Page 568 of 662 FirstFirst ... 468518558564565566567568569570571572578618 ... LastLast
Results 11,341 to 11,360 of 13229
    #11341
    Quote Originally Posted by jojitb View Post
    I am planning to get a new vehicle. originally altis o civic ang choices ko kaso si kumander gusto daw innova. sabi ko meron na kami revo pero gusto din daw niya innova.
    Iyung innova gas-E variant lang ang kasya sa budget ko, kawawa ba talaga ang E in terms of features sa G? 100K din yata ang difference eh.
    If you need:
    - beige interior
    - backing up sensor
    - side moulding
    - black/metallic gray body paint option
    - airbag for front passenger
    - alarm
    - multi-information display
    - crome (door handle, side mirror)
    - 6 speakers
    Go for G.
    May 2005
    #11342
    ATTN innova club members:
    message from Mam Olive from YM...
    olive_medel: nagkaka problema po ako logging in sa tsikot... may login bug daw po... baka po pwedeng paki post naman sa Innova Club thread na d ako makapag login kaya d ko masagot mga posts ng members.
    olive_medel: nakita ko nga po kaya ym kita... paki post na lang po na tuloy ung EB sa Nov. 28... log in na lang muna sila sa yahoo groups para sa details ng EB.
    olive_medel: kahit kasi ung ibang members, d rin maka login sa tsikot.
    thanks po sa lahat...
    Oct 2009
    #11343
    sa wakas naka login na rin, been trying since monday morning with no success.
  4. #11344
    5k pms ako tom
    how much kaya abutin?
  5. #11345
    guys help, advisable pa ba ang 4 people sa middle row seat? at 3 sa 3rd row, ako then 1 front passenger. ung 4 sa middle ay women, isa mejo chubby. 4-5 times po ito a week for 70km travel. slex- c5 lang po.
    di ba makasama sa innova ko?
    Sep 2006
    #11346
    Quote Originally Posted by innoBOB[09JmtG] View Post
    seemed like it is on its counter-balance or counter-weight...
    just always check on your tire pressure...
    #11347
    Quote Originally Posted by wakin View Post
    guys, meron po bang adjustment ang headlight ng innova? para kasing di pantay yung beam ng ilaw.
    Meron sir. May makikita kang 10mm screw sa likod ng headlight. Easily accesible naman gamit yung pasunod na tools ng Innova.
    Just make sure na naka tapat sa pader o sa gate yung ilaw mo habang nag aadjust para sure na pantay yung adjustment mo at di rin masyado mataas.
    HTH.
    Mar 2003
    #11348
    Quote Originally Posted by weewee1203 View Post
    If you need:
    - beige interior
    - backing up sensor
    - side moulding
    - alarm
    - 6 speakers
    Go for G.
    thanks weewee1203!
    E would be perfect if I can just add the fog lights and the multi-info display. Pwede kaya pakabit sa casa nun? magkano kaya?
    Oct 2009
    #11349
    thanks weewee1203!
    foglight maybe installed, but the multi info display i doubt if they could install it, one thing is where to find the said display.:question:
    Aug 2006
    #11350
    Assuming you still have the same stock tires, it is still safe.
    Been driving my Innova now for 3 years now with 2-4-3 sitting configuration, Bulacan-Makati and vice versa running 80KMs daily.
    May 2007
    #11351
    5k pms ako tom
    halos pareho lang po iyan ng 1K PMS nyo.
    Oct 2009
    #11352
    bossing baka may service manual po kayo ng innova e kahit anong gawin ko po hindi ko mapastart eh walang diesel umaakyat sa nozzle tnx po
    #11353
    Quote Originally Posted by ---spotcash--- View Post
    gosh, i had my ride checked in Toyota, and according to them this usually occurs on an Innova. So what I did was to change my fuel filter filament and cleaned the fuel filter; after cleaning, the fuel system, warning light still lit. accdg to the mechanic that I have to change mu fuel filter centimeter sytem, too bad they have no stock in the branch, goota order in advance and be back there next week...
