Results 61 to 70 of 309
March 10th, 2004 11:20 AM #61
have passed through that situation din..
hmmm... una talaga baka makatipid pero in a week time.. naglowering springsdin akohehe
March 11th, 2004 03:13 AM #62
posted by Autoxer sa HCP
Cutting stock springs to lower car.
Cost of cutting at sidewalk "talyer" 800 + 150/spring cutting charge.
Cost to replace blown shocks due to cut stock springs. ~1800x4 = 7200 + 800 labor =8000.
Add that to the 1400 you spent to cut your springs = 9600.
Add 750x4(cost of replacement springs)= 3000.
That would be 12600.
That doesn't include the gas & time you waste to get the parts you had to replace.
In perspective, a set of H&R sport springs used to cost 10500.
March 11th, 2004 09:50 AM #63
Help naman
Hey guys
Meron bang lowering springs at leaf sa likod pangmaliliit na auto kagaya ng auto ko na suzuki fronte? Ano brand?
March 11th, 2004 01:47 PM #64Originally posted by Supierreman
- Dec 2002
- 11
March 13th, 2004 07:48 PM #65guys, tanong lang po. if i buy lowering springs, then i should get gas shocks instead of fluid? bakit po? thanks.
March 13th, 2004 08:09 PM #66
gearspeed,
Hindi ba binabasan lang ng leaves ang spring or gumagamit ng lowering block?
Grail.
It is primarily for better handling and to avoid 'bottoming out' the suspension when you hit bumps.
March 14th, 2004 06:59 PM #67
pansin ko lang..most modern cars (even my 97 familia) gas shocks na..does this mean hindi na kelangan palitan?
sorry po at ot na
..errr...basta, wag tipirin ang pag lower kasi mas magastos. period.
- 124
March 15th, 2004 08:35 AM #69ako rin nag pa cut ng springs dati... dahil mahirap pa mag hanap ng lowering springs dati pang corolla. Soobrang tagtag... as in tumatalbog ako habang umaandar.. hassle. Lowered yung car for a yr, and ang bumigay lang naman (fortunately) is the bump stops ng shocks.
March 16th, 2004 08:59 AM #70gearspeed
Kung merong kayo maadvise na pagmaliit na kotse na lowering springs at shocks..Sabihin niyo naman kung ano brand?...Thanks...
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
