Page 293 of 395 FirstFirst ... 193243283289290291292293294295296297303343393 ... LastLast
Results 5,841 to 5,860 of 14348
    End of the year for me means flushing out everything and changing odds and ends. Just changed the following:
    Oil, air, fuel and ATF filters.
    Engine oil, ATF dialysis
    Replaced valve cover
    Replaced front brake discs and hydrovac hose
    Flushed out coolant, brake fluid, power steering fluid
    Recalibrated my injection pump
    Cleaned the A/C and replaced belts
    Readjusted headlights and had the housing cleaned
    There goes my 13th month salary. Happy New year!
    Quote Originally Posted by K.I.L.L. View Post
    Kill, ano yan shotgun approach! heheheh
    Happy New Year To All!
    Happy Holidays to all!
    Matonong ko lang po.
    Magkano ang binabayad nyo sa LTO for the annual MV registration of your beloved Pajero?
    This 2015 kasi is PLUS 450.00 php para sa bagong plaka.
    Salamat,
    Ka david
    KILL, that's one long Christmas shopping list! :-) Happy Holidays to one and all!
    Aug 2007
    Sir K.I.L.L. ,
    Saan po kayo nagpa calibrate ng injection pump at magkano po? Maraming Salamat po.
    My beloved FM just reached 100k so aside from my annual flushing, I had it thoroughly checked. I actually forgot to include that I replaced the motor on my small exhaust fan as well as my AC blower motor.
    Quote Originally Posted by Monty View Post
    It took me five days to get everything done but I like keeping my FM in tip-top shape.
    Quote Originally Posted by ikaw_ngaba View Post
    Sir K.I.L.L. ,
    I had it done at Central Diesel on QA. It took two days. Cost varies depending on what needs to be replaced inside the pump as well as if your glow plugs are done for. In my case, my plugs were OK and my pump only had the usual wear and tear (thanks to 2T I think) so total cost was 10,500.
    Nov 2014
    Sir kill ano po brand ng 2T gamit nyo ang panu po yun ginagamit?
    Kasi po yung mekaniko ko binigyan ako ng petron fuel additive power booster 150ml container. Sabi po nya ilagay sa fuel tank 1 bottle per full tank. Eto ba yun 2T?
    Thanks!
    Quote Originally Posted by birman View Post
    Thanks!
    The 2T oil I use is Petron's power burn that comes in a yellow bottle. I mix it with Petron Turbo Diesel. I put in two small bottles of 2T power burn for every tank full of Turbo Diesel. I started doing this roughly 2 years ago and a good friend of mine even commented that my FM now runs smoother than before though I can't remember.
    Nov 2014
    Sir KILL eto ba yun 2T oil na ginagamit mo from petron?imageuploadedbytsikot-forums1420900306.301871.jpg
    Bili sana ako knina pg gas ko kaso sabi ng pump boy png motorsiklo (gas) dw yun ganagamit. For diesel engine dw petromate power booster dw.
    Mas lalo akong na confuse ngayon hehehe please enlighten me on this mga 2T users. Petron diesel max po gamit ko fuel. TIA
    The yellow bottle is exactly what I use. I don't bother with what the attendant pushes to me. They don't know anything.
    KILL, I recently tried Unioil diesel which they say is Euro IV. I'm quite happy with it (with 2T of course ). Less vibration and less smoke as compared when I was on Turbo Diesel. You can also check out the various threads here which are positive. :-)
    Dec 2014
    Howdy!!! A newbie here...
    Magtatanong din po sana... Balak din namin bumili ng Pajero pero pang surplus lang ang budget namin (P300K-P350K). My friend also recommended me to consider a surplus Pajero at siya daw ang bahala sa akin, he'll help me through (he's a member of the Pajero Club of the Philippines) then as I was shopping around in the internet may mga Dubai Pajero pala na LHD na talaga pero parang napaka-hirap mag-hanap nun ganun variant... I need an SUV mainly because I am also considering the floods in the Metro and we might be moving to Antipolo soon (from QC)... My question is:
    1. Can I fit my budget to the car I wish to buy? Dubai variant sana eh. Where once I bought it minor tweaks and sakay na lang, ganun... Any other suggestions? My other option is a RAV4 kaso gusto at dream ko ang Pajero eh.
