Page 115 of 251 FirstFirst ... 1565105111112113114115116117118119125165215 ... LastLast
Results 2,281 to 2,300 of 5006
    Jul 2004
    #2281
    Quote Originally Posted by jclalzona View Post
    I'd just like to ask if any of the monty owners here have upgraded their audio systems while retaining the MID. I found some of the packages offered by the Tsikotshop quite interesting but I'm looking for a setup that's more or less compatible with the stock HU (if that's even a fair comparison). I've also just got a modest budget of P12k-P15k tops.
    Thanks in advance!
    i don't think you can separate the AVT HU from the AVT display. it is one and the same integrated unit
    what tsikot shop did was to retain the AVT HU and added amps, woofer and upgraded the speakers
    Aug 2011
    #2282
    Quote Originally Posted by prime_it View Post
    Glad to know sir. Btw, gaano katagal kayo naghintay sir? tnx
    bale 1 3/4 months... hehehehe...
    woohoo... got my plates... luma na sasakyan... lol...
    #2283
    Quote Originally Posted by obfree View Post
    Sakin bagong-bago, wala pa stickers eh
    May 2011
    #2284
    Yeah, I was basically wondering which of the speaker/amp/sub combos would go best with the AVT HU. the a/d/s - Lighnting Lab combo and Firland - Lightning Lab 1-amp systems were what I had in mind, but as much as I'd like to go with DLS, it's a bit beyond my budget.
    Jul 2004
    #2285
    a lot of members over at MSCP has some really great ICE set up
    one member who is also a tsikoteer, si drivensteven, is a consistent winner
    maybe you can PM him and ask for his suggestion
    #2286
    Napakaconvenient talaga nung tpms nung avt lalo na sa tire rotation. Had free time this morning and i personally cleaned the brakes, plus did a parallel rotation of tires since 20k kms na reading ko. Touch function lang para sa sensor exchange, unlike my previous tpms which cant change orientation Of the sensors
    Jul 2004
    #2287
    Quote Originally Posted by zix888 View Post
    paano yung touch function?
    does this mean that the tpms has to be on all the time, ergo the key is in acc, while all the tires are being changed?
    #2288
    On my fieldmaster oem tpms, when you rotate the tires , you have to remOve first the sensors and retain it to that position,if you want to get the actual readings. because each sensor has only one designated position, like front right sensor for example, if you put that sensor at rear right, and time comes that you need to inflate it because your tpms screen says your front right tire is under inflated, you have to inflate the rear tire because front right sensor is actually there at the rear position. But here in our gtv, after doing the necessary rotation of tires, turn on acc, go to tpms, just touch the front left tire on the tpms screen for 5 sec, tire will turn yellow, then touch the tire which will replace that position, thats it, automatically it will interchange, actual readings na siya. Even yung spare tire pwede din interchange position kaya convenient for rotation
    Jul 2004
    #2289
    .....after doing the necessary rotation of tires ..
    if i get it right, you can rotate first, then after rotation when all the tires are already bolted back on and tightened, that is the only time you can do the recalibration?
    if this is the case, then it is very convenient
    #2290
    That Â*is correct sir, kaya talagang very convenient
    This is the one that i used on my big wheels since i just want to leave my oem sensors there at the stock wheels. This system still needs to retain only one sensor position to get actual readings.Â*
    Nov 2011
    #2291
    H11 , i had mine replaced the next day i got my gtv from the casa. Put 4300k kaya terno sa low beam
    sir zix bago palang po ako sa forum... tanong ko lang po kung pano po nilagay yung HID nyo sa Foglight nyo.. tinaggal po ba Bumper ninyo pra ma install yung HID.?
    #2292
    Quote Originally Posted by reiner08andres View Post
    No need to remove the bumper, just the foglamp cover and the foglamp, makita mo na more than enough yung space sa likod niyan. Madali lang ikabit, installed mine in less than 15 mins
    Nov 2011
    #2293
    thank you sir... musta po pala about sa Cruise Control.? meron napo ba kayo.?
    #2294
    Update agad ako as soon as matapos. Magpost agad me ng pics
    Nov 2011
    #2295
    sige po sir zix...
    Oct 2003
    #2296
    comment ko lang:
    ang tibay ng thread natin hahaha still going strong kahit lumabas na ang 2012 model
    on another note: ano kaya itsura ng 2012 sta fe? ...vgt na din kaya? walang matinong spy pics na lumalabas e. looking forward to it. by next year, baka palitan na namin ang sasakyan ng misis ko. yung heavily disguised pics na kumakalat, mukhang maganda. depende sa pricing, a vgt 2012 sta fe can be a serious threat to the montero's market dominance.
    Jul 2004
    #2297
    Quote Originally Posted by smooth View Post
    comment ko lang:
    ang tibay ng thread natin hahaha still going strong kahit lumabas na ang 2012 model ....
    next year ma testing ang tibay ng thread na ito
    #2298
    comment ko lang:
    Even yung 2011 models ng sante fe is vgt na, tagal ko nga pinag isipan yan and itong gtv eh. Ganda kasi ng makina. 2.2 crdi vgt almost 200 ps and 436nm torque plus 6speed pa, pareho din ng sorento ang makina yan, isa din yun sa options ko, pero gtv pa din pinili ko.
    Oct 2011
    #2299
    comment ko lang:
    2013 pa ang new Santa Fe diba?
    Jan 2011
    #2300
    Yup, I have been following this thread since day 1. Tibay talaga ng thread na ito. I really learned a lot.
2011 Mitsubishi Montero Sport [continued]
