Results 251 to 260 of 808
January 4th, 2022 04:55 PM #251
My sweet spot is 40psi cut-in, 60psi cut-out. WellMate specifies air pressure to be 2psi less than the cut-in. Therefore, 38psi on ours.
Below is the applicable snippet to your question from the WellMate guide.
Sent from my SM-G970F using Tsikot Forums mobile app
- 54,219
January 4th, 2022 06:55 PM #252we purchased our 1 hp eurostar pump from shoemart, more than three (five?) years ago.
it cost a shade less than 9K, at that time. after all these years, ok pa naman. it was almost noiseless at first. hindi naman masyadong maingay now.
we have a non-pressurized open-top tank connected to nawasa. it is always full, thanks to nawasa. a float valve similar to a water closet's, prevents overflowing.
alas, no failsafe in case of low water level. "katok and silip" system lang.
our eurostar pump sucks water from the above tank, and pushes it into a ready-made, locally-made stainless pressure tank. cut-off psi's are 40 and 60.
every so many months, when the air bubble decreases, we drain the pressure tank of all water. to make it easier for us, we did the ff:
we had the local tubero attach a length of nawasa pipe with gate valve, under the tank, via the drain plug. medyo mahirap kasi tanggalin at ikabit ang drain plug namin.
we have a basic vespa air compressor that we use in inflating our cars' tyres.
using a length of garden hose attached to the nearest gripo, we push air into the pressure tank using the vespa, to hasten water drain from the drain plug's tubo.
without that vespa, the drainage process takes the better part of half a day.
once completely empty of water, which takes less than 30 minutes, we simply close the drain plug's valve and the tank is good to go.
we have had no problems with it, for several (five?) years now.
we used to have goulds, back when our home water supply was from deep well system.
for some reason, that pump would ground itself on a regular basis...Last edited by dr. d; January 4th, 2022 at 07:15 PM.
January 5th, 2022 08:57 AM #253
Should there a water supply switch between the water tank and water pump? ...
- 54,219
January 5th, 2022 10:29 AM #254
January 5th, 2022 11:16 AM #255
You'll need a a float switch(to safeguard the pump if tank runs out w/ water), a manual pump switch(magnetic or breaker) & a valve from tank to pump. The latter 2 are necessary for servicing/replacing the pump, as doc advised above.
An added note, for some reason(orgasmic alarm pheromones perhaps?[emoji848]), ants love to gather around outlets & pressure switches. Contact can be compromised. Inspect & debug these periodically.
January 9th, 2022 09:53 PM #257
Remember, you're in Tsikot....that garage won't be enough.[emoji4]
January 10th, 2022 10:03 AM #258
That's why it's efficient, coz his frontage can fit a least 1 more car or 2 minis [emoji38]
January 10th, 2022 01:55 PM #259
The circulation is odd though
You have to go through all the bedrooms before getting to the living and dining
Enclosed garages are also rare here, probably because of snow
Is this floor plan of a house abroad?
BANNED BANNED BANNED
- Aug 2021
- 132
January 10th, 2022 03:49 PM #260Di.pwede sa amin yan, daming magkaharap na pintoan. [emoji16]
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
