Page 189 of 330 FirstFirst ... 89139179185186187188189190191192193199239289 ... LastLast
Results 3,761 to 3,780 of 6591
    Mar 2003
    #3761
    4m40, medyo marami na nga ako nakikitang sunog na sticker, akala ko dahil sa init ng araw kaya nagkakaganun.
    aldrich, di pa ako nakapagpagawa sa cruven, but kakapalit ko lang ng shocks, definitely may kinalaman sa ride ang shocks. pag sira shocks mo pag brakes mo sumusubsub ang harap, pag sa likod naman sobrang bouncy. medyo matagtag talaga fieldmaster.
    dcarin, pag nakita mo paano buksan post ka pics, di ko pa napuntahan yang vents,
    May 2007
    #3762
    Quote Originally Posted by aldriech22 View Post
    good day mga sir! proud owner po Nang local 2003 pajero FM . tanung ko lang kung meron na po bang nakapagtry sa inyo nang cruven sa suspension.. just want to improve the ride medyo matagtag. not sure if that wud help.. nways, salamat sa discussion dto madami akong natututunan ...
    Hi Aldrich,
    Kung ang tinutukoy mo eh tungkol sa shocks........
    Nagpa rebuild ako ng orig shocks last month...
    1. Initially inquired at Cruven, pero di sila nakakapag restore ng shocks
    with leaks na.
    2. Went to ZEE Carplus sa may Aurora Blvd, they can restore shocks
    even with leaks, cost me P7200 for the 4 .. all in with 1 yr warranty.
    May website sila for all the informations you may need.
    Currently, ride is OK ........
    #3763
    guys ot lang. i'm selling my autoart pajero gdi version die-cast model. scale is 1:18. you guys might be interested. i just bought it last year. text/call me nalang. 09176139426. thanks!
    #3764
    Quote Originally Posted by nOxiOuS View Post
    [SIZE=4]No advertising in the forums sections.[/SIZE]
    [SIZE=5]Please use the advertisement section![/SIZE]
    Aug 2005
    #3765
    Sure PB. Pag na-dissect ko I will post the pictures.
    Medyo kinakapa ko pa rin di umubra mala "prison break" kong analysis. Baka may mapilas eh lalo pang lumaki gastos.
    Mar 2003
    #3766
    dcarin, parang nakadikit lang ng adhesive yung paikot ng vents. Parang mahirap siya ibalik. For sure may bubuka sa gilid. I should know sinubukan ko buksan yung upper part. Ayaw na lumapat. Hehe
    Oct 2007
    #3767
    salamat sir sa reply.. my pajero i due for it's 40t checkup so dun ko malamn kung me prob yung shocks..out of the country po kasi ako and si misis lang madalas gumgamit .. if ever ill have a look dun sa place sa aurora or maybe opt for orig parts .tagtag po kasi hehe kotse kasi dati ko gamit medyo nakakapanibago.nways salamt mga sir
    Nov 2006
    #3768
    G'day!
    I just noticed that the A/T light in the dashboard is blinking. Although it stops after awhile. No exact pattern on when it blinks and stops. What may be the problem? Please advise mga boss...thank you!
    #3769
    I just drove an abused and neglected Pajero FM yesterday. One thing I noticed is the stupid rear a/c switch placement.
    I had the console disassembled and move the switch in place of the coin holders beside the handbrake. Now it's easier to reach.
    Mar 2003
    #3770
    sir OTep, tagal mo na di nagpost dito. nice to hear from you again. dati diyan ko rin nilagay yung switch but minsan natutuluan ng moisture ng drinks ko sa cupholders. habit ko na kasi mag drink and drive. kaya nilipat ko siya sa tabi lighter socket sa baba ng radio. nastuck up din kasi dati yung AT switch ko dahil din sa tubig. Si master PK sa tabi yata ng suspension setting nilagay.
    shiftknob, try mo muna change ATF. kung naka 80k kana na tinakbo maybe dapat isabay narin yung AT filter. take note lang madalas pag baguhan mechanic. pag refill ng ATF they check the level with the engine off. dapat naka on and laruin mo from P to L several times. kundi pag start mo tataas pa lalo. over filled ATf is very bad.
    #3771
    Si pajerokid sa tabi ng shock controls ata niya nilagay dati. Pero kailangan pa mag-extend ng wire. Eh ghetto fix ko lang ito. hehehe.
    #3772
    hmmm, matagal na ko hindi nakakapagpost din dito ah!
    nagkaproblema ako last saturday lang, tumulo ang sunroof ko at muntik lang bumaha sa loob ng sasakyan ko. good thing, nagawan namin kahapon ni erpats ng paraan para mawala ang tulo at ang reason, baradong waterways. kasalanan ko din naman kasi hindi ko nalilinis ang ducts ng sunroof ko. kaso ang problema ko, nagstain ang ceiling ng sasakyan ko. may mairerecommend ba kayo na magandang panlinis ng ceiling ng sasakyan?
