Page 145 of 171 FirstFirst ... 4595135141142143144145146147148149155 ... LastLast
Results 2,881 to 2,900 of 3407
    Dec 2014
    #2881
    Did you apply one of those windshield chemicals? ... they tend to make wipers skip ...
    So drive at night only? ... or during cloudy and rainy days? ...
    chemicals like rain repellent? yap naglagay ako pero even before ganun na ever since
    di naman ako nagpapabilad
    Mar 2004
    #2882
    Clean your windshield well to remove the chemicals on your screen ... use glass cleaner ... you will be using a lot of elbow grease ...
    Nov 2017
    #2883
    Guys, I will have my first PMS tomorrow at Subaru Alabang. Ok ba dun? Hindi naman sila maloko? Any bad experienced? Thanks guys!
    Jul 2015
    #2884
    Quote Originally Posted by monsky137 View Post
    Non whatsoever...the lift is beside the waiting area..youll see them replace the fluids..
    Jun 2018
    #2885
    Hi mates. Planning to buy a forester. When is the new model coming out?
    Shine the light
    #2886
    Quote Originally Posted by teukie View Post
    Shine the light
    The new generation is already out in North America. It might be here by next year.
    #2887
    Is it worth it to buy the xt now with the all-new model coming?
    #2888
    Quote Originally Posted by iboy View Post
    You should buy the XT as there will be no XT model on the next generation Forester.
    Mar 2004
    #2889
    Wait for the new model ... they will come out with something better than the Subaru Forester XT ...
    #2890
    It may take some time before they come out with something better than the current XT model. For the mean time, the new global Forester generation only have one engine option, a 2.5L NA engine rated at 182hp/240Nm.
    Dec 2002
    #2891
    Guys,
    Planning on buying the current Forester due to the attractive promo. Any experience on which dealership gives the maximum discount?
    Jan 2018
    #2892
    Quote Originally Posted by rossph View Post
    Guys,
    I got a good discount from Subaru Greenhills.
    Best to go to all dealers in your area and compare. Once you have all quotes, you can go back to the agent and dealer you want to purchase from and ask them to match the best promo you found. They will match most of the time.
    #2893
    ^^^ Most of the Subaru dealers here are owned by Motor Image so you might the same offers among the branches. It's really up to the agent as to how much discount you can eke out from them.
    May 2018
    #2894
    Guys,
    Please share how attractive is that attractive promo.
    My budget is only 1M for a brand new car but the 300k discount for a Forester base model is making me drool.
    How about you?
    Mar 2004
    #2895
    Stick with your budget ... work harder ... earn more ...
    Jan 2018
    #2896
    Quote Originally Posted by tsik_r2d2 View Post
    How about you?
    If you can stretch your budget a bit more, go get the Forester. It’s worth it.
    Best time to get a new Subaru is when they are clearing stock to make way for an upcoming model (if you don’t mind that yours will not be the latest one out in the streets). I schedule my purchases around this cycle.
    Jun 2018
    #2897
    Hi guys! newbie here. Just got an old 2010 Forester 2.0X with 66k Mileage. Hasn't been used since 2016. Was driven from the province last week (approx 1k km). Any suggestions on what I should change first? and sa fusion r or sa casa?
    Oct 2017
    #2898
    Quote Originally Posted by Injustice21 View Post
    Fusion R.
    Check all fluids esp. Coolant. Hindi sealed system ang SH9.
    Check MAF sensor - system can be either too lean or too rich. Have it re calibrated as needed.
    Check AFT - make sure pinkish pa yung fluid.
    Check Air conditioning system - prone sa condenser? issue ang SH9.
    Check power steering - esp O-ring and hydraulic hose. Can get brittle over time.
    Check valve covers - if may moisture, have it replaced.
    Check suspension - ball joint, control arm and bushings.
    Hope this helps.
    Sent from my SM-G930F using Tapatalk
    Jan 2018
    #2899
    Have all your fluids flushed and replaced.
    Jun 2018
    #2900
    Fusion R.
    Hope this helps.
    Thank you. Looks like there’s so much that needs to be done. Luckily, I got the unit for free as a Passed down car
    Lower Arm Brushing Big
    Lower Arm Brushing Small
    Press out brushing
    Transmission support
    Valve cover gasket
    Spark plug seal
    O ring
    Air filter
    Shock absorber rear
    Rear brake pads
    Clean throttle body
    Cabin Filter
    Total with labor is around 50k pesos
Subaru Forester
