Page 86 of 496 FirstFirst ... 367682838485868788899096136186 ... LastLast
Results 851 to 860 of 4959
    Apr 2012
    #851
    Mar 2004
    #852
    ^^^ Tasteless article.
    #853
    I have a 2011 Montero GLS. Just last Sunday, April 27, I was in an uphill climb about to overtake a very slow bus. My speed tailing the bus was only about 30KPH. When I tried to accelerate the transmission disengaged from "D" with no display at all in the LCD with the engine still running. I guess it shifted to N. I tried the manual shift but still no display and not shifting to any gear. When I shifted to P only then the LCD gear display was restored then shifted to D only then I can drive forward again.
    For about 3 times whenever I am on full-stop and slowly accelerating I experienced the same issue and resolved with the same change shift from P to D.
    Have it checked with Diamond Motors 2 days, April 30, and they immediately told me that it is a known issue which is the the Inhibitor Switch. They said that it is no longer covered by warranty so I have it replaced for Php 5K parts and 2K labor.
    This issue is actually quite dangerous particularly when it first happened to me when I am about to overtake a bus uphill. This should be covered by a Recall with the parts replacement at Mitsubishi's expense.
    #854
    ^ i guess that bit of news should be here instead -> http://tsikot.com/forums/mitsubishi-.../index114.html
    #855
    This is the issue I experienced with the INIHIBITOR SWITCH as the culprit.
    I have a 2011 Montero GLS. Last, April 27, 2014 I was in an uphill climb about to overtake a very slow bus. My speed tailing the bus was only about 30KPH. When I tried to accelerate the transmission disengaged from "D" with no display at all sa LCD panel though the engine still running. I guess it shifted to N. I tried the manual shift but still no display and not shifting to any gear. When I shifted to P only then the LCD gear display was restored then shifted to D then doon lang ako naka drive forward ulit.
    For about 3 times on my way home, whenever I am on full-stop or slowly accelerating I experienced the same issue and resolved it with the same change shift from P to D.
    I have it checked with Diamond Motors on April 30, 2014 and they immediately told me that it is a known issue which is the Inhibitor Switch. They said that it is no longer covered by warranty so I have it replaced for Php 5K parts and 2K labor.
    This inhibitor switch issue is actually quite dangerous particularly when it first happened to me overtaking a bus uphill. This should be covered by a recall with the parts replacement at Mitsubishi's expense.
    Aug 2011
    #856
    Quote Originally Posted by erj22 View Post
    i haven't got any info yet. but my neighbor's montero just went berserk. the lady driver was brought to the hospital for checkup. the vice president of our HOA saw that the shifter is in P with handbrakes on. no full details yet though.
    update: the car was on its way to the garage when the lady driver transferred from front passenger to driver seat. it was driven by her daughter in-law. gear is in park and handbrake is engaged. when seated, that's when the monty went berserk. gear was still in park and handbrake is engaged. it went full throttle. there is a video of it running wildly and the driver is depressing the brake to no avail. monty still went through. i'll try to acquire the video.
    Nov 2012
    #857
    sana yung video mapakita na sa brake pedal nga nakatapak at nasa park position ang gear, kasi ang alam ko once the gear is in drive or reverse and you try to step on the gas and brake at the same time the engine will stall, at kung naka park position naman kahit anong diin mo sa accelerator hindi siya gagalaw sa pwesto.
    waiting for the video...
    #858
    devil's advocate here..
    so the article is leading us to believe that despite the stickshift in Park, the handbrake engaged, and the adrenalin-pumped driver stepping with all her might on the brake pedal for dear life, the monty still decided to lunge forward...
    i wonder, did they exchange driver positions via the front doors, or via the hard way?
    i'm from missouri..
    #859
    ^^^makabili nga ng MS parang UAV. Remote control na lang need.
    Hehehhe.
    Baka pagtaga north Sudden Acceleration.
    Dito kasi sa south ang nababalita Sudden Stop eh.
    Nyahahaha
    Posted via Tsikot Mobile App
    Jun 2012
    #860
    video lang na nagpapakita na naka-ilaw 3rd brake lamp tapos sumugod pa rin, oks na. game
Mitsubishi Montero Sudden Acceleration Accidents [MERGED]
