4m40... nabasa ko noon 124hp yata.. not much.. pero.. coming from a 99hp gen2.. sarap ihataw:D hehe... from pag bigla mo ihahataw... ang dali umaakyat ng needle.. to 140... i have not yet tried over 140... but i think may ibibigay panga.. hehe
my FC is also around 7 to 8... but mostly city driving lang talaga..
napansin ko lang maingay seats.. ano po kaya magagawa dito?
sir zix.. how does fm 124hp compare to ms 178hp? hehe...
Sir, ang ODO Reading ko 127+++K na. i haven't tried checking the prop shaft yet. Tanong ko sa mekaniko namin kung marunong sya. With regards sa tires nag rotate na ko eh, kaya nakabalance na yung nakalagay sa likod. Sobrang nakakainis yung differential whine sound. Kaya minsan i prefer running at 60 km/h lang kasi maingay. I'm planning to go to ilocos, di kaya magkaproblema yun kapag long drive?
BTW, sino na nakatry sa inyo ng rancho rs9000x sa front? I'm planning to replace mine with a set of ranchos sa front.
or OME?
thanks guys sa mga sumagot...
inlove din talaga ako FM pag nasa expressway pag may nagovertake sakin FM hinahabol dahil gusto ko lang subukan kaso pag umabot na ako sa 140kph hindi na pumapatol sakin mga naka FM crv gen 1 po pala ride ko.. twice ko na nasubukan FM yung sa nlex and jdm 2 doors naman sa sctex..
how much tire ng FM yung sa stock magweels ralliart?
will try that.. hehe thanks sir zip...
honestly.. hindi ko naisip na i-oil siya.. ang iniisip ko palagi is to pad-up vibrations.. hehe
sir, i think most of the FM owners here have had there injection pumps calibrated (including replacement of the injectors)
calibration is part of maintaining a diesel engine like our 4m40/4d56.
symptoms that it is due for calibration include excessive black smoke, hard starting (despite new glowplugs) etc.
have your ride inspected at a reputable calibration center like central diesel in quezon ave or malabon diesel.![]()
Sirs,
May EGR din ba ang 4m40 engine? If so, mayroon bang may alam ng shop na nagbblock nito? TIA
meron yung year model 2003 up ata, kasi yung akin 2002 wala eh hehe... may discussion na dito nyan sa thread, try nyo sir i-search.
replaced my oil pressure switch/oil sending unit kanina... nag-intermittent blinking yung oil warning indicator...
part number MC840219
casa price P560
If nag babawas ng langis yung ride mo, have the engine checked for leaks. if no leaks namn I think topping up every 2000 kms is not that much, diesels aren't called "oil burners for nothing" ... to expound its due to the higher compression ratio in our cylinders vs. gasoline fed counter parts..
Who's the expert that told you that the FM is exempted or is not recommended to be calibrated?![]()
when you have excessive smoke and loss of power I suggest you bring it to a calibration center especially a duly authorized Bosch service center not the ones na sa tabi tabi lang... bringing it there doesn't necessarily mean they automatically calibrate it, they are gonna diagnose if you have symptoms of a pump that needs calibrating or help you out if they can because they are professionals...Be warned thou the 4m40 is quite expensive to have it serviced for calibration..
I hope this helps you in your problem, good luck![]()
Need help...my dashboard compass / altimeter liquid have already leaked.
Pano ba pinapalitan / kinakalas yun para mareplenish yung liquid na nagpapafloat dun sa ball?
Also water lang ba yung liquid na yun or a special type of gel? puna ko kasi parang medyo iba amoy ng aircon ever since it leaked.
thanks sa mga magbibigay ng inputs![]()
