Results 251 to 260 of 691
July 8th, 2008 07:45 PM #251
with regards to the a/c, di ko pa na papalinis evap ko ok pa kasi lamig nung sa akin, wag lang yung sobrang init nung summer medyo hirap na sya. maybe needs cleaning na talaga.
as for engine power, tama lang sya don't expect na mabilis ang vitara as the tranny gearing is made for off-roading.
as for the suspension kay idol Doc Phillip(wiretap_md), ang nakita ko na maganda ang pagkagawa, kaya ako napabili ng vitara din. calmini na ata set-up nya, with arb bumpers
July 9th, 2008 08:52 AM #252
September 28th, 2008 10:47 AM #253
Hello guys;
I've been reading this thread & it shows that many of you guys knows a lot about Vitara. Mine is a '97 a/t JLX.
Kindly advise me of a good Suzuki mechanic who charges fairly too. I'm from the Katipunan, QC area. My cp# is 09167000954. Thanks in advance.
God bless.
byker
October 9th, 2008 11:19 PM #254
think rats along katipunan, lampas sa katips bar, can help you para malapit sayo.
mine is serviced by Stage 1 in araneta ave.
- May 2006
- 15
October 24th, 2008 02:58 AM #256sir, may alam ba kayong magaling na suzuki mechanic dito sa south? (sta. rosa)
4 months ago kasi dinala namin sya sa suzuki mandaluyong para ipa-check yung idling problem kasi sobrang erratic talaga. pero after 2 months nagflu-fluctuate na naman yung rpm at minsan namamatayan pa.
anong meron ba 'pag ganito nalabas sa exhaust?
http://i490.photobucket.com/albums/r...7/DSC00009.jpg
http://i490.photobucket.com/albums/r...7/DSC00010.jpg
October 24th, 2008 10:23 AM #257
Kung idling ang problem mo baka Airflow control sensor lang ang sira.
One way of checking it is to remove the electrical connection while engine is running. Papalya kung matangal mo then pag binalik mo balik sa normal idling.
Maraming pwedeng pag-mulan ng pamamalya pwedeng fuel filter,busted spark plug, or distributor. Yong nasa photo mo tuwing morning lang bayan or lagi ganyan?
- May 2006
- 15
October 24th, 2008 10:42 AM #258sir larshell, anong electrical connection po? saan yun?
any idea po kung magkano yung airflow control sensor?
October 26th, 2008 08:34 AM #259
Usually airflow control sensor is located in between the tube from air intake manifold and Airfilter housing. May electrical wiring sya. Try to unplug it. Pakiramdaman mo kung may pagbabago sa idling.
- May 2006
- 15
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
