Page 191 of 718 FirstFirst ... 91141181187188189190191192193194195201241291 ... LastLast
Results 3,801 to 3,820 of 14348
    #3801
    Quote Originally Posted by blue View Post
    hmm, mukhang ok ito sir a. san store ka po bumili, what model ang nakuha mo and magkano nga pala? tia!
    Dito sa Angeles city, bridgestone dueler at 275/70/16 p9,550 per piece
    #3802
    kindly check sir if my power ka going to the motor. if may power naman you can hear the motor working. if the motor is working but the window remained idle, usually worn out na ang plastic gears nya sa loob. i'm not sure but i doubt na may nabibili na gear lang for the motor. usually may nabibili na 2nd hand power window motor, if not brand new na kunin mo sir.
    sir, subukan ko pa-open yung motor to check.
    Quote Originally Posted by Monty View Post
    CB, oo, subukan mo kay Zaldy's along osmena highway (formerly south super highway) medyo malapit sa intersection ng dolores (formerly pasay rd) at osmena. Nasa kanan siya pag papunta ka ng edsa.
    sir naalala ko nga nabasa ko dito about zaldy's. kayo ba yung nagpagawa dun before? ano yung ginawa?
    #3803
    CB, hindi ako iyong nag post dati. Ngayon ko lang nabanggit ang Zaldy's. Sinusumpong iyong rear window ko. Sabi ng casa palit na ng motor assembly. Medyo mahal kaya pumunta ako kay Zaldy. Ayon, naayos (at a fraction of the cost of a new motor) at mga 3 taon na ay ok pa rin.
    #3804
    monty, sige dalhin ko muna kay jemson bukas. kung hindi niya magawa, kay zaldy ko dadalhin. madalas ko makita yung shop ni zaldy going to makati hehe may nagpost na din kasi before dito sa gen2.5 na kay zaldy nagpagawa ng power window motor.
    Nov 2006
    #3805
    Hi FM peeps.
    ano ba dapat itune sa ating FM to maintain good engine performance.
    I noticed loss of power already.
    I heard from other FM peeps na hindi nila recommended ipa-calibrate ang injection pump.
    I noticed also malakas na kumain ng oil yung engine. I had to top-up ever 2000 kms.
    I religously maintain my FM every 5000 km...change oil, change air filter, change fuel filter, etc.....
    ano pa ba dapat icheck?
    Recommended ba na ipa-calibrate or huwag na lang ipagalaw?
    salamat in advance.
    #3806
    sir crazy... warn ko din po sainyo.. minsan sa banawe.. iniinsist nila palitan yung motor... sasabihin nila.. sir.. sira napo motor natin.. meron po kami nito.. tapos aalokin sainyo.. na trade in yung sira kapalit ng bago.. para mas mataas po bayad...
    sa mga naging case ng akin... puros linis lang pala katapat... same po po kasi halos hitsura ng.... powerwindow motor sa.. regular motor... parang boto po ng shampoo na maliit.. hehe... binubuksan lang po nila yan.. nililiha ng konti para malinis.. at kabit uli... yung iba nga pinopokpok lang pag nastuckup.. iikot napo uli.. basta hindi pa sunog yung motor.. pag sunog napo yung motor.. yun po.. rewind napo ang kailangan..
    machecheck niyo po kung buo pa ang motor....
    napansin niyo po pag bukas ilaw niyo sa dome light? or maplight? pag nagbubukas or nagsasara kayo ng bintana medyo dumidilim po yung ilaw...
    ganun din po sa wiper motor... pag inon niyo and may konting konti na dilim ng ilaw.. (minsan mahirap po makita yung dilim ng ilaw dahil sa sobrang konti lang) it means ayos pa po motor at nastuckup lang.. linis lang po yan
    pag wala po dilim ng ilaw.. maaari pong may problema sa wiring/switch or motor
    #3807
    Palinis mo na rin sir para isahan na lang.
    salamat sir.. papalinis ko na baka lalong magkaproblem eh..
