Results 351 to 360 of 691
- Jul 2010
- 109
August 7th, 2010 10:09 PM #351Follow up na din po!
When I acquired my Vit kasi, may makapal na chain na pang secure ng 5th wheel. Same sa chains na nakikita ko pang secure ng mga motorbikes.
The problem is, ayaw na mabuksan nung lock.Did everything to unlock it hanggang sa masira na yung nag-iisang key.
Balak ko sana lagariin na lang pero tingin ko super hirap gawin nun or baka maputol lang yung blade.
Pano ko kaya matatanggal yun? :cry:
August 7th, 2010 11:11 PM #352
any brand you prefer would do, as per user manual, recommended is 10w-30 i use synthetic oil
yup gamit ko vic oil filter
haven't changed mine yet
mahal ang K&N dito may natanungan ako sa banawe 4500 daw. nakuha ko sa US, 1800 pesos lang pinauwi ko sa kakilala. pansin ko mas gumaan ang hatak ng makina.
ATF=automatic transmission fluid, can also be used for power steering
the shop supplies the parts for me, tamad na kasi ako pumunta ng banawe. minsan pag nasa banawe na ako bili na ako ng mga regular parts na pwede istock like oil filter and plugs
as for the price i compute it this way... parts price + labor ng shop to get it from their supplier
if i were to go to banawe... parts price + gas to banawe and back to the shop + pagod ko(priceless)
it's called timing light, yes kasama sa tune-up yun. but plugging it to the OBD scanner is another story.Last edited by impulzz; August 7th, 2010 at 11:26 PM.
August 7th, 2010 11:17 PM #353
- Jul 2010
- 109
August 8th, 2010 03:04 PM #354wow! bilis reply! thanks sir Impulzz. Vitara owner din po ba kayo?
Sa oil po, ibig sabihin ba, merong 10w30 na mineral oil based tapos meron din 10w30 na synthetic?
Sa fuel filter, naisip ko lang po kasi palitan na rin to make sure na makuha ang optimum FC. May effect din daw kasi sa FC ang maruming fuel filter.
Sa parts and service po, since I'm from Las Pinas, mukhang mas ok pa nga na kunin ko na lang sa shop yung parts kaysa bumyahe pa ko ng Banawe. I'm not sure lang kung mura din makabili sa Evangelista para mas malapit. I can pass by there from work.
Sa timing, should I expect po ba na kung sa Gas station ako magpa tune up eh gagamitan na nila ng timing light at hindi na mano-mano ang reading?
- Jul 2010
- 109
- Jul 2010
- 109
August 9th, 2010 01:37 PM #356Went to ACE hardware this weekend. Bought a gallon of Castrol 10w40 and a VIC C-933 oil filter. Wala kasing 10w30. Sabi nung attendant, yun daw ang pwedeng alternative. Did I buy the wrong type of oil?
August 9th, 2010 07:52 PM #357
yes i have a 96 vit, daily driven
pag ka aalam ko both types have this rating. as for the 10w40 pwede sya. its a little thicker but it will do.
EFI naman engine ng vitara, but alam ko ang timing nya mano mano pa rin setting. tingnan mo mabuti yung distributor ng vitara may adjustment.
- Jul 2010
- 109
August 9th, 2010 11:50 PM #358sir, yung pagiging thicker ba ng 10w40 is an advantage or a disadvantage?
Dalhin ko na lang siguro sa Shell Customer's Cradle. Marami kasi nakapag sabi magaling daw mga mechanics dun. Siguro naman alam na nila kung pano dapat gawin yung timing!
Super thanks sir Impulzz for the enlightenment!
August 10th, 2010 11:16 AM #359
sabi nila kung medyo luma at di naalagaan makina advantage sya, kasi thicker oil will partially seal the leaks.
a thinner oil will be lighter for the engine to circulate.
- Jul 2010
- 109
August 10th, 2010 02:17 PM #360
This is excellent info! Thank you very much Egan! The aircon system, particularly the...
2014 Subaru Forester
