Page 22 of 35 FirstFirst ... 1218192021222324252632 ... LastLast
Results 421 to 440 of 691
    Jan 2003
    #421
    Quote Originally Posted by ck24 View Post
    Guys,
    May alam ba kayo na nagaayos ng speedometer? dkse gumagana yung ODO meter ko pero yung needle and trip meter is ok. Makati and marikina area sana. D daw kaya gawin nila filmars.
    baka may isang gear sa loob ng nasira kaya di gumagana ODO. dati benz ko ganyan din, the option from the forums was to find a gear from RC cars, that has the same teeth count, or buy the whole assembly. i just left it as is, kasi when i opened the meter, durog na durog yung gear impossible na mabilang pa kugn ilan ipin nun.
    Jan 2010
    #422
    Ganun ba sir, i'll try to have it opened muna. Parang complicado ayusin ah. Ang mahal naman ng whole assembly kung bnew, sana meron surplus pa.
    Jun 2008
    #423
    regarding oil seal ng differential eto inabot ko chief..
    oil seal - 250
    labor - 250
    gear oil - 400
    solve na...
    Jan 2003
    #424
    dati may nakita akong surplus na buong dash ng vitara kasama yung cluster meter sa may imus, gusto ko sana bilihin pang katay, kaso we were on our way to tagaytay that time.
    Jul 2010
    #425
    Quote Originally Posted by impulzz View Post
    baka mababa brake fluid level kaya yun sensor pag nalulubak nag-activate.
    Hindi naman po sir. I normally check the fluid reservoir pero half full naman. Dun po ba dependent yung hand brake light indicator? Balak ko sana tanggalin yung glove compartment para ma check kung may wiring ba dun na related sa brake light indicator e.
    Jan 2003
    #426
    yes it's also the hand brake warning lite
    it's half full, so pag nalubak ka gagalaw yung fluid mag iilaw yung warning light.
    kung mababa fluid level mo at walang tagas sa linya baka manipis na pads.
    dun sa hand brake lever, may switch dun, pag naalis mo yung center console makikita mo yun baka maluwag, but that rarely happens. kung maluwag no contact, hindi iilaw.
    Jul 2010
    #427
    Galing! tama nga sir! :D dinagdagan ko lang yung brake fluid. Ok na. Thanks thanks!
    Jan 2003
    #428
    don't forget to have your brake pads checked, baka manipis na, kaya mababa fluid
    Jul 2010
    #429
    Would it be an easy/safe task to replace the bulbs behind the dashboard gauges panel? Ang dilim na kasi kaya hindi na umaabot yung ilaw sa bandang temperature gauge.
    Jan 2003
    #430
    madali lang naman, total of 8 screws to remove. then there are 2 wiring sockets to remove and the speedometer cable. kaya madilim yung sa may temp gauge kasi may pundi siguro na rice bulb.
    2 peanut bulbs at 2 rice bulb yan. the rest are for the warning lights. while you're at it, clean the inside too.
    Kenn, bouncing na din ba yung speedo needle mo at low speeds? like 20 to 40 kph.
    Jul 2010
    #431
    Ang peanut at rice bulbs ba po ay nabibili sa suking auto supply? I suppose generic lang tong mga to right?
    Sir when I clean the insides, ibig sabihin ba ay naka expose yung mga maliliit na gears na nag papaandar ng meters and needles?
    Pagkakatanda ko po nag bbounce nga yung needle. Hindi ko lang ma recall at low speeds. What does the bouncing indicate?
    Jan 2003
    #432
    yung peanut bulb (t10) meron sa auto supply, but yung rice bulb na mas maliit, sa banawe lang ako nakabili dati.
    bale aalisin mo lahat ng gauges, para malinis mo yung loob. madalilang naman pero dapat malakas loob mo mag DIY.
    yung bouncing needle sa vitara ko naayos ko by spraying white grease sa loob nung kinakabitan ng speedometer cable. natuyo na kasi yung grasa sa loob kaya nag bounce na needle
    May 2009
    #433
    Guys,
    Totoo po ba na matakaw sa gasolina ang Vitara Gen1? And, mahirap din daw po itong hanapan ng parts? I saw one, nung galing ako Libis the other day. Asa jeep pa man din ako, silip ako ng silip, porma din kasi eh.
    Jan 2003
    #434
    sa akin matic, city driving sta. to fort boni, 6.5Km/L, XCS gamit ko. di ko pa nasukat sa long drive.
    motor parts di naman mahirap, body parts medyo, konti kasi konti lang nagpapasok ng surplus lalo na pang 4 door.
    pag manual tranny mas matipid daw. hey guys sino naka M/T? can you share your FC?
    Jan 2003
    #435
    ganda ng mags nito
    yung tail lights ganda din
    Jan 2009
    #436
    ganda ng mags nito
    Wow nice and ganda naman nito, saan kaya makakabili ng taillights na ganyan parang GV ang dating hehe
    Jan 2009
    #437
    Quote Originally Posted by midasproject View Post
    Guys,
    Hindi nman po, halos parang car lang din FC niya specially kung MT, yung sa akin city drive ave. ng 8-9 km/L long drive nman is 12-13 km/L
    May 2009
    #438
    Thanks Noroi. :D So its just like my cedias consumption. Great. Comfy ba sa long drive? I mean, comparing it to a Pajero perhaps. And, matagtag ba?
    Jul 2010
    #439
    Hi guys,
    Hingi lang ako advice. I'm planning to have my clutch cable replaced. Tanong ko lang kung meron din bang ibang mga parts that would be cost-efficient na isabay palitan/check/linisin kapag sinervice-an na yung clutch cable?
    Hindi kasi ako sure kung ito yung mga tipo na may babaklasin na ibang parts tapos maganda na isabay na rin palitan yung kung ano mang belts and other stuff para makatipid s labor.
    Thanks,
    /Kenn
    Jan 2003
    #440
    kung clutch cable lang naman sira, wala naman gagalawin sa loob ng tranny. so wala naman maisasabay na iba.
GEN I Suzuki Vitara 88-up [merged]
