Results 2,001 to 2,010 of 5002
July 25th, 2011 05:05 PM #2001
July 26th, 2011 12:42 AM #2003
- Feb 2008
- 162
July 26th, 2011 01:41 AM #2004Just to add to what S'theparanoid mentioned,
1) try not to fill up gas when you see a tanker unloading newly delivered gasoline as this stirs up sediments in the bottom which could clog up your SCV.
2) change fuel filters regularly or as most people here are recommending at least 5k kilometers before the scheduled maintenance replacement of the fuel filter. You may also try changing to aftermarket fuel filters though I personally haven't done this yet. You can check the threads regarding fuel filters.
3) Just in case you still are worried about it, kasama naman po sa warranty yan.
Please do note that these are just recommendations to possibly avoid problems earlier on in the life of your ride and are not absolutes. Problems with the SCV still does happen but not as rampant as before. I guess its also partly due to the kind and super helpful people of this forum kaya nakakaiwas na po sa problems.(Maraming salamat po!)
I've been using Petron turbo on mine and at 15k, wala pa naman problems. There are also other gas stations that came out with a higher euro compliant diesel, though not as tested as with the big three. I believe most newer diesel models will sooner or later have problems with their SCV's because of the type of fuel we have or at least the type of maintenance the gas stations have of their fuel depots. Lastly, try not to worry too much about it and ENJOY your ride. Hope this has been helpful.
July 26th, 2011 10:17 AM #2005
Hi,
If you have 3.2L engine ,the 8.5 ltrs of oil is normal to be expected, sa bagong oil filter lang pag refill ng langis is already 1 ltr, about the engine warning I was temporary relieved dahil nag disappear, but last night bumalik na naman, pababayaan ko na lang muna as long as walang problema ang accelaration ko, kung baga immune na ako sa engine warning light.
Regards & Safe Happy Driving
RTS
July 26th, 2011 11:04 AM #2006
I used V-power since the unit was new, still got the SCV issue. Replaced already, even when the unit was still in it's first 1000 km, I could already sense that there was something different with the sound of the engine. IMO, it doesn't matter which fuel you use (as long as you stick with the big 3), if you have SCV issue, it will eventually present itself. Better to have the SCV symptoms come out while you're still under warranty.
- Jul 2011
- 21
July 26th, 2011 11:20 AM #2007Hello!
Just wanted to ask if i have a 2.5L 4x2 strada, what gasoline company should i use? Caltex, Petron, Shell?
Thanks for the insights.
July 26th, 2011 11:24 AM #2008
Hi,
about the SCV issue, pang apat na experienced ko ang engine warning light, the 2nd one is according to the casa they need to replace the SCV dahil it affected my acceleration, since it is still under warranty no sweat. The rest no change of SCV ,only cleaning of EGR, Exhaust manifold & other ancillary parts. It is not always the SCV is the culprit but other parts. Now na I'm off the warranty period & if in case I need to change the SCV, tumataginting na Php 5K plus ang kailangan. Im beginning to doubt the parameters set by the manufacturer dahil ibang pick up of different makers wala naman rampant problem na ganito.
RTS
- Feb 2008
- 162
July 26th, 2011 08:22 PM #2010
Daming issue ng SU7:grin:
Xiaomi E-Car
