Results 2,111 to 2,120 of 5002
August 15th, 2011 12:06 PM #2111
It is almost a week since I switch to Hurricane air filter & its early to say about the filtration effect, even the KNN filter ,the filtration is ??? compared with the OEM , the two mentioned brand has no filter pads so the possibilities is not good as the original when it comes to filtration, yung nga lang parang sakal ang air intake , whereas the Hurricane & KNN malakas ang intake. What I did is a bought thin layer of air con filter inilagay ko sa ilalim, for the cost of Pesos 100+ you buy in any hardware stores & cut 6 sets of filter, in that way i have initial & secondary filters. Your worries goes same with other drop in filters without the pad filters.
RTS
August 15th, 2011 04:24 PM #2112
- Jan 2011
- 27
August 15th, 2011 05:22 PM #2113
August 15th, 2011 06:53 PM #2114
- Mar 2009
- 154
August 16th, 2011 10:31 AM #2115[QUOTE=RTS;1801561]It is almost a week since I switch to Hurricane air filter & its early to say about the filtration effect, even the KNN filter ,the filtration is ??? compared with the OEM , the two mentioned brand has no filter pads so the possibilities is not good as the original when it comes to filtration, yung nga lang parang sakal ang air intake , whereas the Hurricane & KNN malakas ang intake. What I did is a bought thin layer of air con filter inilagay ko sa ilalim, for the cost of Pesos 100+ you buy in any hardware stores & cut 6 sets of filter, in that way i have initial & secondary filters. Your worries goes same with other drop in filters without the pad filters.
sir RTS anu filter binili mo sa hardware, parang dishwashing foam ba ito, may pictures ka ba so i can see, Thanks
August 16th, 2011 12:46 PM #2116
[quote=marktriton;1802012]
sa ACE hardware ko binili , just tell them filter for air con(household) ,usually naka plastic na sila at precut na for window type aircon.maraming klase but I chose yung pina ka manipis, then with the old OEM sinukat ko lang ,then cut & I produced around six pads, matagal tagal na rin gamitan yun, It is not a special type of filter, commonly use sa aircon, there are thick, & thin around 5mm, kasi pag kinapalan mo it may cause again some restriction in air intake.
RTS
- Jan 2011
- 27
August 16th, 2011 05:39 PM #2117
- Jul 2011
- 21
August 17th, 2011 06:59 PM #2119Good day!
I heard from one of the S.A.s here in western Visayas that 2012 strada will be out either 1st or 2nd week of September.
Manual Transmissions will have VGT. the other one told me that 2.5 gls and glx will have ABS-EBD. How true is this?
Thanks!
