Page 194 of 718 FirstFirst ... 94144184190191192193194195196197198204244294 ... LastLast
Results 3,861 to 3,880 of 14348
    #3861
    Quote Originally Posted by shiopz View Post
    Need help...my dashboard compass / altimeter liquid have already leaked.
    Pano ba pinapalitan / kinakalas yun para mareplenish yung liquid na nagpapafloat dun sa ball?
    Also water lang ba yung liquid na yun or a special type of gel? puna ko kasi parang medyo iba amoy ng aircon ever since it leaked.
    thanks sa mga magbibigay ng inputs
    Mayroon na nag DIY niyan dito, hindi lang basta tubig ang ginamit niya. Yung sakin nagleak na din, hinayaan ko na lang, still working naman kahit walang liquid
    Quote Originally Posted by zix888 View Post
    Same here, kahit walang liquid ok lang pala. baby oil ata ginamit ni Sir PB before.
    #3863
    sir mura na yan. i remember buying mine at a more expensive price. tapos sa casa pa yan.
    nagulat din nga ako cb eh... mga 900 to 1k budget ko for that part tapos mura lang pala.hehe.. may slight lowering of prices daw sabi nung personnel sa parts dept.
    Aug 2010
    #3864
    thanks mga bossing sa feedback...would you know kung pang ilang page dito sa thread na to yung DIY? im willing to backread naman, pero mas okay sana kung may makakapag point na lang ng page number para mas madali...baby oil as replacement, pwede naman pero baka naman lalo mangamoy
    thanks!
    #3865
    Shiopz,
    Hanapin mo sa archived section ng thread na ito using the "search" function. May pictures at instructions na pi-nost si PromdiBoy. Tama si RT, baby oil ang ginamit ni PB.
    Good luck.
    Aug 2010
    #3866
    Salamat Sir Monty!
    #3867
    #3868
    Quote Originally Posted by AC View Post
    will try that.. hehe thanks sir zip...
    honestly.. hindi ko naisip na i-oil siya.. ang iniisip ko palagi is to pad-up vibrations.. hehe
    same here. usually lumalangitngit yun left & right arm rests ng back seat against sa door sidings if nakababa (if naka recline naman ang back seat tumatama sa rear side facing seats yun arm rests), tas yun mga gilid ng back rests tumatama din don sa door sidings. pati na din yun rear side facing seats, kaya lang yun cause naman is more of mechanical squeaks.
    Mar 2012
    #3869
    Salamat Sir Monty!
    Sir Try mo rin mineral oil, you can buy sa mercury small bottle lang
    Quote Originally Posted by blue View Post
    Actually mas ok din combi ng padding and silicon spray para sigurado. Sa arm rest naman, temporary solution ko is to double adhesive felt material para no more squeaking sound pag tangal ang seat cover. Maganda din pang padding ang neoprene material kasi makapal. Kung para sa maliliit na padding lang, pwede na yung mouse pad sa CD-R king, mura lang.
    #3870
    alisin mo na lang yun liquid sa loob, nagtry ako mag diy after a year nagleak na naman... tagal na time na inalis ko yun kasi natulo sa loob at dinidrain ko para maubos na medyo sinipag ako nun isang araw kaya ginawa ko na..
    pagbukas ko tangal na yun clear epoxy na diy ko and nadala pati plastic sa likod nun inclinometer kaya wala na laman ngayon.. medyo may amoy nga yun oil...sa sobrang init siguro kaya nagleak ulit..hth
    Jan 2011
    #3871
    Share ko lang po after a month and a half in the paint shop, here she is.
    Front
    Back
    Interior
    Modification:
    1. Debeers paint
    2. Overrider and extended bumpers w/ fogs
    3. Custom leather seats.
    4. Tint removal DIY
    Here is how she looks before the makeover.
    Quote Originally Posted by davesy View Post
    Front
    Back
    Interior
    Modification:
    1. Debeers paint
    4. Tint removal DIY
    Very nice sir!!!
    Jan 2011
    #3873
    My dash oil indicator warning lamp lits up whenever I don't press the accelerator, ano po kaya problema?
    Sir RT, Thank you po.
    Even after fully wared up? Baka mahina charging, mahina na battery? Or grounded?
    Jan 2011
    #3875
    maybe grounded nga sir kasi when we jump start the engine using another battery namamatay pag papalitan namin ulit to its original.
    Feb 2012
    #3876
    Front
    Back
    Interior
    Modification:
    1. Debeers paint
    4. Tint removal DIY
    Ganda sir!! ganitong look yung target ko para sa JDM ko e, hehe
    pwedeng pa-pm or post nung price nung mod #2 sir?? thanks!
    #3877
    sir dave.. very nice makeover...
    may sumisilip sa 1st pic.. hehe
    gano katagal po inabot paint niyo? im assuming kasi... you had this painted after you got your new pajero.. hehe ang bilis ah..
    btw confirm ko lang po sir.. ito pong minakeover niyo ang balak niyo bilhan ng knn? confirm ko lang po that it is jdm.. iba po kasi filter ng jdm sa local.. hehe mabuti pinost niyo po picture..
    confirm ko din lang po that you have an oblong filter rather than a round one po?
    thanks
    Nov 2004
    #3878
    Ask ko lang mga ser san po ba trusted shop/trusted mechanic ng pajero natin? Balak ko sana pa tuneup/change oil and other pms checkup, pa check na din throttle/choke...
    Yun po ba sa throttle/choke lever talagang napakaluwag hatakin at itulak? Hinatak ko kasi parang walang reistance e di ba naka connect yun sa cable? Napaisip tuloy ako kung nawala sa ayos sa paghatak ko kahit binalik tinulak ko naman ulit kasi nga wala resistance, sinubukan ko din twist konti pakanan ayun may resistance na di ko lang alam baka dahil lang may kinakaskasan na pag twist kaya mejo sumikip. Tamang hinala tuloy ako sa throttle/choke kung nawala sa ayos feeling ko lumakas ng onte sa diesel... Pag ba naka active/bukas choke pano ko malaman? Di ba dapat maiiba takbo pag rekta na at bukas choke ko parang papalya? Thanks.
    Jan 2011
    #3879
    thanks
    Sir AC, mid march ko po pinasok yan sa paint shop medyo matagal pero okay lang po kasi pulido naman, sinadya ko po talagang hindi madaliin para mas maayos. Sir bilog po Air filter niyan yung nilalagyan ng fins, 4m40 EFI engine sir.
    Sir EA622, thank you po, pm sent.
    Aug 2010
    #3880
    salamat Chief! very detailed.
    Sa lahat ng nagfeedback - maraming salamat po!
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
