Page 558 of 662 FirstFirst ... 458508548554555556557558559560561562568608658 ... LastLast
Results 11,141 to 11,160 of 13229
    May 2007
    #11141
    Quote Originally Posted by paker View Post
    Question ppwede po ba 235/40/18's on innova? or which would be better? thanks
    masyado na po matagtag ang size na yan... IMO, prone to tire blowout na rin po yan dahil sobrang nipis na po ng 40 for the Innova... ideal would be 215/55/17.
    if you have any other queries regarding the Innova... i suggest that you post it in the Innova Owner's thread... we're more than willing to help you.
    May 2007
    #11142
    Quote Originally Posted by innoBOB[09JmtG] View Post
    just upping my old post. thanks!
    i suggest that you have it underwashed also to avoid possible corrosion of your underchassis.
  3. #11143
    Quote Originally Posted by liv View Post
    thanks. that's the only thing I did, with running water via hose, (nawasa water)
    sadly, gusgusin na innova namen ngayon, due to those storms coming, at nabaklas pa ung right foglamp ko. huhu
    Nov 2006
    #11144
    hehe may thread na din pala na ganito sorry first time ko dito..
    *sir liv ok napo nakakuha ako 235/50/18's medyo matagtag and medyo ramdam mo ung gulong, but the steering is still the same
    #11145
    Quote Originally Posted by roberto_minosa View Post
    Yung sa VVT-i namin plastic moulding. Meron talagang custom-fit para sa mga bumper. Yung sa Fortuner iba din yung dimensions kasi mas malaki yung bumper nun. Pero pwede DIY, gagamitin yung 3M anti-slip tape.
    ah ok, ano ba mas maganda. yung plastic moulding katulad sa inyo or yung sa 3M? tignan ko din yung sa 3M.
    thanks..
    Aug 2006
    #11146
    Quote Originally Posted by alnr View Post
    thanks..
    Merong 3M anti slip tape sa ACE or HandyMan, it has different colors to choose from and it also has the transparent variant. Yung sobra puede mong lagay as door step sills sa front and 2nd row para di rin nagagasgas pag may sumasakay at sumasampa.
    Pag plastic moulding, custom fit yan and usually sa mga accessories store ka makakabili like in Banawe.
    Mas maganda yung 3M, pag naluma na puede mong palitan uli. Eto yung 3M tape na nilalagay sa mga bathroom floors para di madulas.
    #11147
    Quote Originally Posted by Mile2 View Post
    Every after 5K pa rin ang PMS.
    To simplify:
    10K PMS - change oil to fully synthetic plus change oil filter.
    15K PMS - change oil filter plus 1 liter oil only.
    20K PMS - change oil to fully synthetic plus change oil filter.
    25K PMS - change oil filter plus 1 liter oil only.
    30K PMS - change oil to fully synthetic plus change oil filter.
    35K PMS - change oil filter plus 1 liter oil only.
    40K PMS - change oil to fully synthetic plus change oil filter.
    - change transmission oil, change differential oil, change radiator
    coolant, change brake/clutch fluid, change power steering fluid.
    Pinakamabigat sa bayarin yung every 40K PMS dahil palit lahat ng fluids plus brake pads if needed.
    meron na ba nakapag 80K km check dito? magkano inabot? ano-ano ginawa? gas a/t ang sa akin. tia.
    #11148
    had 1k in toyota cubao, 2.2K roughly, bilis lang din, naglunch lang kami, pagbalik tapos na,
    Kelan po kayo nagpa service? Napa appointment ba kayo or walk in lang?
    May nkaita ako kangina sa ACE hardware, Php700? Ganun b talaga price yun? Pero malaking roll and I think sobra sobra kung sa 4 doors and rear tailgate lang ng Innova gagamitin.
    Also had a chance to check my fuel consumption and I'm running 6.8km/liter. My ODO reading is 758 KM and on a tipid mode driving style. Medyo malakas nga sya, sana mag improve pa pagnatapos na break in period.
    #11149
    Greetings Innova peeps!
    I'm moving your thread up as a sticky
    More than 11,000 posts and over a million views here alone!
    #11150
    ok thanks again sir! appreciate your help :D
    more power to innova peeps here :D
    Aug 2006
    #11151
    Quote Originally Posted by habibs View Post
    It should be more or less the same PMS jobs with 40K PMS.
    and I will also add, fuel filter replacement is also due at 40K PMS.
    #11152
    Thanks for making our thread a sticky .
    Will surely help a lot of Innova owners and soon to be owners of Innova.
    More power to all Innova peeps....
    Aug 2005
    #11153
    gandang araw mga Innova owner's and fellow tsikoteer
    Patulong naman po, ask ko lang if anyone from you encountered na may lumalabas na parang small thermos na may parang drop of oil sa panel board,anu po ba ibig sabihin nun and pag iinistart ang oto bigla nlang namamatay may car is innova-vti manual.transmission marmaing salamat po.
    Sep 2009
    #11154
    AUV of the year (2009Auto Focus) ang Isuzu Crosswind.
    Just ordered Toyota Innova E vvti
    Kanya-kanya lang naman talaga ng taste yan e.
    Jun 2008
    #11155
    AUV of the last century?
    Peace...
    #11156
    Quote Originally Posted by matrixxx_90210 View Post
    low oil pressure. check nyo sir kung meron enough oil yung makina nyo. how old is your innova?
    Aug 2005
    #11157
    sir my innova is 2006 J vvt-i manual, inin-form lang sa akin ni mrs. kasi hirap daw magstart and pag nagstart naman ay namamatay agad,ang huli lang na ginawa sa oto ay underwash from then nagloko na hirap na magstart,pi na check sa mekaniko diskargado ang battery kinargahan then inistart tapos ganun pa rin. Pls help naman po, thanks in advance to my fellow tsikoteer
    Aug 2006
    #11158
    Bro, patignan mo sa owner's manual page 9 nandoon yung mga symbols ng instrument panel.
    Pero base sa description mo "Low engine oil pressure warning light"
    Na-check ba ng mekaniko yung oil? baka kulang na? pacheck mo yung garage nyo kung may oil leak sa floor.
    Kung okay ang oil, check the wires baka kinagat ng daga.
    Check also air filter and MAF sensor.
    How to clean VVTi MAF sensor (almost the same with Innova)
    http://toyotaownersclub.com/forums/i...howtopic=63346
    May 2005
    #11159
    ^boss mile2 napapansin ko to sa signature nyo lagi "Royal Purple 10w30, racing air filter. " ano po yung racing filter na yun? sorry di ko makita sa buong thread nasa malayo na ata, tsaka yung RP nyo fully synthetic na din? out of warranty na ba unit nyo? ty
    Aug 2006
    #11160
    Warranty pa unit ko, pero sa labas na ako nagpapa oil change, sa SpeedyFix or Shell station. Bumibili lang ako ng fully synthetic oil Royal Purple.
Toyota Innova Owners & Discussions [ARCHIVED]
