Results 91 to 100 of 309
- May 2004
- 81
August 3rd, 2004 08:36 AM #91bros, pede ko nang tanong yung type ng lowering spring nyo at yung shoxs nyo? an ba gamit nyo at pati na rin yung ride nyo para may idea ulit ako.. maraming salamat sa input!
August 3rd, 2004 09:19 AM #92
If I'm not mistaken, yung tukod look is for rear-wheel drag race cars, and very fast ones at that. Aerodynamic efficiency in a straight line is the reason, I think. Plus the rear wheels that drive the car are usually bigger.
It's not advisable for street cars esp. front wheel drive cars.
H&R would be your best bet. Hindi naman yan taon-taon pinapalitan.
August 3rd, 2004 10:11 AM #93
gamit ko intrax lowering springs with KYB gas shocks up front. OEM fluid pa sa likod pero lapit ko nang palitan to gas (when budget permits
- May 2004
- 81
August 3rd, 2004 02:27 PM #94mga bro,
ano po ba advantage ng paggamit ng gas shox sa lowering sprng against sa stock shox lang po? tahnks..
August 3rd, 2004 02:35 PM #95
Fluid type shocks may not be able to handle the forces that come with lower springs - both when in motion and while standing still. It might work, but it won't last as long and the ride quality is not as good as gas-types.
August 3rd, 2004 03:15 PM #96
lowering springs on fluid shocks tend to make the car bottom out when hitting speed bumps or potholes.
- May 2004
- 81
August 3rd, 2004 04:30 PM #97bro ssaloon, anong bottom out po un? di ba naka stock shocks ka sa ride mo? ok lang ba?
August 3rd, 2004 04:53 PM #98
kasi malambot yung fluid type shocks, kaya pag daan sa hump, malakas ang body movement. kaya pag baba mo sa hump, bababa din yung body ng car which could lead to your tire hitting the inner lining of the fender or pag sayad ng auto. stock sa likod lang since di naman ako punuan magpasakay, gas sa harap kasi don yung heavier side of the car due to the engine.
- Dec 2003
- 51
August 3rd, 2004 05:29 PM #99i suggest you get an H&R sport 30mm drop lang para sa A101 mo na corolla pero check out kung ok pa ang shocks kasi sayang lang ma apektuhan ang handling.nag sasakay ako 4 hindi sumasayad.conservative drop lang medyo mas mababa ang likod kesa harap yan ang corolla nakatingala since progressive ang H&R ma cocorrect ang tayo tuwid at unat swabe.
- May 2004
- 81
August 3rd, 2004 07:25 PM #100sir warbird at mga bro
san nyp ba recommend bumili ng h&r sport na lowering spring? alam nyo po ba contact numbers nila? nag tanong kse ko sa fusion r medyo mahal eh... 12.5K.. baka may masmurang mabilhan na alam nyo... thanks
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
