Page 112 of 124 FirstFirst ... 1262102108109110111112113114115116122 ... LastLast
Results 2,221 to 2,240 of 5006
    Feb 2007
    Posted yung link sa PMS thread sir.
    Sent from my Nokia 5110 using Tsikot Forums
    Sep 2011
    Link nalang sa fb niya sir. Naka mobile lang ako e
    https://m.facebook.com/profile.php?id=111752392198163
    Posted via Tsikot Mobile App
    Sep 2011
    Sir zixx, kapag hinugot mo yung atf cooler hose and inistart mo makina on N, automatic na lalabas na yung old atf? Since binangit dun na 3.5L, babantayan ko pa ba yun or kapag 3.5L na yung lumabas, wala nang mag flow?
    Sana magets mo sir haha )
    Balak ko kasi is kung free flowing ang daloy ng atf dun sa cooler, e ididischarge ko nalang lahat dun while naglalagay ng new one sa filler tube. Kapag iba na kulay yung lumalabas, off na ng engine tapos measure nalang.
    Quote Originally Posted by babynos01 View Post
    nope! kasi yung level ng lines going to/from cooler sa tranny side is not same level sa bottom part niya. kaya hindi lahat madrain kahit paandarin siya. you really need to remove the drain plug. no short cut bro
    Feb 2007
    Bro zix, i got the MD050317 instead for the DP GASKET. ;)
    Sent from my Nokia5110i-VgT using Tsikot Forums
    nice find!!!
    Feb 2007
    Just found out that aside from adding to engine oil, this can also be used for transmission oils.
    Quote Originally Posted by butchyboy View Post
    May I know why sir? Nababa na panu yung pan ko, yung "gasket" nya parang paste lng di kagaya nung sa EGR na bakal. Kailangan i strip yung nakadikit na gasket then may linagay na high temp silicone gasket ata
    hindi ko lang sir type yung gasket maker, if may oem na gasket lang sana, sigurado ibaba ko din yan pag nagchange atf ako.
    my axles, feeling happy
    rear axle * 40k kms
    front axle * 50k kms
    transfer case * 50k kms
    ^bro ok ba yung Top1 gear oil?
    Sent from my Nexus 7 using Tapatalk 2
    sa transfer case ko ginamit. 50k kms tinakbo, okay naman
    Sep 2005
    My friend who owns Benmawi autoworks in Binan offered me a free demo use of his ATF changer/Dialysis machine.... I used up around 9 liters of Caltex DIII ATF.... My old fluid did not looked that used since it was "sweetened" at 15,000 kms ago.... Loved how the machine literally sucks the old fluids...
    My rig now shifts smoothly.... It takes around 15 minutes for the process... worth the effort if you can.
    HTH
    Jul 2004
    Quote Originally Posted by petixs View Post
    HTH
    How much did the service cost and where is the exact location of the shop?
    HI Prez,
    Its near south woods exit... Its actually registered in Google maps, just type in Benmawi autoworks.
    What we used is the suppliers DEMO unit. I think he's going to buy one but it's going to be a month before it comes to the shop. He just invited me to the shop as a "guinea" pig.
    The owner is a Honda Plant employee who decided to take the plunge and go for business himself with some Honda folks.... They are extremely knowledgeable with anything Honda, as most of his clients are Honda Owners but non Honda owners also go to his shop, as all vehicles are basically the same, save for the parts and some proprietary stuff. I'll just update the board on when his ATF/dialysis machine comes.
    HTH
    Quote Originally Posted by vin0929 View Post
    Goodevening po sa lahat. beginner po ako dito sa tsikot. I got a 2nd hand monterosport 2010 Gls 4x2 AT last May 2014 at 46k mileage. napa linis ko na po egr sa eldorado dahil ng cel. mabuti at nawala ilaw after 2 days na malinis. binasa ko talaga mula umpisa hangang dulo ang topic para sa montero at madami akong natutunan. Tnx sa magagandang paliwanag ni sir Six sana pare matulungan mo ako sa mga dapat ko pang gawin dito sa sasakyan. Maraming Salamat at pacencia na at hindi pa ako sanay.
    welcome sir. btw nagprivate message po ako sa inyo. pa check na lang po. thanks
    Sep 2014
    Tnx Bro. Zix for blanking my egr and installing cabin filter. Next week OCC nmn at trottle control. Nice meeting you pre'
    thanks din bro, nice meeting you too. kinis ng monty mo, jackpot ka na diyan!
    touchdown!!!!
    k&n's
    auto dimming rearview mirror
    obd2
    Mar 2011
    Mga sir san na nga yung DIY ng SCV at diagram. TIA
    May 2011
    hi zix888. just want to inquire re cabin filter and egr block thanks
2011 Mitsubishi Montero Sport [continued]
