikot.yehey.com/forums/showt...79#post1505879
    Thank you ginnova for that contribution to all innova owners.
    Jun 2010
    #13022
    Quote Originally Posted by erwinjason76 View Post
    hi fellow innova lovers!
    hope you could help me with these questions:
    1. how long is the break-in period? what is the usual mileage reading, so u can safely say that your car is done with the break-in pd.? first 1000km speeds of 60 to 80km avoid full throttle acceleration..
    1. what is the max driving speed during the break-in period? lets say you're done with the first PMS. TIA!
    after 1000km PMS with Fully synthetic oil. speeds of 80 to 110km. Avoid hard revving on stop and go traffic, less pollution saves the environment.
    Drive safely
    Nov 2007
    #13023
    Good day guys, I would like to share my current experience with Toyota Makati PMS (30,000) done May 28, 2010.
    Before I had my PMS my FC was 10Km/L. After the PMS it went down to 8km/L and for the first time I suffered engine stalling twice.
    I called Toyota Makati and this was the explanation:
    Stalling: They said the culprit was the clutch. According to them this is prevalent with Manual Transmissions. Mine is a 2007 E D4D Manual. I can't see the connection and if this argument correct then this should not be happening since my innova is practically new. Can anyone of you guys share your take on this.
    Change in FC from 10 km/l to 8km/l: I made the complaint 2 weeks ago and the said this was normal. They said I should be happy considering others have an FC of 7km/l. I almost slammed the phone when I heard the excuse.
    Anyways , this morning I checked the dipstick for the first time since the PMS, and lo and behold, to my surprise the oil level is 1/4 inch above the max level. Approximately that translates to about 500ml of excess oil. I did a DYI and removed the excess. There was a dramatic change in engine response. I am also certain this is the reason for the lower FC.
    And to think that the reason I am going to the CASA for my periodic maintenance is for peace of mind. This mistakes should not be happening.
    I think I solved the FC problem but now the engine is stalling, I just hope there is no permanent damage done by the over filling of oil.
    Any comment on my experience?
    Oct 2009
    #13024
    Quote Originally Posted by shibby75 View Post
    ganyan nangyari sakin nung nalagyan ng wax, para matanggal nilagyan ko ng gaas at pinunasan ko ng tuyo na basahan.
    Linisin mo ng maigi then Apply (Rain Fly ng ELEVO). Ganda nito lalo na kapag umuulan lalo na kung malakas ulan. ndi madilim sa paningin.
    #13025
    Quote Originally Posted by Blackshark1999 View Post
    7 liters lang ang standard ng langis natin? mahirap bang imemorize yun hahahaha... sir baka yung janitor ang nagpalit ng langis nyo hahaha... mabuti hindi sosa yung inilagay hehehehe...
    #13026
    Quote Originally Posted by bumblebok View Post
    bossing47 thank you.. what particular shell oil do you use in your innovaD4d? helix diesel or Helix ultra?
    about sa HID. marami naman brands this days. my first HID is a Philips XenonHID kit made in germany bought from Singapore way back 2006, put them in my civic. until today OK pa rin. hindi nag deteriorate or nag fog ang headlights...last year i bought a philips xenonHIDkit made in taiwan from LA car accesories located Yakal St.San Antonio Village Makati. i put them in my frontier..Ok din no prob. stay away from XENON WORX brand they dont last long..
    copy sir"stay away from xenon works..."
    regarding sa oil... ordinary oil lang nilalagay ko sir... kaya lang i see to it na i changed it regularly... every 5k odo reading...
    Aug 2009
    #13027
    good day, ask lang po, if paano ba tanggalin ang emblem na letter E sa likod nag innova ko gusto ko kasi malinis ang likod sa INNOVA ko. THANKS
    Nov 2007
    #13028
    Quote Originally Posted by annika View Post
    Use sinulid or thin nylon string, gently insert sunulid (for sewing) or nylon string between emblem and body. Pull parallel until the emblem gives. Then use gas to remove remaining adhesive.
    Aug 2006
    #13029
    *Blackshark1999
    If I were you since malapit na matapos warranty mo, ilaban mo na yan na palitan nila yung supply pump. Kulitin mo ng kulitin kahit kalampagin mo na pati mga CRO at top official ng dealer mo.
    Aug 2009
    #13030
    *blackshark1999
    thanks for the reply. yong paint sa Innova na merong emblem walang shadow. this november lang ang unit ko. people from casa volunteer to take it pero hindi ako at peace kng cla kukuha baka ma gasgas ang pintor.
    May 2007
    #13031
    Hi guys, hope you can give your inputs:
    1. What car freshener do you guys use? ako kasi gumagamit lang ako ng dehumidifier. dati i used to put california scents.
    2. How do you figure out kung normal ba lahat ng mga sounds na nadidinig mo sa kotse mo? i have a second hand innova kasi eh. i dont know kung normal ba nag start ka ng engine in the morning, talaga bang malakas ang tunog compared pag mainit na yung makina, etc..
    thanks po.
    Aug 2006
    #13032
    Yesterday I had my new set of clutch installed at Caltex Fairview, wow parang bago na ulit ang hatak ng car ko
    All original Toyota Parts from Gant auto supply.
    Clutch cover
    Clutch disc
    release bearing
    P 7,000.00
    Transmission pull down _ (Caltex)
    P1,200.00 (3 Hours)
    Total cost P8,200.00
    Manipis na yung clutch pero di pa umaabot sa rivet kaya walang score mark ang flywheel ko at makinis pa rin..just in time na nagpalit ako otherwise baka nag-pa machine shop pa ko ng flywheel.
