Page 82 of 103 FirstFirst ... 327278798081828384858692 ... LastLast
Results 1,621 to 1,640 of 2054
    Jul 2010
    #1621
    #1622
    awesome GTV sir expatio!
    looks like the garage is still under construction...
    Jul 2006
    #1623
    Hi Expatio,
    You mentioned about Tinting a few post back. Which have you decided to get? Black Chrome or Color Stable?
    May 2007
    #1624
    Finally!!! :rockon: Congratulations Sir Expatio!!! you finally Got To haVe it!!!
    Jul 2010
    #1625
    Quote Originally Posted by Thumbdrive View Post
    Thank you Sir.
    This is the garage under construction:
    Two bays will be converted to a temporary apartment for ako.
    All the other buildings in the photos are part of a small hotel complex
    I like this post, very creative sir. hehehe
    #1627
    Quote Originally Posted by zix888 View Post
    Offset is +38mm, this is a very high offset, hard to get especially if you are planning for a 26s or 28s. I had to get a custom made offset of +40 mm size 28"rims for my gtv
    Thanks!I'll keep that in mind.
    #1628
    Quote Originally Posted by don View Post
    thank you sir
    replaced it with a chubby type nahahabaan ako sa orig hahaha
    Thanks! Ako din, the long antennae should have been at the back.
    #1629
    ok naman reception sir wala naman ako napansin nagbago kasi radio antenna talaga sya (Foliatec brand) hindi tulad nung ibang nakita ko dun nakadisplay parang aesthetic purpose lang
    sirs, i hope you do not mind my joining you guys, i have been readin up on the monty and this is most informative, sir magkano foliatec bili mo? mahaba nga ung antenna, parang 80's na antenna ang dating, tks for any info chief
    May 2004
    #1630
    Quote Originally Posted by pr462 View Post
    500pesos po yung Foilatec sir
    Feb 2011
    #1631
    Mga sir masyadong mausok itong GTV ko. lalo na pag umaarangkada ako. black smoke xa since. katatapos ko lang mag pa 1st pms kahapon. normal lang ba itong black smoke? or what's wrong with the unit?
    Feb 2011
    #1632
    ito po GTV ko.
    #1633
    Share ko lang mods on my gtv,
    -28" chrome rims 295 25 28 tires
    -bosch europa(cover removed so that it can be positioned to the same spot of the oem)
    -4500K HID foglamps
    - PIAA frameless wipers
    -clear tints v70(Vkool)
    http://m1085.photobucket.com/albumvi...f5l0E%2F3yw%3D
    May 2004
    #1634
    Quote Originally Posted by maz7487 View Post
    sir since kakaservice lang kahapon did you ask that questions sa casa? i think hindi po normal ang black smoke but the casa should be the one to tune it for you para hindi mavoid warranty ng GTV nyo sir
    May 2004
    #1635
    -4500K HID foglamps
    *zix888- those rims are awesome
    May 2004
    #1636
    guys do you have the manual for the Information Display?
    i dont have one
    did you notice the poor chassis paint if it has rust on some welded parts?
    mine has
    does your Montero comes with a factory undercoating?
    mine only on the rear wheelwell
    #1637
    thank you sir
    #1638
    i dont have one
    mine has
    same with my gtv sir, no manual for the avt unit, and i had to retouch the paint on the chasis because of that same rust on the welded part. i just used spray paint, just a little retouch.
    #1639
    sir i dont know if it's normal or what, but the black smoke is one behavior of a diesel engine especially kung unang hirit after a while na easy driving. But after that black smoke, dapat wala na. i have been using diesel engine for only 10 years now, and i have been observing and studying its behavior. I tried bullying ALL the SUVs with diesel engines and all of them have that "black smoke" (even X5 and XC90 produces that scary smoke, no exception) when they give in to my temptation.
    Feb 2011
    #1640
    So sir zix888 are you suggesting i should wait for a while for the black smoke to disappear? Para kasi siyang malaking truck yung pang cargo kung aarangkada ka ng mabilis.hehe
2011 Mitsubishi Montero Sport [ARCHIVED]
