welcome po sa tsikot ser albert99 at congrats sa new ride...
Sa akin po 33psi. Ok na ok po sa akin ang ride. Sinunod ko lang yung nasa manual. hehehe!!! 10.58 km/l ang consumption. Mixed highway at city driving. Gas na manual ang J variant ko po.![]()
hello! newbie here...glad to hear from my fellow innova owners...got an Innova E...acquired last feb of this year....so far so good...no hassles yet..very satisfied!![]()
Hello Innova owners, pasali naman dyan. Satisfied ako sa performance ng D-4D engine. J variant nakuha namin at 7K na Odo. So far wala pa naman problem. Gusto ko maglagay ng 2 speakers sa likod left and right door. Dalawa lang kasi sa harap meron. Possible ba please give advise kung kaya ng stereo at anong ohms ng speaker ang match sa existing sound system.
hello innova owners! my first post here... i bought a used innova g d4d 2 months ago (released 2005, odo * 11,000kms); hope somebody can answer my questions:
1. the 1st owner lost the warranty booklet, can i still claim for
warranty if a problem arises?
2. if i have my innova's oil changed at gasoline stations,
will toyota still give warranty?
more power!!!![]()
I'm not sure about this. Toyota should honor any warranty without the use of the book. Try asking them about it just to be sure.
They do ask for the booklet when you have a PMS done by a dealer/casa, so that they can input the km/interval bet services and etc .
It is usually better to have the PMS done at casas in the first three years of a vehicle's life, for the purpose of warranty claims. Toyota might not honor any warranty repairs if they found out somebody else other than them tampered with the vehicle.
Welcome richcris!
I think you would be required to show the Warranty Booklet to prove that you are eligible to warranty service.
If you have the change oil done at a gasoline station, the warranty as far as the engine is concerned would be voided.
Mga Sir / Ma'am:
Tanong lang po. Kapag nai-lock na po yung steering wheel ng innova eh normal lang po ba na at an angle sya? Kakaiba lang po kasi itong sa innova dahil sa ibang rides eh level or tuwid pa rin yung manibela kapag naka-lock na.
Yup, ok lang. Hindi naman kailangan perfectly straight. Basta functional ang lock (at hindi naglolock habang tumatakbo).
MGA SIR,tanong lng g at diesel at 2700km odo.yung reserve water sa radiator na kulay pink ang coolant,nagbabawas din ba sa inyo?nasa low kc sa akin dinagdagan ko nang tubig muna ok lng ba?.talaga bang nagbabawas iyun di ba dapat pabalik balik lng iyun? kailangan ko na ba dalhin sa casa?thanks.![]()
Hindi E ,kc Kahapon Nilagay Ko Sa Full Yung Tubig Hanggang Ngayon Full Pa Rin.
ah.. baka iba lang ang design ng Toyota. Galing kasi ako sa casa for the 5K PMS of Santa Fe CRDi VGT, every 40K KMs daw ang coolant refill. Gulat nga ako e. Kala ko kasi dapat periodically sya dapat nilalagyan ng water/coolant. Sabi nya, you'll only have to kung may leak.
anyway, baka iba lang design.
If your vehicle is cold (ie. havent been started for the last 4 hrs or more), usually the indicator will be below the max indicator. This is normal. If you look at it again, when the vehicle is hot (ie. used for at least a few kilometers of running) you will see the indicator will suddenly be near or be at the maximum indicator.
Under the normal conditions, the coolant level should not be too low unless you have a leak. It is NOT recommended to fill up with water as this will only dilute Toyota's pink coolant. I think it is better to bring it to the CASA and have them top your reservoir with their pink coolant fluid.
