Page 144 of 171 FirstFirst ... 4494134140141142143144145146147148154 ... LastLast
Results 2,861 to 2,880 of 3407
    Jan 2018
    #2861
    Having an issue with a 2015 Subaru Forester 2.0i ... AFAIK this model does not have dual climate control ... driver side does are not cold ... the passenger side vents are cold ...
    Any thoughts? ... should I bring this to Subaru or an Aircon shop? ...
    Usually that’s a sign of not enough freon.
    Have your AC system checked for leaks.
    Mar 2004
    #2862
    Thank you guys ... replaced O-rings (2 pcs) ... added compressor oil ... reloaded Freon ... 2500 bucks ... mechanic said many repair shops (and dealers) fail to check the oil in the aircon compressor thereby causing premature failure ... O-rings and compressor oil should be checked every 2-3 years according to him ...
    Took a long drive this afternoon 34 C ... so far, it's good ... Will observe for a couple more days ...
    Dec 2017
    #2863
    May I know where did you bring it?
    #2864
    Meron bang intermittent mode yung windshield wiper ng 2.0i-L 2018 model? Medyo naguguluhan ako sa manual at di ko mapagana. Sa pagkakaintindi ko, yung "Auto" mode eh gumagamit nung rain sensor pero sa experience ko napaka-unreliable nya kapag pa-wisik-wisik yung ulan.
    Mar 2004
    #2865
    Someone referred this mechanic who does home service ... he's returning to work abroad ...
    Dec 2017
    #2866
    So, he has no shop of his own. Perhaps after he retires abroad, he can put up a shop.
    #2867
    Is this the mechanic who fixed your aircon?
    Jan 2018
    #2868
    Good thing it was only the orings that needed replacement. No leaks found in the whole system?
    Mine had a very small leak in the evaporator which made my wallet cry.
    Mar 2004
    #2869
    He intends to do home service repair ...
    Yeah, he diagnosed the leaking O-ring issue of the aircon compressor ... he's actually quite experienced and good ... he already knew to check the compressor when he heard it running ...
    Had him check another vehicle's compressor also ... as expected, the O-rings also needed replacement ... compressor needed oil ... he used good quality Freon from Singapore ... he doesn't like to re-use old Freon since they have contaminants already ...
    Can now cool the cabin up to 14-16C ... have one of those 3-in-1 voltmeter with temperature gauge ...
    Mar 2004
    #2870
    Quote Originally Posted by SpinCycle View Post
    Evaporator is ok ... was tested for 30 minutes ... and then took a long drive the next day ... 3 days and so far, it's good ...
    #2871
    *Walter - please PM me the name and contact details of that mechanic. Just in case I feel my FXT’s aircon start to show the same symptoms. Thanks.
    Dec 2017
    #2872
    If it will not violate the forum rules, perhaps you can post the address or contact numbers in case someone will need his service.
    #2873
    Hi guys, mine is approaching 40k km, I think the ATF is scheduled for replacement. Do I need to bring to MI for servicing?
    I tried Fusion R to replace my noisy bushings, and had my oil change at fixstop congressional, ok naman service nila.
    Mar 2004
    #2874
    He's going back abroad ... he just came as a favor ... he said he might setup shop when he returns ... was convincing him to stay since from tsikot referrals alone he can have a good clientele already ... but he needs to train some more ... me thinks he just likes tinkering with the Ferraris and Lambos there ...
    Just remember to tell whoever will diagnose your aircon to check the O-rings and compressor oil first ... also ask what type of refrigerant they use ... apparently there are different brands of refrigerants available same as out engine oils ...
    Mar 2004
    #2875
    Quote Originally Posted by oliver1013 View Post
    Better to bring to MI for ATF replacement ... CVTs are quite picky ... better to be safe ...
    Oct 2017
    #2876
    As far as refrigerant is concerned, i think subaru uses r134 ata. Correct me if im wrong.
    Sent from my SM-G930F using Tapatalk
    Dec 2014
    #2877
    ano ba ang ok na maintenance for your windshield wipers nakakaasar lagi na lang nagskiskid ang wiper ko kahit anong palit ng wiper blades
    Oct 2017
    #2878
    Quote Originally Posted by Richard Yap View Post
    Wag ibilad directly under the sun.
    Mar 2004
    #2879
    Did you apply one of those windshield chemicals? ... they tend to make wipers skip ...
    So drive at night only? ... or during cloudy and rainy days? ...
    Oct 2017
    #2880
    No. Definitely not. [emoji23]
    What i meant was keep your car in the shade as much as possible.
    I kept mine in the shade sa office, sa bahay, and i park sa shade as much as possible sa labas.
    My OEM subaru wiper lasted 7 years.
    Kakapalit ko lang last year.
Subaru Forester