    Quote Originally Posted by AC View Post
    sir big.. suggest ko nadin po... kay mang mario sa sm north edsa..
    halos bahay lang yung shop...
    madami customer kaya medyo may pila...
    but priced very reasonable
    and so far... me and my friends masaya naman sa trabaho nila.. hehe
    here is link.. dito ko din nakilala sa tsikot.. pinost ni sir otep:D
    http://tsikot.com/forums/aircon-temp...io-reyes-9292/
    maganda nga feedback kay mang mario kaso sobra layo ko south pa ako..hehe
    #3808
    Quote Originally Posted by fcuyugan__29 View Post
    thanks, i'll take note of that!
    #3809
    Quote Originally Posted by bigbrocx View Post
    mga sir plan ko ipalinis yun aircon ng fm namin may time na malamig siya then pag sobra init, mainit din yun buga parang wala na lamig.. ano mas maganda palagyan ko na lang ng freon or palinis ko na din? and ano kalimitin pinapalitan kapag pinalinis? parang may nabangit sakin na kalimitan daw kapag binaba, ang pinapalitan daw yun evaporator yata yun or yun condenser hindi ko sigurado kung alin dyan sa dalawa.. i hope hindi sira yun.. TIA
    palinis mo na sir since 9 years na pala. usually pinapalitan expansion valve, filter drier, o-rings (if applicable) and of course yun freon. yun evaporator or condenser (coils) hindi usually pinapalitan not unless may leak na hindi nila kayang irepair. pag kasi may butas sa may gitna or sa loob ng mga "coils" & fins na hindi abot ng hinang nila nire-recommend na palitan na lang. minsan naman don sa mga fittings mismo may problema. binababa nila (pull-down) yun buong blower & evaporator para malinis and makita if may leak sa system. leak is usually checked via soap bubble test. hth!
    #3810
    monty, ac, blue, nalilinis nga yung power window motor. mine was dirty na daw.
    cleaned power window motor, replaced gauge clsuter bulbs to LED, replaced temp cluster busted bulbs, installed additional aux fan, installed antenna.
    everything done c/o Jemson. except LED and antenna.
    #3811
    Testa, ty sa info. Medyo mahal pa mag pa projector lamp, change mina ako ng bulb para medyo lumakas.
    Mga peeps ano ba maganda gamitin para lumakas ng kunti yung buga ng headlight? Ano ba yung pang FM H4 na bulb? Nakakita ako ng Philips 4300k Clear Vision meron na bang nakagamit sa inyo?
    TY
    #3812
    Pampagana. Hirap pa rin talaga sibakin ng FM kung sa porma at porma lang
    Monterosport / Fieldmaster - YouTube
    #3813
    Quote Originally Posted by zix888 View Post
    Classic talaga ng dating ng FM. Sobrang tikas, sobrang ganda ng tindig niya talaga!
    #3814
    Mukhang na mi-miss mo na naman ah
    Bili ka ng FM na 3-door tpos salpak mo yung 28"
    #3815
    TY
    Yup H4 Bulb, clear vision ba? saken xtreme vision... ayus naman, better than stock..
    #3816
    naingit ako sir zix... hehe
    tulo laway... _
    Oct 2011
    #3817
    Question lang mga Ka-Tsikot. I have been thinking about my rear differential. As per sa mechanic namin dito sa office sira na daw.
    I need your opinion regarding this matter. May possibility pa kaya na maayos or ma repair instead na i replace ng surplus? I have already consulted Mr.Atutubo about my problem he told me save up for a surplus differential.
    Thanks and more support.
    #3818
    Quote Originally Posted by jilibee View Post
    men, pano mo nasabi na sira differential mo?
    #3819
    Yup it is CLEAR VISION ang nakalagay sa packaging niya. Tanong ko kung ano difference ng dalawa.
    Oct 2011
    #3820
    May ugong na tunog kapag high speed na. I've already asked our mechanics to check on the bearings, fortunately they found nothing. The next thing i did was i told them to check the magnet at the differential that usually indicates the metal grinding wear and tear is seen. To our surprise there was a lot of metal or metal polishings (sorry for the term). So i called up mr.atutubo to ask his opinion before opening the differential. He told me to replace the Gear oil with a higher viscosity and then observe. I waited a couple of days for i can test if the remedy has fixed the problem unfortunately not yet fixed.
    Thats how we arrived with that solution replace the diff with a surplus one. Has anyone experienced this problem? I need your inputs.
    Thanks in Advance.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
