Page 111 of 124 FirstFirst ... 1161101107108109110111112113114115121 ... LastLast
Results 2,201 to 2,220 of 5006
    1st time to change ATF ba bro?
    Plan ko is 60K kms ang change ATF. So ok pala kahit centenial monty! :D
    Sent from my Nokia5110i-VgT using Tsikot Forums
    sweetened at 40k kms and at 75k kms(pan draining 3.5L)
    Sep 2011
    Grabe itim ng atf sir zix ah haha. Ako i drain from the pan lang every 20k kms.
    Posted via Tsikot Mobile App
    Feb 2007
    Quote Originally Posted by babynos01 View Post
    Ilang liters usually nakukuha nyo sir?
    Dec 2012
    Hi, im looking for the sd card slot ng avt oem head unit para mag update ng gps maps sa ms-glsv. natanggal ko na yung head unit mismo pero wala ako makitang sd card. sana may makatulong. ty.
    Sep 2013
    Quote Originally Posted by mykmarinas View Post
    sir nasa left side ng screen yung sa old gen montero, check niyo nasa may likod lang may parang rectangular slot doon
    Sep 2011
    Max is 3 liters sir. Medyo magulo basahin yung sa pdf kasi. May mga steps na iniskip haha.
    For 80k which is 6 months from now, balak ko sundin yung sa pdf para bago lahat. So far kapag nag rerefill ako every 20k, red parin yung color ng atf.
    sakin 3plus liters nung nagddrain lang ng pan. sinusukat ko yung actual na na-drain, yun din ang amount na nilalagay ko
    Quote Originally Posted by zix888 View Post
    Bos Zixx,
    Is it easy to replace the Tranny filter? I'm assuming there's only a single strainer filter? for the 4AT GLS-V.
    Thanks
    Feb 2007
    Thanks bros.
    Bought ATF SP III(4L) so pwede 4L din drain ko for sweetening.
    Sep 2011
    Magkano sp3 sir? Mahal yan ah haha. Sa akin dexron3 lang ng total e haha.
    Feb 2007
    Nasa 370 petot sir. Para kasi same oil pa rin. ;)
    Sep 2011
    Seryoso?! Bat sa atco and iba nasa 600 to 800 pesos/liter?
    Saan mo nabili sir?
    Feb 2007
    Dito sa bansa ng Langis sir!
    Sent from my Nokia 5110 using Tsikot Forums
    Quote Originally Posted by petixs View Post
    Bos Zixx,
    Thanks
    yan ang ayaw ko gawin sir, kasi walang plug and play na gasket para sa pan. allergic ako sa gasket maker
    yaiks..
    Madugo pala. kaya pala nung sinabi ko sa casa nung 40k na pati screen filter paltan, sinabihan ako na hinde pa advisable.
    Thanks Master.
    Sep 2011
    May I know why sir? Nababa na panu yung pan ko, yung "gasket" nya parang paste lng di kagaya nung sa EGR na bakal. Kailangan i strip yung nakadikit na gasket then may linagay na high temp silicone gasket ata
    Sep 2011
    Theres an fb mitsubishi nontero sport. Black yung montero niya. He/she posted pictures wherein they brought down the pan. Hinahanap ko din saan nakalagay filter e. Does it need to be changed every 40k din ba?
    Onga around 3+ liters for pan drain. Still have the containers here haha.
    Feb 2007
    Post mo picture nya dito sir.
    Incase magbaba kayo ng oil pan:
    bos saan niyo nakukuha iyong illustrations na iyan? may service manual kayo ng monty? pa-share naman ng link pls
    Sep 2014
    Goodevening po sa lahat. beginner po ako dito sa tsikot. I got a 2nd hand monterosport 2010 Gls 4x2 AT last May 2014 at 46k mileage. napa linis ko na po egr sa eldorado dahil ng cel. mabuti at nawala ilaw after 2 days na malinis. binasa ko talaga mula umpisa hangang dulo ang topic para sa montero at madami akong natutunan. Tnx sa magagandang paliwanag ni sir Six sana pare matulungan mo ako sa mga dapat ko pang gawin dito sa sasakyan. Maraming Salamat at pacencia na at hindi pa ako sanay.
2011 Mitsubishi Montero Sport [continued]