    Nov 2006
    #3773
    Thank you sir will have it checked!
    Jan 2008
    #3774
    Sir ask ko lang kung kailan paba na i pa retapping yung valves ng 4m40 engines a month after the overhaul? may nakapag sabi kasi sakin na self adjusting daw yun, totoo ba?
    Mar 2003
    #3775
    testament, sa detailing forums dati ni sir theveed ang gamit sa headliner is megs all purpose cleaner. with microfiber cloth pang kuskus.
    dysdamon, dati parang nabanggit ni master PK na self adjusting nga daw.
    galing ako casa kanina pinaservice ko yung isang mitsu ko. sa sobrang bored ko nag shopping nalang ako sa parts section para sa pajero natin. wear and tear parts na common palitan sa aging pajero ko. ito mga nabili ko.
    - outer door handle 3,100 oem kinuha ko. meron daw taiwan replacement only 450. exact replica. nabali kasi ng driver namin. naka mighty bond nalang ngayon.
    - door trim handle. sino nga ba yung nag tanong about laspag na handle. para sayo naman to. ito yung nalalaspag na handle sa loob na kulay grey. medyo mura narin kaya binili ko na. kaysa mag remedyo. 840 pesos lang.
    - center aircon vent, dcarin para sayo to. one piece siya 2 vents and wood trim. 4 screws para maalis. 3,700 kuha ko. imho kaysa remdyohan mo buy a new one. tatagal naman ng 10 years uli. marupok na kasi mga plastics plus may ambipure damage yung wood trim ko. kaya kinuha ko na.
    #3776
    will try that pb, pag napunta ako ng blade, hahanapin ko ang nirerecommend mo. problema ko din, ayun, ang lakas ng amoy! napilitan ako magbukas ng ambi pur odor eliminator at nilagay ko ngayon sa harapan.
    Apr 2005
    #3777
    Guys magkano ba resale value Paj FM ngaun?
    Jan 2003
    #3778
    Quote Originally Posted by 4m40_adm View Post
    Paj Bros:
    Share ko lang, ingat kayo pag nag papawax, especially dun sa may mga 3d Sticker. May effect kasi to after some time, makikita nyo nagiging brown yung sticker nyo. Nag palit nakasi ako last year nakalmutan ko lang ipost.
    sir pb, hehe wala pang rims pero curious lang ko kung ano max na height at kapal ng gulong na pwede sa fieldmaster natin. Yung 4x4 type at hindi yung bling bling type. :D
    yun malaking pajero sticker sa gilid eh dapat iwasang malagyan ng wax, nagiging redish yun kulay tapos nabubura, ang pangit tignan.
    Quote Originally Posted by dcarin14 View Post
    Mga Ka-Paj, Ask sana ako kung meron na sa inyo naka pag baklas ng center aircon vent (with digital clock display) sa dashboard. Try ko sana i-DIY yung nabali na vent fins ng aircon.
    Sinubukan ko sungkitin sa gilid pero may resistance kaya worried ako at baka mapilas. Sinubukan ko tanggalin digital clock module pero wala akong makita na screws to indicate na naka screw ang panel.
    Salamat in advance
    yun central vents may 4 na screws sa loob, hindi mo matatanggal kung di mo ibababa yun buong dashboard. medyo hindi accessible kung dudukutin mo lang yun mga screws. yun digital clock eh nakaclip lang sa central vent so pwede mo sya push palabas mara matangal.
    Jan 2008
    #3779
    Guys so far the top overhaul and injection pump rebuild ng 4m40 subic pajero ko is doing well almost 2 months na walang problema tuloy tuloy lang ang byahe. Significant change before and after the overhaul is the fuel consumption from 4.9 to 7.2 km/liter, engine responds quicker, less engine noise tsaka syempre yung tirik pag pinasok ng air yung injection pump nawala nagkakakalyo palad ko kaka bomba ng fuel pump before ko ipagawa.
    kanina change oil lang ako from caltex delo gold to mobil 1, pakabit yung thermostat, drain and refill the radiator with 50:50 distilled water and coolant, push button door lock control dun ko nilagay beside A/T controls.
    Sana matagal kami ulit magkita ng mekaniko ko, bukas interior detailing naman ako.
    #3780
    oi, magandang pagbabago yan ah! 7.2 km/l, magandang fc na yan sa pajero mo! sana tuloy tuloy na ganyan ang behavior ng pajero mo bro
