Page 297 of 341 FirstFirst ... 197247287293294295296297298299300301307 ... LastLast
Results 2,961 to 2,970 of 3407
    May 2018
    #2961
    Quote Originally Posted by SpinCycle View Post
    May 3M pa pala si Subaru ngayon? I thought nagpalit na sila ng supplier to SolarGard.
    baka mga lumang stock sir hehe.. pero Greenhills lang yata yung nag offer ng Solar sakin.
    #2962
    Quote Originally Posted by tsik_r2d2 View Post
    Would prefer 3M over Solar Gard. Naiirita ako sa logo ng Solar Gard, ultimo sa dash cam ko nakikita sa laki.
    Nov 2007
    #2963
    Quote Originally Posted by goo View Post
    Pwede naman tanggalin ang mga logo ng tint. Use alcohol on tissue to remove. Nalaman ko lang itong tip after 4 years of the 3M logo sa center ng driver’s view [emoji23]
    Quote Originally Posted by JJB View Post
    Jan 2010
    #2965
    for 50km pms na unit ko pero nasa 35k palang odometer reading i was advise sa MI service na due for radiator coolant replacement na daw. They will bleed the coolant daw ang replace a fresh one, procedure will take almost a day daw kasi meticulous daw ang pagpapalit ng coolant as there should be no air present, will charge P7,100.00 coolant and labor included. my question is, is it really needed, wala naman ako na experience na engine overheating, napapanis ba talaga ang coolant? and baka lang lalo mag ka problem? im having this "why fix if not broken" thinking kasi.
    thanks
    Jul 2015
    #2966
    Quote Originally Posted by Capsaul View Post
    thanks
    Its called preventive maintainace...if in doubt...ask for a 2nd opinion..
    #2967
    thanks
    I was just at Motor Image BGC yesterday for my 24-month PMS and they also told me that on my next PMS, they will already change the coolant. The cooling system requires 9L of coolant and they are selling it at around 600 per liter. They suggested the coolant change within the PMS schedule so that it will be included in the cost of the 30-month PMS. Like any other fluid in a vehicle, it needs to be changed so it a necessary activity in maintaining a vehicle.
    They said they have a cheaper concentrate option instead of the high temp coolant and it is up to me to choose which one. They did suggest the high temp one for my FXT. However, I am free to bring my own coolant if I don't want to purchase it from them. I found a Peak high temp coolant at Roadstar for around 300 per liter. I look for other options so that it will be cost effective on my end.
    #2968
    Iirc, based on the manual. First time replacement of coolant should be at 132 months(11 tears), or at 220,000 kms.
    Pls. check your manuals.
    #2969
    I will check back with Motor Image what prompted them to shorten the coolant change cycle.
    Mar 2004
    #2970
    Um ... maybe to make more money? ...
    It says in the manual that you should only use Subaru Long Life coolant ... some coolants have certain chemicals that can corrode the metal in the engine ...
Subaru Forester
