Page 98 of 250 FirstFirst ... 4888949596979899100101102108148198 ... LastLast
Results 1,941 to 1,960 of 5000
    May 2011
    #1941
    Sino sino nasa malapit sa dona solidad st.? mga taga multi N., moonwalk or betterliving area area dyan? Masmaganda if may Taga strada club officer mismo na makasali para pa member na mga gusto magpa member.
    Alam ko may isa na member nang strada club na taga multi national area lang nakatira.
    Dec 2010
    #1942
    Quote Originally Posted by theparanoid View Post
    +1
    it happens to me as well, and it turns out yung seatbelt.
    or kung di man check na din yung likod ng sandalan ng backseat, make sure tight yung mga gamit don. (including yung bar)
    +1 din ako dyan, Annoying yung sound talaga, seatbelt lang pala problem...
    Dec 2010
    #1943
    +1
    Oct 2009
    #1944
    Quote Originally Posted by gpb77 View Post
    ako sir taga multi / moonwalk ako. di pa nga lang nakakabit yung club sticker.
    May 2011
    #1945
    Quote Originally Posted by bigtrak View Post
    Ayus sir. Pwede tayo Magkape kape along dona solidad.
    #1946
    OT... any feedbacks on the cooper tires A/T and STT? Gusto ko sana yun STT tapang tingnan kaso I'm worried kasi I will be driving mostly on road. Will the difference in the STT and AT be noticeable for the driver?
    Salamat :D
    Dec 2007
    #1947
    Quote Originally Posted by sphinx1228 View Post
    Salamat :D
    stt ba yung equivalent ng mud tires? if yes, very noticeable ang vibrations and tire noise, tapos medyo hahaba ang braking distance mo. acceleration and top speed will be lesser din. and according to arvin, mas mabilis mapudpod kung mostly highway ang takbo mo. pero other than that astig naman ang looks ng gulong mo hehehe
    Jan 2008
    #1948
    yup, STT is actually the m/t of cooper. Basta ang rule of thumb pag sa gulong is if you will be doing mostly paved roads, stick to h/t, 60/40 paved/gutted may h/t na kaya pa eto. 50/50 get a/t. 40/60 - may a/t series na kaya pa eto. any other ratio get m/t.
    reason for this is that the more tire contact you have with the ground the more control you get, more grip on the road and breaking efficiency and better fuel economy because of less air drag due to the bigger lug spacing. Tire life gets shorter when tire lug spacing gets bigger, kasi mas kumokonti ang goma na may contact sa kalsada.
    #1949
    kala ko pa naman pwede gamitin ang cooper STT for everyday use. I will be mostly on paved roads so H/T really makes a logical choice. However, when emotions come to play then STT is the more appropriate choice since whenever you look at your truck with those M/T it makes you smile :D
    Salamat sa advice! At least makakatulog na ako ng mahimbing at mababawasan na pagiiisip ko sa goma.:nightf:
    Oct 2004
    #1950
    Mag-Cooper S/T nalang, sir. All-terrain pero mas maangas lang ang tread.
    COOPERS WIN 4WD TYRE TEST
    #1951
    Quote Originally Posted by doy View Post
    Checked with Ryco and the AT3 are around 8k and the STT's are 12k so I am assuming na yun S/T's are in the middle so mga 10k? This is for 265/70/17 tires.
    If the s/t's are in the 10k range might as well get the pirelli scorpions atr. Mas logical ba na choice yun pirellis?
    May 2011
    #1952
    sirs, 1st time here ;) ... i'm planning to buy strada 2011 glx this Aug but accdg to my dealer may lalabas daw na 2012 model this Sept. question is any idea what was the diff of 2011 vs. 2012? thank so much in advance...
    best regards
    #1953
    dont know if I posted this before. but try mo to
    Yahoo! Image Search Results for cooper st maxx
    Quote Originally Posted by ARB View Post
    Oo nga, ganda niyan, very happy ako with Cooper, mura but very good quality!
    Oct 2004
    #1955
    Check nyo din kung meron nang S/T Maxx:
    Cooper Discoverer S/T Maxx - Toyota Tundra Forums : Tundra Solutions Forum
    Baka close lang ang price sa S/T. Mas maganda kase ang sipping ng bagong S/T Maxx. Lesser chances of hydroplaning. Tapos maangas pa yung tread extension sa sidewall.
    #1956
    Sir Ry, which Cooper tire are installed in your Strada?
    Jan 2008
    #1957
    yung cooper s/t maxxx is a great design.. in between siya ng stc and stt. highly reccomended siya ng cousin's ko sa states and australia. only problem here is wala pa yung stock nila and limited lang din daw ang size according to ryco. as far as pirellis go, pwede na din sila pero may issue with the rubber compound as being to soft, so tire life is greatly reduced, ika nga parang erraser na nauubos sa kalsada. i think bridgestone has a good a/t design na ngayun. hindi ko lang matandaan or was it dunlop? hehehehe try nyo tanungin si polpol, naka 265/75r16 siya na a/t ngayun
    Jun 2007
    #1958
    sir, anong size yung STT na 12k na tinanong nyo? weird naman...kasi huling tanong namin not so recently yung 285/75/16 9.7k lang..
    Jan 2008
    #1959
    o nga naman noh!! bakit ang mahal naman niyan? ano sukat nang pina quote mo? kasi yung huling quote ko din para sa 265/75r16 was Php8,900
    Jan 2011
    #1960
    Quote Originally Posted by uj1n View Post
    best regards
    hmmm... interesting.
    first time im hearing about it.
    were you able to ask kung all-new daw po ba or facelift lang?
    at any rate, i believe kapag maglalabas ng new models magbaba ng price for the current one.
    so it should be a win-win situation for buyers (ingat lang sa 'paradox of choice')
2010 Mitsubishi Strada [continued 2]
