Page 196 of 718 FirstFirst ... 96146186192193194195196197198199200206246296 ... LastLast
Results 3,901 to 3,920 of 14348
    #3901
    #3902
    Quote Originally Posted by ecneret View Post
    ty sir. how about sa price sir baka may idea ka? tia!
    price will really depend on the condition of the car. check sulit, ayosdito to know the price.
    #3903
    actually tumingin na ko sa mga yan kaya lang wala talaga ako idea sa presyuhan sa ngayon ng gen 2 or 2.5 so di ko alam kung 'taga' price o hindi.
    tnx anyways!
    Feb 2012
    #3904
    mga sir, any idea sa insulation ng pajero natin? pag kasi nakapatay aircon ramdam tlga pumapasok init galing sa engine bay... or kapag ginamit ko then pinark ko for a few hours, pag pasok ko mainit talaga sa loob kahit may roof ung parking... ano po kaya material na okay dito? shops? estimated price? TIA!!
    Apr 2012
    #3905
    Hi pajero peeps, just want to check your opinion regarding FM. Given the chance na pareho sariwa, which one will you choose? Also considering that this would be used as a family car. Thanks guys
    1999 model FM 4x4 Ralliart look with Web mags 598k pesos
    2004 model FM ralliart pero 4x2 640k pesos
    #3906
    Quote Originally Posted by ryanbea View Post
    Kung hindi mo naman gagamitin pang offroad sa 4x2 ka na
    #3907
    yup get the 04 kung city driving lang and minsang baguio/tagaytay trips... 4x2 pajero capable naman sa akyatan... added maintenance cost kasi yung 4x4 mechanism (electricals,differential etc)
    pero kung mag-offroad ka, by all means get the 99 model. panalo pareho yan pajero yan eh.hehe
    #3908
    kamusta naman charge nila sa PMS sir? and sinasama ba nila mga bolt tightening?
    last time ako nagpa-PMS heavy check up eh, 100k km bale mileage ng paj (tatlo categories nila for PMS 5k,10k,20k)
    anyway, yup kasama yung mga bolt tightening, underchassis full inspection, greasing ng doors, greasing ng underchassis parts, brakes (clean/adjust), change oil,filter,air filter,fuel filter, fluid inspection, tire rotation with balancing, check wipers,lights,carwash.
    express 5k, premium 10k, ultra 20k
    image link nung PMS packages nila from their FB page
    Wall Photos | Facebook
    #3909
    Quote Originally Posted by EA622 View Post
    Since summer ramdam mo talaga yan... here's what I did, buy ka nga double sided aluminum insulator sa Ace or handyman around 100 petot per meter I think. Lagay mo sya sa ilalim ng carpet sa area ng footwell.. Labor: D.I.Y.
    Kung bitin parin pati sa loob ng roof trim lagyan mo na rin. Hope this helps
    *ryanbea
    In your shoes I'd still get the 4x4 especially cause its cheaper and you get more capability. If as you say na parehong sariwa... di naman ganun kahirap I-maintain ang 4x4 since additional differential and transfer case gear oil lang dag dag and since its a 4x4 city driving really wont take it to its limit to break the system. minus 1-2 km/l ka nga lang sa fuel consumption vs. a 4x2... just my 2 centavos... hehehe
    Feb 2012
    #3910
    thank you sir! palagay nio sir this will get the job done?
    kasi prang may pumapasok din na hangin galing dun sa engine wall? lalo ung sa may side ng evaporator.. andami ng mga wires etc. dito, pano ko kaya mailalagay ng maayos un insulator?
    Jan 2011
    #3911
    Sir try niyo rin i check yung fire wall ng paj niyo baka may mga kulang na seal or rubber na malaki butas kaya pumapasok yung init sa loob, marami kasi sa electrician ganyan ginagawang trabaho.
    Jan 2011
    #3912
    Sir yung 4x4 nalang kasi mas mura may option ka pa for 4x4.
    Apr 2012
    #3913
    Thanks guys, will take note on these points.
    #3914
    guys, loose yung aircon switch knob ko. mabilis matangal. any way to tighten it back again?
    #3915
    Masking or teflon tape para humigpit... hehehe
    #3916
    first thing tangalin mo muna yung door sill trim para ma lift mo yung footwell carpet. tpos tsaka mo isik sik yung pre cut insulators mo. Can't really say if mawala yung pumapasok na hangin, pero since ginagawa mo na rin yun carpet insulator check mo na rin
    Oct 2011
    #3917
    Another option sir is ibuka nyo yung humahawak sa knob by inserting a flat screwdriver. konting konti lang po ang kelangan na pagbuka.. too much and it will be difficult to push the knob back. do it in very small increments untill u achieve enough tightness
    #3918
    ginawa ko yung teflon. mahigpit na uli hehe thanks!
    Quote Originally Posted by 7009 View Post
    onga. hindi ko naisip yun hehe pwede pala ibuka para humigpit siya hehe thanks!
    Mar 2012
    #3919
    Sir, yung 1999 model 4x4, silver ba ito? May EGR headlight cover and brake lights cover/ sunroof? Kung same ito sir, nakita ko din ito sa malapit sa Pier. I think you need to check the following: Aircon, medyo mahina lamig, baka cleaning lang. Aircon vents switch, hindi nagbabago ang labas ng hangin sa mga vents, so baka tangal lang yung cable sa likod or putol, DIY lang. Front suspension, although walang kalampag,at maganda ang ride, I saw some joints na puro grasa so baka bagong greasing or medyo punit na mga rubber covers.
    Sir tama din na icheck yung engine wall at baka may loose ng rubber fittings, or kung wala na, pwedeng ang carpet foam, or neoprene na isaksak sa mga butas. Then just to be sure, use aluminum sticker (sa Ace meron) to cover all holes sa engine bay. At least protected din during engine wash.
    Sir pwede din instead of ibubuka, cut kayo ng small plastic and insert dun sa space to widen the gap. Tapos teflon pa. This will make sure hindi na luluwag yung switch. Yung iba naman they just insert 'blu tack' para may kapit ang switch.
    Mar 2012
    #3920
    Since na mention na rin lang ang insulation, I saw an online ad on Asphalt sound deadener.....P300 per sheet, size is 26 in x 35 in x 1.8mm. Ok kaya ito? They say this material is being used by auto manufacturers... Plan ko kasi mag DIY sa pajero natin to lessen the sound of the engine and road noise.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