    2. Madami ang nag-sasabi na maganda ang handling ng Mitsubishi... Is it true?
    3. I am a potential new car owner with little driving skills... Will this move (buying a surplus vehicle) give me headaches? In terms of maintenance...
    Thank you very much and wishing a Happy New Year to all of us...
    Quote Originally Posted by JB Day View Post
    1. True, mahirap hanapin ang Dubai version, plus karamihan ng Dubai version, or lahat ng Dubai version, ay V6 gas engine.
    2. Subjective for me. Kanina, sinubukan ko i-drive hard yun FM namin. Ok naman sa cornering pero ang taas ng roll niya na pwedeng matumba pag nag-sharp turn ka. Well, di mo naman ineexpect ang good handling sa isang ladder framed SUV
    3. It will depend kung hanggang saan ang pisi mo. Ako, first car ko yun JDM Pajero, so surplus yan. Well, expect wear and tear sa mga parts niyan lalo sa underchasis. As time goes on, dadami pang lalabas na problema dyan. Pero mind you, hindi mahirap i-maintain ang Pajero. Basta alaga mo ito, hindi ka niyan bibigyan nang malaking headache.
    Kung target mo ang surplus Pajero, karamihan dyan eh 20+ years na, so expect bigger problems as time goes on. Yun sa akin, 1 month nang di tumatakbo dahil bumigay ang transmission.
    Dec 2014
    Sir Testament11,
    Thank you for your input... I you we're to advise me should I push through my plan of buying one? If not what would you suggest? My budget is w/in the range of P300K-P350K... Eh Sir kung maka-chamba ako ng Dubai na diesel? Cencia na at dream car ko talaga ang pajero eh... Bukod sa dream ko siya eh yun practicality niya (laban siya sa lahat,,, baha, lubak, atbp.)...
    Thanks again!!! Happy New Year and God bless us all...
    Sir Testament11,
    Go for it ... kung surplus just make sure na ok ang conversion and orig lhd ang dash (15-18k bnew) .. kung dubai na diesel test drive mo muna. Some of them have leafs springs for the rear .. while local and japas surplus are usually coil sprung.. so baka magkaiba ng ride or kung palitin n springs nya (leaf) mahirapan ka makakuha..
    Local, japan surplus or dubai it really boils down sa current state ng vehicle.. bring a mechanic to be sure
    Sir Testament11,
    Yep go for it. Basta ito lang ang tip ko pagdating sa 2nd hand cars na medyo matanda na. Habaan ang pisi when problems arise. Di biro ang mag-maintain ng isang 15+ year old na sasakyan and it needs TLC.
    Feb 2014
    Mga boss, may nakukuhaan po ba tayo ng headlight chrome reflector? Kanina ko lang kasi napansin nung nililinis ko yung sasakyan na sunog yung sa left headlight ko. Thanks in advance mga sir and merry christmas!
    Quote Originally Posted by specialtikoy View Post
    Wala sir. Buo mo talagang bibilhin yun headlight
    Sa alam ko wala. Subukan mo sa mga surplus shops para sa buong assembly. Sunog ba talaga o madumi lang? Pag sunog baka masyadong mataas ang wattage ng bumbilya.
    Jan 2011
    Pang gen2 lang available sa surplus sir.. 1500 each.. kasya naman sa FM natin pero magkaiba ng glass. Clear ang glass sa gitna ng FM, yung sa gen2 may linya2x.. nagtry ako hanap sa banawe & evangelista.. ang available for FM eh Depo replacement or Brandnew orig..
    Kung magpapalit ka ng orig set from casa or kung change ka to depo sir, baka pwede bilhin yung right headlyt mo? hehe replacement na kase right headlyt ko..
    Salamat!
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
