Page 28 of 35 FirstFirst ... 18242526272829303132 ... LastLast
Results 541 to 560 of 691
    Jun 2008
    #541
    question mga ser... required ba mag pa camber and align pag nag pa lift via donut spacer lang? nag lift kce ako via donut spacer lang worry ko baka nde maging maganda kaen ng goma
    Jan 2003
    #542
    had mine cambered and aligned when i had it lifted with donuts. just to be sure :D
    Sep 2011
    #543
    mga vitara masters san po may available spare tire cover?
    Jul 2010
    #544
    Hi guys,
    For some reason, I lost the cover of my brake fluid tank. Would you happen to know where I can get a replacement?
    Thanks,
    /kenn
    Jan 2003
    #545
    *kenn try links or olympia, not sure if they sell caps only.
    *vitbox been looking for one too. gusto ko yung parehas sa jimny
    Jul 2010
    #546
    *sir impulzz -san po yun links?
    Jan 2003
    #547
    OLYMPIA AUTO SUPPLY - G.Araneta Ave., Quezon City
    #256 G. ARANETA AVE., QUEZON CITY
    PHONE NO. 7165386
    FAX NO. 7137934 / 7165389
    LINKS MOTOR SALES - Banawe, Quezon City (if you're coming from e. rod it's on your left lampas ng fe del mundo hospital)
    #129 BANAWE STREET QUEZON CITY
    PHONE NO.
    711-42-31
    FAX NO.
    711-30-22
    Read more: http://tsikot.com/forums/suzuki-cars...#ixzz1Zju5aqVc
    Jul 2010
    #548
    nice! thanks!
    Jan 2010
    #549
    hello! i just acquired a 97 jxl vitara m/t, and im in the process of fixing some of the problems i encountered so far:
    a) broken speedometer cable ( binaklas ko yung dashboard gauge and nakita kong putol yung speedometer cable)
    b) leaking brake fluid (may tagas ang load sensing proportioning valve -LSPV)
    c) clutch pedal( sobrang taas yung clutch pedal at medyo matigas pag inaapakan)
    mga magkano kaya mga parts na ito: speedo cable, clutch cable, lspv im from the province kasi. i really have no idea kung magkano.
    thanks.
    Jan 2003
    #550
    replacement unit cost around 1k last time i asked olympia, thought mine was broken
    this one's expensive i'll ask my friend if this is the part we change a few months back that cost 6k
    think you need to replace pressure plate, disc, and release bearing... no idea since mine is an A/T but you can get replacement for these
    Jan 2010
    #551
    thanks sir impulzz. damn. mahal pala ng lspv. sana hindi aabot ng 6k, preno pa naman. pwede kayang remedyohan na lang?
    Jan 2003
    #552
    kung yung o-ring lang ang nasira baka pwede. yung sa akin kasi siguro sinubukan pa repair nung previous owner, the mechanic chipped off a big part sa may lip so ang nangyayari pag lumusong ako sa baha, pinapasok ng tubig, contaminates the fluid and internal brake parts.
    Jan 2010
    #553
    i tried removing yung LSPV kanina, grabe yung kalawang.... naghanap ako ng piyesa dito sa baguio- wala. pero nag order ako sa isang auto supply shop kaso by monday pa malalaman kung meron stock yung supplier nila, pag wala pa rin i will be ordering directly from manila ... my last resort will be converting my rear brake line to toyota- mas marami daw kasi piyesa...
    ask ko ulet, ano yung pagkaiba ng VITARA JLX sa JXL ?
    Jan 2003
    #554
    jlx trim lang lumabas dito sa atin. baka binaligtad lang yung emblem nya hehehee
    Jul 2010
    #555
    Hi guys,
    I'm suspecting that I got bad wheel bearings. Are these readily replaceable or is it like most Vitara parts that I need to order somewhere?
    Jan 2010
    #556
    Quote Originally Posted by impulzz View Post
    oo nga baliktad, JXL hehehe. thanks.
    Sep 2011
    #557
    mga vitara masters, ask ko lang ung vitara ko kapag start ang engine mataas ang minor bumababa lang kapag binukas ko na aircon? at how many liters of oil ang para sa 1.6L engine? nagpa-change oil kasi ako ung 4 liters ay halos 3/4 lng ng stick.
    Jan 2003
    #558
    on cold start my idle is at 1200 to 1300 rpm then when the engine warms up it goes down to 700rpm
    as for oil the manual says when you change the oil filter you put in 4.2 liters of oil
    Sep 2011
    #559
    sir bakit kaya kapag ginagamit ko na cya with aircon normal naman rpm nya. pero kapag ini-off ko n aircon, tumataas rpm nya. ano kaya problem? hindi naman nagpa-fluctuate rpm.
    Sep 2011
    #560
    hindi lng basta tumaas kundi halos nsa 2000 rpm at medyo umiingay makina?
GEN I Suzuki Vitara 88-up [merged]