    Bearing may alog na rin kaya pinalitan na rin.
    Clutch cover malalim na yung score mark sa fingers due to release bearing contact which is the usual reason of replacement, hard clutch symptom.
    Generally, maayos magtrabaho yung mechanics ng Caltex Fairview at kumpleto sa gamit kaya mabilis ang gawa nila pero they counter check each other work kaya pati mga turnilyo ibinalik nila ng maayos at walang puwersahan. Pati ako nakiki-mechanic sa ilalim ng lifter
    Versus Casa quote:
    Clutch cover
    Clutch disc
    release bearing
    P 9,600.00
    P5,000.00 (allow 3-5 working days)
    Total Toyota dealer cost: P14,600.00
    Jun 2010
    #13033
    Quote Originally Posted by bossing47 View Post
    thanx sa advice.fully synthetic gamit ko kasi 3 to 5 days nka park lng ang mga kotse. and mas matipid sa fuel pag fully synthetic..
    And share ko lng po. today nag change ako ng 4set of tires. ang original tires ng innova is Yokohama Aspec 205/65r15.
    Nag change ako to Falken ziex ze912 same lng din. I notice mas less ang noise on cement roads and very quiet on the asphalt compare sa yokohama.
    driving on wet roads mas secure siya pag nag brake unlike sa yokohama. tomorow i plan to fill it nitrogen. and see pag may effect fuel consumption.
    Dec 2009
    #13034
    Quote Originally Posted by hops View Post
    thanks po.
    1. Car freshener? It all depends on your preference on what scent and brand. Better po kung organic freshener. Maganda naman ang california scent brand.
    2. Normal po ung loud engine sound especially on the first engine start in the morning. Yung 2010 model vvti innova ko ay umaabot ng 2,000 rpm pero bumababa din to normal 1,000 rpm after 30 secs to a minute.
    May 2009
    #13035
    Thansk Shibby,
    Ginawa ko last Saturday, pag umluan sana okay na. How many time mo ginawa?
    Oct 2009
    #13036
    Quote Originally Posted by Mile2 View Post
    Clutch cover
    Clutch disc
    release bearing
    P 7,000.00
    P1,200.00 (3 Hours)
    Versus Casa quote:
    Clutch cover
    Clutch disc
    release bearing
    P 9,600.00
    cheers to that Mile2. How about in Makati or manila area? Do you know someone or casa na magaling sa mga ganyan? Im along zobel roxas area.
    ciao!
    #13037
    Clutch cover
    Clutch disc
    release bearing
    P 7,000.00
    P1,200.00 (3 Hours)
    Versus Casa quote:
    Clutch cover
    Clutch disc
    release bearing
    P 9,600.00
    Mile2, ano nakita mo symptoms at nag-decide ka na pa pull down ang transmission. Ilan na Odometer reading innova mo. Pinapull down ko rin yung tranny ko last month sa casa and yes it took them 5 days to complete the job but i was able to get a service vehicle from them kasi warranty claim naman. May squeaking sound kasi ako naririnig kapag partially depressed yung clutch pedal lalo sa umaga pag malamig pa makina.SA told me OK pa daw disk at bearing. may in-align
    lang daw sa cover. Sana pinuntahan ko pala yung innova ko ng pull down yung tranny.
    Jan 2010
    #13038
    good day to all, I am a toyota innova owner and long been lurker on this site I just ant to share a news about toyota engines....
    Toyota warns about faulty engines
    Page last updated at 07:48 GMT, Thursday, 1 July 2010 08:48 UK
    Japanese car giant Toyota has warned about potential faults with the engines of about 270,000 cars it has sold worldwide, including the luxury Lexus.
    It said the engines could stall while being driven, but affected vehicles have not yet been recalled.
    This is the latest problem to hit the carmaker, which has recalled more than 10 million vehicles globally since last September.
    Fresh figures show Toyota's June sales were up 26.7% on a year ago.
    Worries about further reputational damage and the costs of a potential recall pushed Toyota shares down by more than 2% on Thursday.
    http://news.bbc.co.uk/2/hi/business/10472627.stm
    #13039
    inaantay ko na nga ding mapudpod yung mga goma ko... 2 1/2 years na din kasi unit ko pero mukhang matagal pa hehehe makapal pa.. alaga kasi sa balance, tire rotation saka align...
    ganda ng brand na nakuha nyo, balak ko continental comfort, saka maganda siguro laparan ko ng konti (215/65/15) para medyo makapit pagliko saka, hindi masyado ramdam yung maliliit na lubak... though mas magaan sprint sa stock na sukat...
    tama kayo mas maganda brake(kapit) ng ibang brand na goma kesa yang OEM na aspec... lahat ng goma nila madudulas... innova, fortuner, hilux...
    meron nga akong nakitang binebenta na willing swap sa oem na mags ng innova... 17" sukat nya... medyo nagdadalawang isip ako hehehehe... bahala na hahahaha...
    Apr 2010
    #13040
    Quote Originally Posted by Capsaul View Post
    for me first 1000km ang break-n period... during this time max speed is 100kph.
    some say di na kailangan break in period dahil well seated na daw ang pistons before pa ilabas ng casa..
    Drive safely
    thanks sir capsaul & bumblelok!
Toyota Innova Owners & Discussions [ARCHIVED]
