Congrats sir ChoyJo. Ano po tint and variant ginamit nyo? i like the fit with your black GTV.
Black din po kasi color preference namin and based on the photo taken inside the MS, eh di gaano compromised yung visibility.
TIA
TIA
thanks for the informative article... actually, i have a strada (and a tscp member too) and there is a section in the manual that you should not excessively idle since it is a waste of time and diesel... sabi pa nga eh dapat after starting, go na agad... unfortunately, i browsed through the manual of the montero pero wala akong nakitang ganitong quote... hirap tuloy iconvince ang oldies lalo na at sasabihin niyang "50 years na akong nagdridrive".. hehehehehehe... anyway... thanks again...
Ha ha.
Sure people still warm up their cars in the cold of winter; but not for the reasons the writer gave.
The main reason would be to bring the coolant up to temperature in order for you to have the heater working. There would be two reasons why I would want the heater to be hot.
One being, if you leave your centrally heated house at about 22C and get into a car that is well below freezing it is not a nice experience.
The second (and most important) reason would be to keep ice and mist off your windscreen.
Some expensive cars overcome these problems with supplementary electric heater on remote, heated washer nozzles, and even heated windscreens.
I would never idle my car on startup for any other reasons other than that; but that does not mean I would rev my car up to the red-line immediatly after starting. Of course that reason does not apply here in The Philippines
As we all know after some heated driving it is good to idle a turbo diesel for a short time before shutting down
The article forgot to mention that metals expands proportional to the increase of heat. That parts fitted together has to receive and retain heat in a gradual manner and of the same rate in order to maintain clearance or in-case of forced fit parts, to maintain tightness of fit.
Example:
The dynamic and static duo... called piston and liner.
Liner is very thin and is surround by engine block and some hollow spaces that contains water.
When heat from combustion is received by the liner, the heat is almost immediately transferred to the engine block and water around it. Therefore the liner cannot retain heat and any increase of the diameter of the liner will depend on the increase in the diameter of the bore of the engine block. Problem is, the entire engine block has to be heated also in order for the bore diameter to slightly increase.
It will take some minutes to heat-up the engine block. This is the main reason why in cold countries they have electric heaters for engine block. This is also the main reason why there are aluminum alloy blocks (aluminum is very good heat conductor) which is more widely known for weight reduction.
Now, piston is aluminum alloy, a very good conductor of heat and since it is like floating inside the liner, it dissipates heat through convection, radiation blah... blah and a very little conduction going to the piston rod via the pin and oil.
In short, piston retains the heat of combustion and it expands depending on the amount of heat from combustion.
When piston expands while the liner have not yet, the piston pushes the piston rings harder towards the surface of the liner and it creates abnormal wear or may scratch the liner.
Next example will be the valve seat and cylinder head... but I think no need to explain for now. The above explanation would be enough to give credit to what your father is doing.
As long as the smoke coming from the engine does not pollute your home, there is no wrong in idling the engine for a few minutes. But of course don't do it excessively as what the manual says.
Which dealer would you recommend for service? I've heard horror stories re: Citi and Union Motors
Do you mean how many minutes? It depends on the actual measurement and the location (ambient temperature).
Since you ask specifically, here it is:
If the 4d56 diesel engine coolant temperature reaches over 82 degree Celsius.
Oh no you have to use a laboratory grade mercury thermometer, have to open the radiator cap and dip the thermometer if you want to measure that.
Take also the time how long it takes to reach that 82 degree temperature.
Post the time here together with the ambient temperature during the time of measurement .
By doing so everyone will now know how many minutes is considered excessive specifically for hot country like the Philippines.
