Results 91 to 100 of 196
January 23rd, 2020 09:52 PM #91
Ang drama naman ng post na 'to, parang napaka-bad choice ng on-demand heater. [emoji28]
We have an on-demand Ariston heater at home that's been working for the past 8 years and counting. Have claimed warranty once with it but after they replaced the heating element (so actually these heaters are also serviceable), no more issues.
My current Stiebel Eltron also only requires 3.5 KW and isn't a resource-hog. My monthly electric bill is just 1.2k-1.5k.
Also, for people without multi-point plumbing and electrical wiring readily available, having your typical on-demand heater is the easiest and sometimes only choice.
5 min before taking a shower is also a huge time difference especially in the morning rush hour. Will gladly pay extra to get 5 more minutes of sleep in the morning.
Lastly, jusko we're only talking about ~7k here. Over the course of 5 years that's just 4 pesos a day. No big deal really if it's disposable - that said, heaters come with warranty anyway.
January 23rd, 2020 10:04 PM #92
Your call to take it as whatever, good sir. Just putting out there some industry feedback & experience w/ various types of heaters. Both types have pros/cons & some brands are better built than others.
The Ariston you have may not be on-demand but storage type, sir....otherwise you won't have that chance to replace the element. The on-demand ones are electronic, the storage is primitive electrical. The preparations are pretty much the same for both.
Yes, the amount isn't much but for the about same cost(which those brands mentioned are) less frequent plumber calls & inconvenience should be welcome bonuses.
Note: pic is a sample spec sheet of a Pana on demand.
January 23rd, 2020 10:10 PM #93
Not sure if heating element nga yung pinalitan basta the thermostat stopped working, called the warranty guy, came over and fixed it. Same config siya as my Stiebel Eltron (i.e. takes water from the shower water pipe and outputs it to the shower head). Looks something like this:
January 23rd, 2020 10:33 PM #95
That's indeed an Ariston on-demand similar to your current Stiebel, sir. Common faults are caused by calcification of everything...from the trigger, to the flow restricting tubes & the heating element. Once clogged, there won't be enough volume nor pressure to make the heater turn on.
You guys up north aren't on limestone bedrock like our neckodawoods. Water here is super hard. Softeners are a necessity to keep plumbing in constant good service. The on-demand won't have your luck nor half the longevity here.....I hope you can pardon the drama, sir.[emoji120]
Note: Bosch & Ariston share a few identical storage heater models.
Tsikot Member Rank 4
- 2,716
- 52,731
January 24th, 2020 11:25 AM #97"Jett."
after over 8 years, ok pa.
it survived our shift from well water to nawasa water.
January 24th, 2020 11:43 AM #98
Champs Aston I have each in my 2 shower rooms at home. Because water flows to it which a conductor and leakage prone, I choose mechanical than heaters with digital components.
January 30th, 2020 05:01 PM #99
We (aka my wife) chose Lecston primarily because it wasn't plain white like most other brands in its price range. Getting a free rainfall shower with it helped seal the deal.
January 30th, 2020 07:46 PM #100
Apologies that my answer is 6 years delayed....
ELSD prevents you from being electrocuted while taking a shower in case there's an internal fault. If it senses 'leaking' voltages where it shouldn't be (ie. the water coming out, pipes, heater body or chassis), it sends a signal to its internal breaker to trip, shutting off power to the heater. Remember, it doesn't take much electricity to kill you and you'll be long dead before the current can rise up to a level that can trip the breaker in your home so this feature is absolutely a lifesaver.
On all our water heaters, there's a "Test" button that you can press to test if the ELSD is working. When pressed, the heater should immediately shutdown. You can then push another button to reset it.
Look for this feature when you're in the market for such products.
Equally important is good grounding. This will be your last defense in case the heater together with the ELSD fails.Last edited by oj88; January 30th, 2020 at 07:48 PM.
high idle RPM at engine start
