hi guys san kaya ako pwede makbili locally ng sd card extension cable para sa navi ntn?hirap kas mag tanggal ng cover e.
^ nice
makes the sd card slot very convenient
how did you secure this? double sided tape?
kudos
:thumbup:
Had to make a custom opening in such a way that the sd card slot will be forced fitted plus wrapped around double sided tape. Because if just mounted with double sided tape, you cannot close the compartment. Pretty secured mounting naman siya, so anytime may update, its really very convenient to get the sd card. Thanks
Did anybody also tried using 'destination - intersection- press any letter, then it hangs' on the 1.9a version? Seems to be the same issue with this sequence on the 1.7a version...![]()
i am still on v1.7a and when i entered this sequence, my unit did not hang
in fact, sobrang daming POIs with PA na lumabas including PArking garage entrances
so far, even the 1.7a is good
got me from makati to alaminos and back on two different routes (via zambales going there to enjoy the scenery and via tarlac going back) accurately
EDIT: the sequence i did was menu -> destination -> POI -> P -> A -> Go
i did not use intersection
Yeah, tried this on my white version 1.7 and worked fine.Originally Posted by 111prez
I've noticed version 1.9 can detect speed cameras at slex. Dunno how's that but I slow down. And they've updated the animation at skyway to look more real.![]()
Sir zix didn't know what happened to my sd card extension. Tried calling to follow up but they didnt understand my mandarin... I just let my friend talk, but, only in his free time. hopefully I get this month.Originally Posted by zix888
Thanks 111Prez/Zix888. Had already informed iNAV on this and they will let me know daw tomorrow for the new patch/revision. They are sending a link via email quarterly. It is an executable file to load the latest revision. Will update once may balita...
Hi monty gurus.has anybody experiencd hanging on their gps?car's location wont move or cant find satellites.thinking of resetting but worried of losing maps.thanks in advance
resetting (meaning pressing that teeny button on the left hand side of the head unit) will not make you lose your maps
i already did this before when my lcd screen hangs
but just in case you do lose your maps for some reason, then its off to warranty claim for your avt unit
nice sir very convenient talaga pag may extension cable.
btw, sir magkano bili mo sa extension cable mo?un pinagtanungan ko sa china grabe it cost me $159 kasama na shipping.ganun ba tlga price nya?here's the link
Buy SD extension cable with case, sd card reader cable, micro sd extension cable, Patent 15P 46cm SD card extension cable with case at Aliexpress.com
Sir I got it for 25rmb = 180php. Medyo pricey yata nakuha niyo sir.Originally Posted by chasezhian
Resetting will not erase the maps sir. The only way you can lose the maps is when you erase the contents of the sd card. Our navi is really dependent on the sd card. I already tried turning on the navi without the sd card, and it would not open. Also tried to put other maps on it, working but distorted. Check ko nga yung mga files one by one nung sd card baka may pwede upgrade like the voice or instead na arrow i could change it to vehicle just like the portable navis na downloadable mga sounds and figures, pero so far dead end.
