ok! update next week. TY!![]()
Got my G gas M/T Flaxen last Friday! Happy with the decision to go for G instead of J--though that beige flooring is really a dirt magnet I will have to cover somehow with matting.
Question: what's the right tire pressure for the Innova. My SA said 30 for each tire is best. Coming from TYT Pasong Tamo, I had them checked--the tires were at 35-37--and reduced. The manual recommends 33. At 30 it seems it's still a bit bouncy.
mga bro, just installed a full tint on my windshield. sunguard magic silver, not so sure about the code of the tint, silver cya pag naarawan tapos black cya pag gabi na alang light na tumatama sa harap. problem is yung mga kasalubong ko sa gabi eh nage-glare ang lights. as in triple ang reflection. ang headlight ng kasalubong ko eh parang anim kc above and below the headlight meron reflection. ang alam ko high end ang sunguard compared to 3M. sa mga naka full tint sa harap ano po nakalagay sa rides nyo?
Floor matting you can get from Autobacs sa Banawe - made to order nga lang, pili kang material sa top and the bottom part is spiked vinyl. (P1500-2500 depende sa material)
My Tire pressure is 35, watch out for leaking shock absorbers madami na kong nasusundan na mga Innova na may tagas ang shocks absorber nila sa likod.
I have full tint Solarguard Medium dark Non-reflective. No glare at malinaw pa rin kahit gabi o umuulan.
You can spot them easily, they have this oily looks. Usually namumuti ang undercarriage ng rides natin dahil sa putik at alikabok at mapapansin mo na iba ang kulay ng ng shock absorber hindi siya namumuti sa dumi kundi nangingitim at makintab dahil sa langis.
For me, I check my ride weekly hanggang may warranty pa.![]()
^Sometimes its also undercoating. But over time, the undercoat will dry up.
As for me, I will always look underneath with a flashlight.
Yes, kung bagong undercoat medyo mahirap makita kung leaky ang shocks, pero kung namumuti na ang lahat ng parte ng undercarriage at naglalangis ang shocks absorber mo definitely very visible yan.
saipeme: thank you sir, makakasave nga ako pag ginawa ko yun
GLImamasan: thank you din sir, yung power windows nila, hindi shark ang brand, leopard something kit. doon nila sinasalpak kung saan tinanggal ang manual window handle, so hindi sya kamukha ng upper variants. akala ko nga noong una, pareho lang ang mukha, hindi pala! di naman sinabi sakin ng SA. Oh well, nakakabit na noong nakita ko kaya wala magawa. Nasanay lang kasi ako sa all power ng altis. nakita ko picture ng shark power windows, kamukha sya ng upper variants, so yun na lang sana pinalagay ko.
mile meron nagsabi sa akin na ibilad ko lang sa araw, tnx. solarguard pala di sunguard bro 001. and yes yung sunguard eh lower quality sa 3m.
wala pa nakabigay ng sagot sa tanong ko regarding upgrading the oem tires from 205/65 to 205/70, wala pa ata dito nakasubok. So what I did, since my cousin was about to change, I had 205/70 installed. Kasya. No problem sa full turn, at sa front shocks compression. The comment is that the ride also improved. Tire pressure is at 30, both the old 65 and the new 70.
I saw an innova parked at an SM parking lot, nakakabit siya ng 215/65 r15. It doesn't look that good, personally. Don't know kung sasayad sa full turn and shocks compression, though.
The price difference between the 65 and 70 series is at least 300 petot per tire. 70 series is cheaper.
Good input Altec![]()
Ilang months or years ba bago mapudpod ang tires or ilang Kms before we change tires?
Hay naku, I tried looking underneath with a flashlight and to my dismay I discovered by rear right shocks leaking all over.
Question: Ano po ba reason kung bakit madaling mag leak ang ating mga shocks? Overloading or Low Quality? Hindi po kasi pede factory defect coz ang dami naman factory defect niyan sa dami natin nagrereklamo![]()
