sir standard naman po na may 20k discount ang strada.
Good day to all
just like to ask kung panu malalaman kung gumagana ang turbo sa 3.2 engine, any sign kung sira ito.
thanks![]()
may ABS na rin pala tong 2012 Strada GLX, ewan ko lang kung may EBD.
sorry doube post
HAHAHA! naduling na ko....
thanks for the correction....
anyone can confirm the specs of the GLS-V M/T 4x4? sa australia kasi it has a higher torque output than the automatic tranny...400nm as oppose to the automatic na 350nm lang...sana nga ganun din dito...hehe
sir tanong ko lang ilan po ang Fuel Consumption ng Strada? malaki po ba difference ng 2.5 to 3.2L sa FC? magkakaroon po ba GTV na 3.2?
Nakakatakot pala to force your way through a flood! Last week, bumaha yung road na dadaanan ko. Everybody had stopped. I saw a truck that was brave enough to go through. Bumaba ako to ask some folks gaano kalalim. Sabi daw medyo above the knee. Sige, subukan natin. Sugod! The water slowly but surely started to go up, up. Then all of a sudden, the flood water in front started to slosh over and above the hood, and the headlights disappeared into the murky waters. My son at the back started to say: we are going to float, we are going to float! The rest were quiet. Slowly, nakikita ko na yung dry road in front, pero water still slosh in front. Alam ko na ang feeling ng statement: so near yet so far. Eventually, nakalusot na ako! Pero pucha, nanginginig talaga ang left leg ko, halos di ko na ma control ang clutch. After we successfully passed through, my wife told me: Nakikita na niya yung baha sa bintana niya, around 1 1/2 feet from the window na lang and she was looking around the door if the floodwater would start to enter!
I eventually reached my destination and checked the car. I had basura sticking to the front grill, aside from some weeds sticking out the front bumper. So far, all lights, and my original horn and 2 sets hella supertones still functioned. Yung bag nasa cargo box, basa na ang bottom ng bag, which meant pumasok na sa likod yung tubig!
Kudos to our Strada! Pero di ko na uulitin! My heart, my knees! Di ko kaya!
^hehe...good to know you were able to pass through the floodwaters....hinding hindi ka talaga bibitin ng strada hehe..
Whoa! Ang lupit nyan, boss! Buti hindi pumasok sa air intake ang tubig. Hanggang upper level ng front bumper pa lang na-try ko, with splashes just reaching the headlight. Di basta-basta papasok ang tubig sa cabin natin. Double kase ang weather strip/gasket (isa sa door at isa sa door sill). Unless binutasan yung rubber cap (around 1.5inches diameter; visible from under the vehicle) sa ilalim ng left rear passenger floor mat (most technicians use this to route wires from the outside into the cabin when installing aftermarket accessories). Yung foglights din natin di basta-basta papasok ang tubig (nagtaka nga ako kase may excess heat outlet tube naman siya sa itaas). Yung disc horns water resistant compared to trumpet/snail shell horns. Wag mo lang gamitin ang foglights at horn pag lumusob sa baha para siguradong di masira.![]()
Just to add on the clutch thing, I actually don't use the clutch if fording flooded streets. The idea is to avoid the clutch slipping. Just transfer to the lowest gear (4L if you have) and keep enough distance on the car in front of you. Or best is let the car in front passed and clear the flooded area before you go (if possible). My .01 cents
Nice experience though.![]()