    what i forgot to ask is that if there is a standard time to clean the fuel filter; like changing oil after reaching a certain kilometers that we are indeed to change our engine oil.. will try to ask this when i go back in casa...
    i followed the manual's instructions on how to drain the fuel filter housing, of water. it didn't work. yes, we all end up replacing not only the fuel filter, but also the ENTIRE fuel filter housing assembly. it'd have been cheaper and easier to just replace the entire fuel filter assembly. 2.2 K, if i recall.
    i don't recall what my manual says on time intervals between filter change, and tinatamad na akong bumaba sa garahe...
    hey, be ready for the dreaded fan belt-alternator-compressor bearing failure. the innova is the only vehicle i know of, where you have to replace the entire alternator when its bearings wear out! (or so, what the casa mechanic told me.)
    #11354
    Quote Originally Posted by kupaloids View Post
    HTH.
    yours is a screw? mine is a toothed gear that i have to push up or down using the flat blade screwdriver.
    anyways, compared to the right headlight, the left headlight should be aimed just a tad more to the right and a tad lower. courtesy to the oncoming motorist.
    Sep 2006
    #11355
    tnx for your reply
    this seemed to be an ongoing problem of Toyota, and they should be notified in order to rectify this issue.
    I think that's what going to happen to me coz i am juz waiting for the part, so called, fuel filter centimeter system and it cost now around P2,750.00
    I am just not definitely sure, but would like to do this as to practice to prolong the life of my Innova's engine... I think what I have to do is every time I change the oil and filter of my car, id be doing the same thing with my fuel filter system
    geez, that sounds so scary regarding replacing the alternator, whew that is a whooping big bucks that you have to shoulder, you'd be glad if insurance covers for this...
    what are the signs of fan belt-alternator-compressor bearing failure? any alarming sound on the engine or warning light that will Lit on the dashboard?
    tnx...
    Dec 2007
    #11356
    tnx for your reply
    tnx...
    At last, the login problem has been solved.
    For Toyota to replace the whole filter assembly only means that the float type switch (that detects water accumulation) is damaged and this should not happen regularly.
    It is actually a very good thing to replace the fuel filter element (ONLY!) when the engine goes for an oil change. The price of the element is about 400 pesos and this should be manageable.
    #11357
    Yup! It's a 10mm screw. I used it to lower the aim of my headlights.
    Sep 2006
    #11358
    Quote Originally Posted by timo07 View Post
    same here with the Login... too sad i cant use my other username since I preferred that... dunno what happen...
    oh yeah id wish that this wont happen regularly regarding on my fuel filter system of my Innova; id rather put into practice as what ive mentioned regarding changing my fuel filter element everytime I change my engine oil and oil filter...
    tnx for the reply...
    #11359
    5k pms ako tom
    Mine is d4d, 5k PMS cost me less than P1,600 w/ mineral oil at Toyota NOrth Balintawak last October 09.
    Dec 2008
    #11360
    i got my new innova j 2110 for three weeks and im satisfied with its pulling power....but my concern is coz its only a J model and this model doesnt have a door open warning, i went to toyota cabanatuan to find out coz my 1987 boxtype have it...so i asked them to put a warning light and im willing to pay them but even the people there dont know if there is available socket for connection...so they have to open the dashboard and they found out that there is no other way but to replace the panel board and it will cost me about 18t...and i said no! so i went home sad coz they asked me to pay 160plus for the check up grrrr! imagine my 1987 old model boxtype have it.... and another incident had just happened, i reached 1000k and need change oil...so i went there and they changed the oil and paid them...but the next day i found out that oil level is more than the "full" level...and i found something powdery at the bottom of the pipe near the catalytic converter...so i went back there...Hay naku poor TUKELLE! they said that s its normal to have a powder coz its new and they drained oil for about half a liter.......and here is the sad news they charged me again for their failure to put the oil to normal level...i said what you were the one that changed and drained oil and now you are charging me 168pesos for your failure?!!!! what a sad experienced!!! so at the end i paid it!!! hehehe!and lessons learned!! Is this what you call after sales service?
Toyota Innova Owners & Discussions [ARCHIVED]
